#29 |
Ok, OP. Mixed in with our usual ribbing are some valuable observations. Let us know which parts make sense and which, if any, leave you scratching your head.
#30 |
Maybe the OP went and turned off all the nannies and took that 40 degree (C or F ...??) at 60 mph and is now doing laundry .....
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (03-25-2017) |
#31 | |
![]() Oh wait...
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#32 |
104F?
#34 | ||
Drives: Black 2013 Scion FR-S
#35 |
For the mos part it seems the car i just not made for this, the only other suggestion was to mess with the camber which idk what to put it at and front or back? Not very specific. I also had this problem before new tires so its not that
#36 | |
#37 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
http://www.ft86club.com/forums/showthread.php?t=103609 |
#38 | |
1. What car have you driven that does what the frs doesn't do? 2. When the VSC kicks in, which end is letting go? 3. What's the outside temperature when you are driving 4. What's your tire pressure. If they're not even, tweak them and try again.
#39 | |
Drives: 2013 BRZ Sport-tech WRB
I changed mine at about 25,000 km. Before changing, the LSD did not engage smoothly at all, it was like an on-off switch. Afterwards it was much more progressive, with a lot less tire squeal. I'm up to around 45,000 km on the car now, and the LSD still works great, so I think the issue was more down to diff gears wearing in than short fluid life. |
#40 | |
Drives: 2013 FR-S 10 series [755]
My dealership actually told me to flush my brake fluid when my car only has 19000 miles...There is no way to refuse a simple job where they can make big money....you know...dealership.. |
#41 |
Huge E85 fan!
Drives: 2016 Scion FRS
OP, are you sure you're not bottoming out the suspension or getting some bad rubbing? You are lowered, bigger than stock tires and that's a lot of load in that corner. Have you tried returning to stock springs just for a test?
#42 |
I had thought about this bc i never had the problem before new tires and lowering which was over a year ago. But i also did not drive my car as hard as I do now either. DOnt have the money to put springs back on lol but thanks for the suggestion
| SPC LCA Alignment Issue? | ssidd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-15-2018 12:58 PM |
| FRS Bumper alignment issue, help please | Brody602 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-04-2015 02:27 PM |
| Do I just need an alignment or... (scraping issue) | IDFWU 420 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 12-26-2014 12:26 AM |
| Alignment issue | guscab | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-08-2014 10:26 PM |
