Old 07-13-2014, 07:55 PM   #365
choi0706
Drives: t
do you have a US part number for this?
Originally Posted by fstlane View Post
Thanks for the awesome DIY op. I installed mine today and everything went smoothly following your guide.
I went a different route on the manifold fitting as I found an oem Mercedes fitting the worked perfect.
http://www.ebay.com/itm/110860307014
Thanks again!
choi0706 is offline   Reply With Quote
Old 07-13-2014, 08:17 PM   #366
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Damn that merc part is perfect!!! Exactly what I tried to find to no avail.
Part number please!!!
Kostamojen is offline   Reply With Quote
Old 07-13-2014, 09:08 PM   #367
fstlane
fstlane's Avatar
Drives: BRZ Limited
I ordered it through the eBay link above and it noted the oem part number is 1032000108. I never bothered checking at a dealership as I wasn't in a rush to get it. It ended up costing $15.36 including shipping from the UK and took a little over a week to receive. It's was less expensive than the two fittings listed in the original post and cleaner install in my opinion.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
Sargy (04-06-2015)
Old 08-08-2014, 12:23 PM   #368
sickmint79
Drives: bmw
would this work?
http://www.ebay.com/itm/14mm-x-1-5-W...p2054897.l4275
i hit buy on this, which i assume is where you got yours, however the seller has been 100% unresponsive
http://www.ebay.com/itm/Mercedes-Hos...item19cfca0a46
or how about http://www.rapidhosesystems.com/inde...e/fuel-systems
M14 x 1.5 to 1/2"
AF746-03 AF746-03BLK AF746-03S (blue/black/silver part #s)
http://www.tuspeed.com/aeroflow-metr...rb-p-5670.html
why is this such a pain...
sickmint79 is offline   Reply With Quote
Old 08-21-2014, 01:24 PM   #369
STS-V
So the general consensus is this isnt as good, or better, than the perrin oil cooler or kate oil cooler for turbo applications?
STS-V is offline   Reply With Quote
Old 08-21-2014, 02:04 PM   #370
sickmint79
Drives: bmw
it seems to be that it is not good enough for fi.
i am curious as to turbo on/off track temp data and sc on/off track data. i plan to eventually get the innovate, upgrade the radiator, and see what i observe on track before upgrading to the regular air oil coolers.
Old 09-14-2014, 01:02 PM   #371
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
I was going to do this project over the weekend but underestimated the difficulty of finding a metric barb fitting... definitely not something you can pick up at Home Depot Racing or Lowe's Speedshoppe. Shoulda read the thread more closely apparently this is a common struggle.
On that note, I was wondering, what does the Forrester use? Is there not a Subaru part that we can use?
I ordered this:
[ame="http://www.amazon.com/gp/product/B00KHTORTO/ref=ox_ya_os_product_refresh_T1"]5 Pcs Brass Hose Barb to M14x1.5 Male Thread Mold Water Coupling: Amazon.com: Industrial & Scientific[/ame]
I'll update if it works... if so I'll have 4 extra pieces for anyone that needs one hah
UPDATE 9/25: the barb on amazon absolutely does not fit haha
TheBatman is offline   Reply With Quote
Old 09-14-2014, 02:44 PM   #372
CARNZ
CHECK ENGINE
Drives: 2004 STi
I ordered this:
The Forester uses a different upper oil pan(lower block) that has a fitting built in
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 09-14-2014, 03:01 PM   #373
TheBatman
TheBatman's Avatar
Ah I see so really to do this mod properly you've gotta swap the lower engine block. No biggie. Hahah
Old 09-14-2014, 03:26 PM   #374
acx23
Drives: 2013 FRS (Silver)
Once the coolant is warmed up, it's around 190*f. And it'll get hotter when driven. That's the temperature that has to bring the oil temp down. On the other hand, air cooled oil cooler (ie Perrin) has a way lower temperature coming into the oil cooler to cool down the oil.
Feel free to do the math.
(PS - I know some people who are boosted has oil cooling issues with water cooling oil coolers.)
acx23 is offline   Reply With Quote
Old 09-14-2014, 04:24 PM   #375
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!)
Good info:
-Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
http://www.ft86club.com/forums/showthread.php?t=72961
You can get this for < $200
http://www.ft86club.com/forums/showp...6&postcount=40
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 09-16-2014, 12:45 AM   #376
TheBatman
TheBatman's Avatar
Been thinking again... If that plug is used for the trans coolers in AT cars, then wouldn't there be a fitting that we could buy for the oil cooler??
Old 09-16-2014, 09:19 AM   #377
s2d4
s2d4's Avatar
Originally Posted by TIE Pilot View Post
Good info:
lol, on ebay already.
http://www.ebay.com.au/itm/OIL-COOLE...3d26958&_uhb=1
Old 09-16-2014, 06:06 PM   #378
CARNZ
CHECK ENGINE
Drives: 2004 STi
The AT upper oil pan is different and has that fitting molded into it. They didn't want to make it super easy...
I had originally considered buying the different upper pan/lower block, but decided it wasn't worth the money vs just installing a fitting.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
