Old 11-10-2016, 11:47 AM   #29
Originally Posted by ToySub1946 View Post
I have no idea why, with DRLs on, there are no running lights on at the rear of a car. .
Thais has always baffled me! To the extent I once tried to find out what the rationale was. Never really found an authoritive answer on the subject (blogs and forums are not authorities)
Old 11-10-2016, 05:14 PM   #30
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Handbrake drls
Originally Posted by trigun286 View Post
Whenever I pull the ebrake in neutral, I have noticed that the DRLs shut off. The only related mod I have is the DiodeDynamics always on module. I was wondering if this is a normal thing for these cars and if so is there a way to turn it off?
Sent from my Nexus 9 using Tapatalk
You know.. if you remove the center console. When the ebrake is down it sit on a button turning on the drl. If you remove the button or slightly relocate it to the side the ebrake won't sit on it and you can drive without the drl
If you want always on just tape the button down xD
turtlefeeder is offline   Reply With Quote
The Following User Says Thank You to turtlefeeder For This Useful Post:
Tcoat (11-10-2016)
Old 11-10-2016, 06:55 PM   #31
Gunman
Drives: 2019 Mazda Miata RF
I would have wired the rear fog light, as a rear drl, if I could have found a good power source in the rear, ie only on when running. Note, I didn't want to run a wire from the front of the car just for this.
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
Tcoat (11-10-2016)
Handbrake not working. MstrSHAKE Issues | Warranty | Recalls / TSB 44 01-19-2016 11:53 PM
How to keep DRL running even when the handbrake is on?? CX Cosmetic Modification (Interior/Exterior/Lighting) 25 03-08-2015 04:01 PM
WTB: BRZ handbrake cover and handbrake boot w/ red stitching 86tylerfrs Want-To-Buy Requests 4 01-20-2015 04:11 PM
How to tighten handbrake? Ocean-Grown 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2014 12:07 PM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 05:05 AM
