Old 04-01-2014, 05:43 PM   #4117
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by Carlitoz3 View Post
Another quick question.
What will make my go by smoother?
Putting on the headers or op/fp first?
Thanks.
I would pull the header then jack the engine up on passenger side (or pull the heat shields off the op and remove the dipstick tube) and remove fp/op as a unit. Sneak the new fpop into place but just hang it from the midpipe and keep it as far back as you can. Then header torqued to heads then just start the mid mount bolts of the fpop followed by Op/header then fpop/mid. If that makes sense. Get everything dialed in from front to back basically.
Be sure you disconnected the o2 wires before you start and be sure to install the plug where the elbow resonator was and move the fan connector before you start reinstalling.
I may be wrong but that's how I'd do both at once.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-01-2014, 09:37 PM   #4118
LPC_FRS
LPC_FRS's Avatar
Drives: Scion FRS
http://www.grimmspeed.com/grimmspeed-super-loop-header/
gonna get this tuned tonight ill post dyno runs later
LPC_FRS is offline   Reply With Quote
Old 04-02-2014, 12:32 AM   #4119
sato
sato's Avatar
Drives: Dodge Patitas
So want that!
Sent from my C6906 using Tapatalk
Old 04-02-2014, 09:38 AM   #4120
w00t692
Drives: 2008 Civic Si
Originally Posted by dwx View Post
Ugh you should never have to use something like RTV...
I would agree this motor seems to have a lot of header fitment issues but that's soley on the people producing the headers... The P&L header I have needed to have the part that connects to the overpipe modified because it would cause the overpipe to hit the frame. They replaced or modified everyone's pipes and now no issues. The flanges on my P&L are perfect though, I could probably torque them to 5ft-lbs and they wouldn't leak.
for 10 minutes until the bolts fell out.
w00t692 is offline   Reply With Quote
Old 04-02-2014, 11:05 AM   #4121
Sargy
Long Distance Driver
Sargy's Avatar
Originally Posted by toeout View Post
So what gaskets did you use?
New OEM Gaskets
Sargy is offline   Reply With Quote
Old 04-02-2014, 03:21 PM   #4122
toeout
How many people with the header/OP leak are using the OE overpipe? I have the OE overpipe and I really think that's the problem. I looked at the imprints that the flanges left on the gasket and there is maybe 1-2 mm of overlap between the 3" header outlet flange and the 2.125" factory overpipe inlet flange. OE overpipe is too small to create a good seal.
Having an aftermarket 2.5" overpipe would make it a non-issue, except they cost an arm and a leg.
toeout is offline   Reply With Quote
Old 04-02-2014, 03:24 PM   #4123
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
If I'm not mistaken i think @raul has a different over pipe and is having the same situation.
yomny is offline   Reply With Quote
Old 04-02-2014, 03:30 PM   #4124
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Header to Nameless 2.5" FP/OP connection is leaking for me. Cause seems to be a warped header flange. Nameless recommended using a 3" and a 2.5" gasket together to seal it, so I ordered the Grimmspeed gaskets because I couldn't find correct sizes locally.
raul is offline   Reply With Quote
Old 04-02-2014, 03:30 PM   #4125
toeout
Well ideally you want to have a 3" inlet on the overpipe too, to heave the most flange material to overlap. 2.5" is not ideal, but better than the OE.
I was thinking of having a local muffler shop fab a overpipe with a 3" inlet and reducer to 2.25" and have flex section also added for a good measure.
Old 04-02-2014, 03:32 PM   #4126
toeout
Originally Posted by raul View Post
Header to Nameless 2.5 FP/OP connection is leaking for me. Cause seems to be a warped header flange. Nameless recommended using a 3" and a 2.5" gasket together to seal it, so I ordered the Grimmspeed gaskets because I couldn't find correct sizes locally.
Yeah I have the same "hungry mouth" going on in the middle. Spews water at the start.
Old 04-02-2014, 03:33 PM   #4127
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I had a similar observation on a 2.5" overpipe when I was troubleshooting a leak, still not a lot of overlap there to make a good seal.
Decay107 is offline   Reply With Quote
Old 04-02-2014, 03:48 PM   #4128
yomny
yomny's Avatar
Sounds like the double gasket trick will do it.. Sucks though that even with their own OP/FP it leaks.
Old 04-02-2014, 05:19 PM   #4129
raul
Lap time enthusiast
raul's Avatar
Yep, but if the problem is the flange on the header, it'll leak regardless of the Overpipe you have.
Old 04-02-2014, 05:52 PM   #4130
xjohnx
Grip>Slip
xjohnx's Avatar
i think it's more an issue of the 2.5" overpipe trying to mate up to the 3" header collector. if they weren't so expensive i'd consider upgrading to a 3" overpipe/downpipe.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
