Old 07-05-2016, 05:23 PM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by FR-Sky View Post
My tire pressure was 32 after heat, i figure that would provide more grip since i was going for mountain road..but i guess not..
Not really... ~38 hot is generally about what you want. For spirited street/mountain road, you probably want about 32 cold. For track work, probably more like 28-30 cold. Either way, 38 hot is a good place to be. 32 hot is probably a bit soft, particularly for a more comfort-oriented softer-sidewall "Max Perf" tire like the MPSS.
Lower pressure does not necessarily mean more grip...
The only thing change was some what 7 to 9 clicks from soft on the dampers.
Unless the damper instructions specifically say otherwise, you should adjust by clicks out from full stiff, not clicks in from "full soft". Just don't overtighten once you feel the needle bottom out in the jet. Then count clicks out.
The clicks at the soft end do little/nothing anyway.
FR-Sky (07-05-2016)
Old 07-05-2016, 05:24 PM   #30
wparsons
wparsons's Avatar
UPDATE: I did a few hard corner on the street. 30mph for regular right turn.
10 clicks from soft front, 13 clicks from soft rear.
tires pressure 35.
The handling for the front to enter a corner is great, but my REAR is losing grip and the slippery light on my display is blinking for those corner.
What are your hands and feet doing when the rear is losing grip? Is it losing grip with no gas or brake added, or are you on the gas when it loses grip?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
D_Thissen (07-06-2016)
Old 07-05-2016, 05:30 PM   #31
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Since i was testing with about 30mph, i keep it 3 rd gear,
let go of the gas before enter corner,
give it little gas during cornering, and gas exit corner. <--this is where it losing grip. It does the samething when i coast through the corner too. Then the throttle kick in and the slippery light is blinking.
FR-Sky is offline   Reply With Quote
Old 07-05-2016, 11:18 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
Having experienced MPSS abject lack of grip once they have gone off, I'm more and more thinking it's your tires...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
FR-Sky (07-06-2016), wparsons (07-06-2016)
Old 07-06-2016, 01:18 AM   #33
FR-Sky
FR-Sky's Avatar
Are u serious....i just got the tires like 4 months ago brand new...
Old 07-06-2016, 08:21 AM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
I am serious. Mine had lost a noticeable amount of grip in less than a year, and after 18 mo they were downright diabolical, dangerous even.
Look at the date stamp on your tires. You bought them 4 months ago, but they could be several years old.
Old 07-06-2016, 01:52 PM   #35
renfield90
The Stig's German cousin
How much track experience do you have with this car or with other RWD platforms?
Old 07-06-2016, 02:05 PM   #36
swarb
Driver needs upgrading. Go to a track day or hpde.
Traction control needs to be turned off. It's not well designed and turns off at any sign of slip, it is made for safety not for sport.
Adjust the adjustable shocks.
8k/8k too stiff for the mpss street tires.
Old 07-06-2016, 02:48 PM   #37
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I would experiment with the settings at full soft and full stiff.
Then you will be able to recognize the effects that the settings have.
Imagine a challenge where you have a friend set them at one extreme or the other and you try to determine which settings he put you at by driving.
Once you can recognize the difference THEN you will be able to tell if you need more or less stiffness.
And the shocks will not be able to stop body roll in a slow sweeping turn, that's what the sway bars are for.
The shocks will only affect body roll in very abrupt "twitchy" fast turns.
justatroll is offline   Reply With Quote
Old 07-06-2016, 04:19 PM   #38
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Originally Posted by Icecreamtruk View Post
Exactly my experience with the MPSS. I think they get toasted by the heat. Mine go from cold (very little grip) to greasy (even less grip) in a single lap. Needless to say I dont run them anymore on track (still my street tire, around 60% thread left).
So what is the next logical step up from the MPSS? Is there anything in the Max performance summer cagetory that is rock solid with decent tread wear?
Im looking to replace my brand new Ventus v12s and was considering MPSS, potenza RE11s or a new set of Primacies to be safe.
Sent from my SM-G920V using Tapatalk
Spacemane969 is offline   Reply With Quote
Old 07-06-2016, 04:50 PM   #39
Icecreamtruk
Drives: Track preped NA FRS
The v12s should be similar to the MPSS, so not really a step yup. Most tires in the tw200 category would grip more than the MPSS, but would wear quicker, much quicker. The RE11 is such a tire, much more grip, at the expense of more wear as well.
If wear is your main concern, the MPSS are really good in that department, the question you need to ask yourself is, would I need a tire replacement because I want more grip or because my tires are worn down? Your case seems to be that the grip has left the MPSS before the thread is over, so a 200TW tire would probably be better. There is plenty of choice there, rivals, RE11s, RS3s and all sort of goodies. You might even look into the Maxxis Victra, apparently they could last quite a while compared to other tires in the category, or maybe even the Nittos NT05.
Old 07-06-2016, 04:50 PM   #40
FR-Sky
FR-Sky's Avatar
I heard alot good reviews thats why i was going for it....
The number is 0716 so i guess its fine.
Old 07-06-2016, 04:52 PM   #41
FR-Sky
FR-Sky's Avatar
0 track experience,,mostly mountain road. This is my first RWD car.
Old 07-06-2016, 04:58 PM   #42
FR-Sky
FR-Sky's Avatar
I am surprise my damper actually have 24 adjustable clicks. I have tried stiffer damper around 15-20 clicks. It gives me better steering to wheel response. I have no problem entering corners now, and it feels right, but the problem i have now is the rear will slip. If i turn off traction control, i think the car might over steer, and its quite danger for mountain road.
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 07:40 AM
FRS VS BRZ Damper (strut) kilohercas FR-S / BRZ vs.... 1 09-24-2015 03:19 AM
Koni Sport Shock Question FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-12-2013 01:43 PM
Hood Shock Carbon Fiber Damper Set? Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 24 08-10-2012 02:31 AM
GReddy releasing carbon fiber hood damper/shock set! Deebeaux Cosmetic Modification (Interior/Exterior/Lighting) 13 08-04-2012 05:22 PM
