Old 04-06-2016, 10:29 AM   #4145
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Originally Posted by LenA View Post
Question on front bar for BRZ. Do folks use a stiffer bar to counter the soft springs and use front camber and rebound settings to dial out the understeer the bar added? Or is there other reason for using stiffer bar up front.
Most searches I've done don't talk about rationale for stiffer front bar
Thanks
Len
In Solo/autocross all the time is made up in slaloms (in my opinion anyway), and fast transitions. A larger front bar allows you attack slaloms with more confidence (and less overseer) all without killing your sweeper performance.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 04-09-2016, 05:26 PM   #4146
bslate3
Drives: 2015 CWP BRZ
Like they said stiffer front bar is better in slaloms and transitions. I run a higher rear rebound setting and also front wheel spacers with extended studs(within the rules) on my BRZ to offset the factory understeer. Seems to work pretty well on most courses.
bslate3 is offline   Reply With Quote
Old 04-11-2016, 12:33 PM   #4147
SeanRTR
C-Street AutoX
SeanRTR's Avatar
So results are in from El Toro, and ND Miata's cleaned house, taking the top three spots...first time I've seen a car win a national event in C-Street BFG, probably since I won in Peru in 2014 on version 1 Rivals at the match tour. Although spots 1-9 are all within about 1 second per course, longer course for a Pro standard too, (40 seconds in CS).
Who was there? What happened? Are ND's the new God's Chariot?
What the hell is up with the 60 ft times....I'm showing as low as a 1.8 60' time on the Turbo MR2...is what accurate? Looks like the best 60' for an FR-S was about a 2.4ish, and ND's coming in around low 2.2's, so still much better than the twins, but maybe not quite as good as the NC's at launch?
Any video, and did the course put you on the rev limiter in second gear?
http://sololive.scca.com/CS.html
Old 04-11-2016, 01:12 PM   #4148
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Based on what I've seen from the ND Miatas so far at two rather large courses, the ND may just be God's new chariot
Old 04-11-2016, 01:48 PM   #4149
simpleisbest
Senior Citizen
Drives: Scion FR-S
I think my car had the time in it to be in contention. Had some setting shock setting issues that killed my morning runs, as I spent them dialing in the car and took me a while to get back in the saddle.
The staging area was tricky, as there was a slight incline. More than a handful of competitors red lighted due to rolling out of the staging lights just before launch.
This was the first event for me with the LED style lights...while it took a couple of practice starts, I got used to it (actually cut a .500 reaction time on Sat! LOL). Many did not like the LED lights and I feel there was a lot more RLs than normal.
We had a few mid day showers, so PAX for the event will be off for sure. Not sure if solely due to the rain or the SCCA's new timing system, but there were an insane amount of timing issues and manual starts. Re-runs for people caught who got caught in some of the maddness were almost meaningless, as they would be sitting in grid so long that any heat from their previous runs were long gone and had to go out on bone cold tires.
The course was very off-set transitional heavy. While I think the car does approach those type of elements pretty well, I think there were spots where the spacing and speed may have been slightly more beneficial to the ND with its torque. There were about 2-3 spots where I would hit revlimit on my faster runs...possibly some spots where the RX-8 may have had some advantages.
simpleisbest is offline   Reply With Quote
Old 04-11-2016, 03:05 PM   #4150
xwd
Miatas launch pretty well. MR2s and MR-S have always launched great, even the ES MR-S. I think the BRZ has the wrong combination of poor weight distribution, more power, and short gearing that makes it hard to launch really well.
Old 04-11-2016, 06:57 PM   #4151
Jawnathin
Drives: Toyobaru FRZ
The weather at El Toro this past weekend makes interpreting the results pretty tricky. Unfortunately AS, BS, and CS got rained on just as we were starting our 2nd Heat on Saturday. So depending on whether you were driving first or second, you'd either have a wet course or dry course. It was a quick enough shower to make it wet and slippery but not soaked. You ended up with a course that was dry during the next group when the 2nd drivers got their runs.
That same thing happened on Heat 3 on Sunday as it had rained overnight. So whoever drove 2nd was with the next group and the dryer course. Besides Heat 1 some people didn't really get any dry runs during Heat 2 or 3. Launching the car in the wet is tricky
The course was a bit heavy on the transitions, I think our cars turn in much better but the NDs are narrower so it is hard to say if there was any advantage or disadvantage to either car. Anyway, yes the ND is very quick and those guys drove really well but it doesn't look unbeatable. Sean's co-driver was just two tenths off the winning ND's time for the left side and he drove that course when it was damp.
And yeah that MR2 launches very quickly off the line. It does kind of sucks losing over half a second just in the first 60 feet.
Jawnathin is offline   Reply With Quote
Old 04-18-2016, 02:09 PM   #4152
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Did you guys notice a big difference in your cars going from OEM to aftermarket drop-in filter?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 04-18-2016, 02:26 PM   #4153
qoncept
qoncept's Avatar
Nothing
qoncept is offline   Reply With Quote
Old 04-18-2016, 04:08 PM   #4154
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
No, but it makes more intake noise, which I can't really explain. This reminds me, I should check it and see if I need a new one, it's been two years since I installed it...
Old 04-18-2016, 04:40 PM   #4155
TMF
TMF's Avatar
Drives: '14 FRS TT5
Maybe...ever so slightly. A hair more noise too, most likely because there is less filter media.
But in the world of autox, every last tenth counts. The filters are relatively cheap and have arguably dyno-proven HP increases: http://www.ft86club.com/forums/showthread.php?t=13245
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 04-18-2016, 05:05 PM   #4156
renfield90
The Stig's German cousin
No, but it can only help. The factory paper filter is fairly restrictive.
Old 04-20-2016, 11:54 AM   #4157
ryan t
Drives: frs
so am i still the only one out there on kumho v720?
ryan t is offline   Reply With Quote
Old 04-20-2016, 01:30 PM   #4158
Biggins
Drives: Yes
I do not know of anyone else. However, I will be on them this Sunday! I went with 225/45/17 with no heat cycling and no shaving. Any chance you'd like to share pressures/thoughts?
I have two multi-time national champs in an ND locally this year and some very fast STX cars, so I'll have very good benchmarks. I'm going to run my Bridgestones Saturday and try the Kumhos Sunday.
Biggins is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
