Old 09-24-2013, 12:59 PM   #365
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Originally Posted by Signature Products View Post
I think the egt must be read thru the oxygen sensor. I only have my gauge hooked up to the obd port and mine works as it should. Is your afr reading ok?
Refer to post #356. The first pic is a video. I cycle thru each sensor and they all display correctly. Including egt.
Yes i saw your video and the reading is around 200+ for EGT, that's why I'm lost.
There is a reading for my AFR. Only the EGT showing 0.
Anyidea how do i get it to work ? or there is something wrong with my gauge ?
[ame]http://youtu.be/YOmleetrnvw[/ame]
Sookainian is offline
Old 09-24-2013, 01:11 PM   #366
nelsmar
Has anyone found a way to disable un-used items like battery voltage and 0-60?
My flickr - Canibeat
Local magazine scout
nelsmar is offline
Old 09-24-2013, 01:50 PM   #367
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ecko04 View Post
Correct, it adjusts based on the oxygen sensor.
So the gauge is "calculating" EGT from the OEM oxygen sensor.
King Tut is offline
Old 09-24-2013, 07:51 PM   #368
Dan@AWD
Drives: 2013 Argento FR-S
Anyone have instructions fire wiring the dimmer?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline
Old 09-24-2013, 07:57 PM   #369
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I didn't get a chance to tidy up my install but essentially the wire I labeled as the positive (+) trigger parking lights is where you want to tap into (i.e. military splice) with the green wire from the P3Cars gauge.
Once done, go into the gauge configuration settings and change the dimmer setting to "On.A" then hold the right button to save the option (you gauge will then reset).
Now when you turn on the lights, or your lights come on automatically, the gauge will dim.
Bright
Dim
Video showing the transition between bright and dim
View P3Cars Gauge Video
Sent from my HTC6500LVW using Tapatalk 4
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline
The Following 4 Users Say Thank You to ecko04 For This Useful Post:
ATL BRZ (09-26-2013), frsvr4 (12-01-2014), Signature Products (09-24-2013), TemeCal (09-24-2013)
Old 09-24-2013, 08:33 PM   #370
Signature Products
Signature Products's Avatar
Everyone should be hitting the thank you button for this. I have been waiting since I bought the gauge for them to answer on how to do that. Maybe this can be put in the how to section or at least at the beginning of this thread
Signature Products is offline
The Following User Says Thank You to Signature Products For This Useful Post:
ecko04 (09-25-2013)
Old 09-24-2013, 08:44 PM   #371
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Anyone with the p3car gauge can advise me why my gauge is not getting any reading for EGT ? (Exhaust Gas Temp)
Thank you alot
Old 09-24-2013, 09:21 PM   #372
Dan@AWD
Bright
Dim
Is that the kick panel?
Dan@AWD is offline
Old 09-24-2013, 09:21 PM   #373
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Is there an owners manual link?
448hpsti is offline
Old 09-25-2013, 08:19 AM   #374
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Can anyone please advise how come i'm getting 1900+ EGT reading ?
This morning the reading was 0.
Is there something wrong with the gauge or my car ?
[ame="http://www.youtube.com/watch?v=IL6ow0NjXoY&feature=share&list=UUTZ6o535po yxBRxgQlQGcow"]P3Car gauge EGT 1000 - YouTube[/ame]
Old 09-25-2013, 08:27 AM   #375
xjohnx
Grip>Slip
xjohnx's Avatar
I wouldn't put much faith in an estimated EGT figure. If EGT's are something that you need, i'd get a bung welded on and add it to one of the 0-5V aux inputs on the P3.
xjohnx is offline
Old 09-25-2013, 08:30 AM   #376
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
True. But i just want to make sure my gauge is working normally. Coz the value should not be 0 for the last 2 days and suddenly 1913 today
Because if it's "spoiled" i would like to get it replace after spending almost $400 on it
Old 09-25-2013, 09:10 AM   #377
Foobar
SLO NO MO
Foobar's Avatar
Mine also shows numbers that high. I don't think it's ever been 0 for me.
http://p3cars.com/frz-install/
Foobar is offline
Old 09-25-2013, 11:40 AM   #378
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As I have told you multiple times now, I would not judge whether the gauge is "working" or not based on the EGT. As long as your AFR, IATs, coolant temp, and oil temps look right, then the gauge is working properly. All it is doing is reading inputs from the OBD-II port.
King Tut is offline
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 06:47 PM
iPodŽ/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 12:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) -- General Topics 40 08-19-2012 04:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) -- General Topics 17 12-12-2011 11:39 AM
