Old 02-27-2017, 03:26 PM   #29
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I'd be surprised if they give you exactly what you want, a good shop will hit every number you request precisely, but it looks like they'll give you an alignment that's 'good enough' for a decent price, and they seem competent, it's just that for what you paid them they're not going to spend a half hour tinkering to get exactly what you ask for.
If you want it perfect, you'll have to go to a shop dedicated to performance cars and spend probably around $200, if not more. But it should be good for quite awhile.
Come on man lol youre making me sad af, I just spent 200 on it for their life time alignment plan........I'll fix the front and then see if they can get it taken care of.
is a -1 Rear good or bad? That's basially where I'm sitting at right now lol
Alltezza is offline   Reply With Quote
Old 02-27-2017, 04:43 PM   #30
strat61caster
strat61caster's Avatar
Maybe I'm wrong and he was wise to not get it dialed in just right knowing you'd be back. But if it was a quality shop they would have nailed the rear end knowing it wouldn't need to be changed when you came back next time. The camber and toe variance left/right on the rear leads me to believe they won't put in a serious effort next time you visit, but hey I could be wrong.
-1 Rear camber is a good streetable number imo, which is the topic of this thread. OE tends to land between -1 and -1.5 from the factory, pick a number that feels good in that range, more negative for more aggressive driving, less negative to get a touch more life out of the tires (and we're talking like a couple hundred miles here tops).
Be explicit about what you want otherwise you may not get it. I don't know what you want, but asking to match left and right sides is a reasonable request with regards to camber and toe given the parts you've put on the car, there's no reason they should deny you.
Edit: It should be clear that I'm talking about nailing it, perfectly equal numbers left to right (at most 0.02 different), less than 1/10 away from what you requested if not spot on. What they've provided you is totally acceptable for a DD and occasional fun car.
ineedyourdiddly
Old 02-27-2017, 04:56 PM   #31
jamal
jamal's Avatar
Drives: Legacy GT
-1.5 in the rear, -2 up front is a good starting point that will keep your tires in good shape shape improve how the car handles.
Go out and find a fun road and take a few trips down it before you bring it back in. Then go do it again, you should be able to notice a difference.
jamal is offline   Reply With Quote
Old 02-27-2017, 05:17 PM   #32
Alltezza
Alltezza's Avatar
Yeah I'm gonna go back when I get time to go back and rotate the Front Left Coil.
I'm starting to think he does say "MAXED OUT" is that he's probably thinking that's the lowest "Positive" camber he can get it to, in terms of getting it close to zero.
I'm confused though....I gave them these instructions.
-2 Front camber
-1.6 Rear camber
0 Toe front
1/16 total toe-in rear.
But I'm looking at the paper it came out in this format.
"-2 Front camber -1.6 Rear camber 0 Toe front 1/16 total toe-in rear."
Maybe it's just a misunderstanding, but either way the car drives fine, and I don't have to hold my steering wheel in a "turning" position to drive straight anymore lmao.
Thanks guys, I'll be back with an update. You guys are awesome lol
Old 02-27-2017, 06:51 PM   #33
Ry.ruzn
Ry.ruzn's Avatar
I thought I'd come in, now. When I first turned on my car and started driving it.....damn was the car wobbly af. Also My steering wheel had to be turned slightly to the left to drive straight, and then my ABS and TC light came on lol I was freaking out but I figured it was because I most likely needed and alignment.
Anyways I finally got my alignment done....kinda LOL turns out I'm a dumbass and installed one of my coils wrong.....
The tech came out and wanted to talk to me and was like "Yeah I can't adjust your camber, one of the camber plate is wrong."
Basically my right coil is PERFECT but then my left is......yeah.
Well you live and you learn, to everyone installing coils for the first time....it should look exactly like the first picture above. Make sure you check the weather that it doesn't randomly rain and get cold.....damn it TN weather LOL.
Well this is awkward, both my coils are wrong then. I had mine installed by a incompetent shop in PA. Both left and right look like the bottom pic 😑, I still got a good alignment the way it is at AZP though. Do you know if anything negative comes of having the coils on this way or is it as simple as lifting the vehicle holding the suspension up from(where?) and rotating the plates to the correct position?
Ry.ruzn is offline   Reply With Quote
Old 02-27-2017, 07:09 PM   #34
jamal
jamal's Avatar
Drives: Legacy GT
Putting them at an angle can be a good thing. On a street car, you're not going to be using all of the adjustment anyway. So putting the top of the strut in and farther back gets some extra caster but not as much negative camber. It needs to be like this though:
Old 02-27-2017, 07:14 PM   #35
strat61caster
If the alignment is where you want it, then there's no problem leaving it as is.
Rotating the top hats will mean your camber, toe, and caster are likely to change. I'd bet it would still be drivable but it would be out of whack, potentially causing the car to pull or wear tires unevenly, strange handling quirks, etc. You'd want to have it aligned after you do them, I'm surprised the alignment person didn't comment on it...
Like Jamal said, it can be advantageous on some setups to get some additional caster, but I wouldn't say the 86 is a car where it's worth it.
ineedyourdiddly
Old 02-27-2017, 09:40 PM   #36
Ry.ruzn
Ry.ruzn's Avatar
This is mine. Guess I'll be alright then without the added benefit of extra caster. Ill get it redone the correct way when I go to AZP once I put my summers back on.
Thanks Guys.
Old 02-27-2017, 11:29 PM   #37
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I use Firestone to ballpark stuff in between getting real alignments. Sometimes the hit my numbers and Im good. Other times not so much. But For the amount of times Ive changed suspension and dont have a good alignment place close by its worth it for me so i dont destroy my tires waiting to get a real alignement
Old 02-28-2017, 04:06 PM   #38
FaDuck
Drives: 2014 UltraMarine FRS
So after reading all the excellent info given in this thread, I have 1 question.
Does all the info given apply to staggered setups as well? As far as camber and toe go.
FaDuck is offline   Reply With Quote
Old 02-28-2017, 06:23 PM   #39
cjd
cjd's Avatar
Drives: 2017 BRZ
Staggered just screw's things up... But it should not need a different approach. Alignment is about optimizing contact patch, wider tires doesn't materially change the dynamics.
Old 02-28-2017, 06:33 PM   #40
strat61caster
Relatively speaking yes since this is DD oriented.
ineedyourdiddly
Old 03-01-2017, 12:49 AM   #41
Alltezza
Alltezza's Avatar
Alright it finally stopped raining....after it was pouring all day.
I'm not sure what you guys will say to me or think this is dumb as hell but this probably took 10 minutes MAX. I literally just unbolted those 3 damn bolts at the top hat and lifted the car up with and pressed down on the wheel/tire to where I can get the coilover down and basically rotated it. I had to lift the car up a few more times though. I'm not taking that entire thing apart again just to rotate it.....this honestly made the most sense.
Not sure if it will damage the coilover or not but I don't think it will.
Old 03-01-2017, 01:13 AM   #42
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yup. That's all there is to it.
--00 (rev) or redline setting -Willis-86touge Issues | Warranty | Recalls / TSB 29 06-01-2016 04:05 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Setting up for a night Chen Northwest 15 09-20-2013 03:10 AM
This is how I pan on setting my car up where does it put me jdzumwalt Tracking / Autocross / HPDE / Drifting 16 02-10-2013 10:24 PM
