Old 08-07-2014, 08:04 PM   #351
steve99
Originally Posted by DC2R View Post
Sorry if obvious but this doesn't affect B01C tunes right?
Sent from my SM-N900T using Tapatalk
the V2.03 tunes are now based on the latest D00C ROMs for USA/canada the earlier V2.0X were based on B01C ROM's i believe.
Old 08-07-2014, 10:00 PM   #352
DC2R
Drives: 2014 Scion FR-S
Any point in reflashing?
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 08-07-2014, 10:05 PM   #353
steve99
I don't think anyone has looked into the ROM logic AFAIK and shiv did not mention any changes to defined tables. But if you want the latest ROM D00 revision flash away. The toyota/subaru guys are probably just updating ROM for idle stability with A/con or something but that just a guess
Old 08-07-2014, 10:11 PM   #354
Wepeel
Drives: '13 BRZ Ltd
Really dumb question - my ECU was A01C. I'm assuming I should load the corresponding A01c file to my OFT... correct? There's no benefit to loading a more recent cal (if this is even possible)?
EDIT nevermind the answer was right at the top of the page
Wepeel is offline   Reply With Quote
Old 08-07-2014, 10:48 PM   #355
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Are you sure? that's not what the update says....
8/05/14
v2.03b
-Revised ZA1D00C XML that fixes minor definition errors.
-Revised Stage 2 E85 UEL D00C and Stage 2 E85 EL D00C files with corrected cranking enrichment values
and the earlier:
7/24/14
v2.0b
-Tune map support for only USDM ROMs
-All ROMs are based on latest factory software (B01C and B01D)
-91oct, 93oct and E85 maps are available.
-New XML files for all USDM ROMs. If you want to edit the OTS map, you MUST use the supplied beta XMLs. Delete the old XML file from your ROM Raider folder as they are not longer applicable.
All I see is that 7/24/14 says that the new roms from 2.0b is based on factor B01C and B01D
The newest update 2.03 only revises ZA1D00C XML, which shows true since all the other roms are the same and contains the same date as 7/24/14
CamryDS is offline   Reply With Quote
Old 08-07-2014, 11:36 PM   #356
steve99
8/05/14
v2.03b
and the earlier:
7/24/14
v2.0b
The newest update 2.03 revised ZA1D00C XML, which shows true since all the other roms are the same and contains the same date as 7/24/14
If they are supplying a ZA1D00C/D xml files in v2.03 then the roms will be based on that ie D00C/D as the definition/structure is different from the B01C/D based ROM
The revision to the D00 xml files was because of a definition errors for some of the tables.
I think 2.02 was the initial D00 based ROM release superseded when the XML file was corrected.and release 2.03
You need to be careful which definitions you use to edit ROM if you have copy's of the 2.00 or 2.01 use the defs that come with the ROM zip file else nasty things will happen = car no starty ECU = no respondy = you not happy
from your post
7/24/14
v2.0b
v2.03b
The 2.03 versions are D00C/D based D00 defs will not work with B01C/D ROM,s and vice versa.
Old 08-08-2014, 12:01 AM   #357
CamryDS
from your post
7/24/14
v2.0b
v2.03b
For people who just flash, this won't apply then, happy editing.
Old 08-08-2014, 01:22 AM   #358
Knickstape
Knickstape's Avatar
Drives: '13 FR-S (Asphalt)
So I don't have a header yet. Do you guys think its still worth getting the oft? Anyone come from a unichip to this? That's what I'd be switching from
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
Knickstape is offline   Reply With Quote
Old 08-08-2014, 01:40 AM   #359
PantsDants
Drives: Scion FR-S A/T, Whiteout
I did exactly that, and yes, it's worth it even for stage 1. The off-the-shelf tunes are better, you can modify tunes to your liking, and you can data log to keep tabs on what your engine is doing. Plus you get a discount on their header if you decide to go that route eventually.
PantsDants is offline   Reply With Quote
Old 08-08-2014, 02:12 AM   #360
Knickstape
Knickstape's Avatar
That's sounds great to me! Now to sell the unichip! I appreciate the reply man
Old 08-08-2014, 02:20 AM   #361
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Is the high rev cold start dialed back some with these latest maps? Or do we still need to modify those values with Romraider? It's slightly complicated looking, but I'm more lazy than anything.
Can we just get UEL/EL maps with the cold start ignition retard disabled? If I had to guess, I'd think there are fewer catted setups out there than catless.
I agree. I don't have a header - only a catback. The OFT was my first engine/exhaust mod.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 08-08-2014, 04:27 AM   #362
8686
8686's Avatar
Drives: 86
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Dow...
Dear @Shiv@Openflash
when you think the 700K seriers 2.0 maps will be available?
Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-08-2014, 04:36 AM   #363
troek
troek's Avatar
Drives: 2012 Toyota 86
I dont think its incorporated, but if you need help let me know.
Old 08-08-2014, 07:27 AM   #364
DC2R
Any benefit coming from 2.01 stage 2?uel
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
