Old 03-19-2014, 11:29 AM   #4005
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I've never seen one in person so I wasn't sure 100% what the flaw is with the plates not working. I don't see how it could be placed anywhere besides a runner. Would still be more accurate than in the intake pre blower. @Kodename47 do you have any pics of how the manifold was modified? Which part was "drilled"?
Dustin is offline   Reply With Quote
Old 03-19-2014, 11:51 AM   #4006
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm afraid I don't. It's was just a larger hole to fit the sensor through, the sensor was too large to fit without drilling and it puts it into the path of air..
I've no concerns with its location, I'm not sure what issues could arise from that?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-19-2014, 11:58 AM   #4007
Dustin
Twin Screw You
Dustin's Avatar
Okay, so the overall OD of the hole the plate covers was made larger? Sorry not trying to have you repeat yourself. I'm just more of a usual person. I don't see any issues with its location either. Also, do you know where someone could buy that sensor?
Old 03-19-2014, 12:03 PM   #4008
Kodename47
Kodename47's Avatar
Drives: UK GT86
No. The MAP plate and hole is the same size as the normal kit. It's the area under where the sensor sits that has been cut away. It's just enough for the IAT sensor to enter the runners.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-19-2014, 12:07 PM   #4009
Dustin
Twin Screw You
Dustin's Avatar
Okay, now I got it. Sorry for not understanding at first. Thanks for the info. Looking forward to see how this works for you.
Old 03-19-2014, 12:51 PM   #4010
sw20kosh
Drives: 2013 Black FR-S
That is great that Abbey was able to engineer a IAT sensor that works. The FA20club IAT sensor plate failed horribly as the sensor was reading the temp of the plate and not the air...
As long as your IAT sensor being in the direct airflow of only one runner does not cause too much airflow difference in that runner it should be perfect. I guess as long as the car is tuned afterwards it should be fine.
Old 03-19-2014, 01:27 PM   #4011
Calum
That Guy
Drives: 2013 asphalt FRS MT
As long as the sensor is temperature only it wouldn't make a difference. But if the sensor is in a runner and it's picking up pressure it's going to see pressure waves from the acoustics of the air moving.
Old 03-19-2014, 03:01 PM   #4012
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I believe that is why the aftermarket MAP sensors are having a problem. Like moto mike said it is harmonizing with the intake valves opening and causing problems. I took a look at the stock manifold yesterday and even though the sensor sits in about the same location there is a channel on the inside of the manifold which puts the inlet for the sensor near the middle of the manifold close to the throttle body.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 03-19-2014, 03:18 PM   #4013
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Perhaps a phenolic plate might work better, not conducting as much heat, and be cheaper to produce. Also, diagonal placement of the sensor holes may allow for more room and use of the stock opening.
Old 03-19-2014, 03:40 PM   #4014
Kodename47
Kodename47's Avatar
Drives: UK GT86
The hole isn't deep enough for the type of sensor used. Might I add that in my setup I use 2 sensors on the plate, IAT and MAP are separate.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-20-2014, 11:26 PM   #4015
NickFRS
Drives: 2013 Asphalt FRS
Hey guys is anyone running the non intercooled kit with E85 and a 70mm pulley? I'm almost thinking about doing this very soon. Think it would be okay? Only person I know running that set up also has meth... which is @evan and his insane car... Wondering if it would be to hard on the blower even with E85's cooling.
(also would it be possible to keep the fuel system stock)
@DeliciousTuning and @moto-mike what are your thoughts?
I would only be doing a couple 1/4 mile runs and maybe a track day or two. If I did a track day they wouldn't be competition or back to back runs.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-21-2014, 03:01 AM   #4016
Powersfrs
Drives: Frs
I will be! ima install it Saturday
Powersfrs is offline   Reply With Quote
Old 03-21-2014, 08:40 AM   #4017
xxscaxx
Drives: 2013 SWP BRZ
You should be fine - I know Mike ran his car this way for a bit before the intercooler swap.
Delicious Tuning uses stock injectors, I can't recall if he uses the stock pump too at that level. Mike is a fan of DW injectors and a fuel pump setup, unless that has changed as of recent. I still think he can do it without the injectors though.
xxscaxx is offline   Reply With Quote
Old 03-21-2014, 08:45 AM   #4018
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I know for the 75 with e85 mike can tune for stock fuel setup (its my config at the moment)
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
Xero-Limit (03-21-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
