Old 01-17-2017, 06:16 PM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
Meanwhile i hope Eric doesn't take those joint existence mentions as possible extra crash safety point as any bashing of product. Even if it is so, he has no financial/technical means to do crash testing himself, and his CF shaft product is no less safer then that of other one-piece alternatives on market. If many buyers of those decide for themselves that "it's safe enough for them"/"not a serious issue to care about", things are at very least not worse in any way with his product. So if anyone wishes to start witchhunt on of single-peace shafts unsafety, it would be very wrong to single out just one most recently made alternative on market and bash it. Personally i won't buy it, but not because of some safety concerns, but rather due high price, having other mods of higher priority in purchase & install queue prior that, but see it as good product for those that want to do complete as possible car lightening or for those that want more reliable shaft that is stronger for transfering more torque (eg. for forced-induction-ed twins). After all, if people start looking for stronger gearboxes, upgraded gear sets .. shaft might be failure point too.
Old 01-17-2017, 06:21 PM   #30
new2subaru
Weight Weenie
Drives: 15 FR-S
Some info
5.5 SAFETY
Safety is greatly enhanced with composite
shafts. Composites absorb energy upon impact. They can be
designed to, and will normally, break apart during an accident
rather than entering the passenger compartment catapulting the
vehicle, or whipping a broken end through a tank or valuable cargo.
2 shows a broken composite driveshaft. Note
the broken pieces rather than the bent and twisted club that is
usually left with metal. Impact with hard objects like frame
rails will cause a composite shaft to disintegrate and quickly
dissipate energy. A failure in a bond joint would simply result
in a loss of power. The shaft would probably stay in place
with the loose end spinning inside of it.
Above 128 mph the driveshaft gets into a bending
and vibration frequency that would eventually tear it apart.”
They continue that,to eliminate this problem most high
speed European cars usually have a two piece shaft connected through a center bearing.” Carbon fiber driveshafts can alleviate this problem
http://www.acpt.com/resources/documents/sae_1966.pdf
The Following 8 Users Say Thank You to new2subaru For This Useful Post:
churchx (01-17-2017), Hostile_Kittens (01-17-2017), Joveen (11-03-2018), lamawithonel (01-18-2017), MaximeT (01-18-2017), Turdinator (01-18-2017), VerusEric (01-17-2017), wparsons (01-17-2017)
Old 01-17-2017, 06:29 PM   #31
churchx
churchx's Avatar
Drives: 2014 GT86
Thanks. That is fine piece of info, that fends off crash-safety concerns, at least for me. So if someone ever wants to think that uni-piece aftermarket shafts are less crash-safe, that should be attributed only to metallic (IIRC aluminium) ones at most.
Old 01-17-2017, 06:33 PM   #32
new2subaru
Weight Weenie
Drives: 15 FR-S
You're welcome, Church. Science & Engineering...
The Following User Says Thank You to new2subaru For This Useful Post:
Old 01-17-2017, 10:04 PM   #33
wparsons
wparsons's Avatar
Originally Posted by JDM4E View Post
Like this:
In longitudinal direction, in case of o tube or similar - now allow me to simplify - almost everything is relatively strong. Even a piece of paper rolled into a tube is quite strong like that.
That drawing assumes that the joint attachment to the body is the weakest link. The joint isn't floating or free to bend without the bearing block separating from the body.
As for the tube, that assumes the material is strong in that direction. Carbon driveshafts have the fibers oriented to be strong with rotational forces at the sacrifice of longitudinal forces since they'll never see any force like that in a useful scenario.
flickr
Old 01-18-2017, 01:41 AM   #34
Falcon
Drives: WRB BRZ
To which RPM will you test/balance your CF-Driveshaft?
If i do not have miscalculated, it will spin with nearly 9250RPM when i would be going 155mph.
Vibrations are a real concern for me.
Falcon is offline   Reply With Quote
Old 01-18-2017, 10:40 AM   #35
Tokay444
Touched on in the OP.
For Velox, are there any distinct advantages of this carbon shaft over the existing solutions on the market, aside from your published testing info that is?
Old 01-18-2017, 10:46 AM   #36
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
From the manufacturer, they are guaranteed to 9,000 RPM. However, they say users should have no issues up to 11,000 RPM, but they can't guarantee it.
The major takeaways:
-Doesn't interfere with short shifters
-Extremely high-end materials and manufacturing techniques
-Frequency balanced, which results in a superior balanced shaft
-I believe these may be the lightest on the market
-7075 cold forged ends vs 6061-T6 which is more standard
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
BRZoomTX (01-18-2017), Falcon (01-18-2017), Tokay444 (01-18-2017)
Old 01-18-2017, 12:06 PM   #37
Falcon
Drives: WRB BRZ
Thank you very much for the Information.
Old 01-18-2017, 05:40 PM   #38
cammyT
Drives: 2015 Scion FR-S
So the cf ds is 55% lighter than OEM but what is the diameter compared to OEM? Seems higher wich may in fact negate the weight savings.
cammyT is offline   Reply With Quote
Old 01-21-2017, 04:02 PM   #39
will300
will300's Avatar
Drives: Subaru BRZ SE Lux
On the whole crash safety issue, this video show's you what happens with the stock driveshaft during a head on collision, watch from 6:52.
[ame="https://www.youtube.com/watch?v=6LQKqs_IvgQ"]2014 Scion FR-S / Subaru BRZ / Toyota GT86 | Frontal Crash Test | CrashNet1 - YouTube[/ame]
My Build Thread - Subaru BRZ with ACE CS400 Header, Rogue Motorsport 2.5" Exhaust (Front Pipe & Catback), Tein Flex A, AP Racing BBK and 949 Racing 6UL Wheels.
will300 is offline   Reply With Quote
The Following 7 Users Say Thank You to will300 For This Useful Post:
JDM4E (01-21-2017), johan (02-15-2017), MaximeT (01-21-2017), new2subaru (01-21-2017), tato.valverde (01-26-2017), Tokay444 (01-22-2017), VerusEric (01-21-2017)
Old 01-21-2017, 04:46 PM   #40
FirstWinter
Drives: Car
Any feedback on fitment with shifters like the CAE Ultra shifter or the IRP shifter? If fitment is okay with short shifters like the Kartboy it should be okay with these shifters as well right?
FirstWinter is offline   Reply With Quote
Old 01-22-2017, 02:04 AM   #41
VerusEric
VerusEric's Avatar
I did the estimated moment of inertia for both stock and the carbon fiber one earlier on in the testing. I estimated that the carbon fiber driveshaft was slightly less than OEM. I can try to dig this up again if you'd like. Realistically, I think the reduced MOI is one of the lesser qualities of this driveshaft, but that is my opinion.
Post #5 has the answer: http://www.ft86club.com/forums/showp...42&postcount=5
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
twag4 (01-22-2017)
Old 01-22-2017, 12:50 PM   #42
twag4
Drives: frs
Ill be ordering soon!
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
VerusEric (01-22-2017)
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 06:21 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
