#351 |
Drives: FT86
#352 |
Drives: 2014 Scion FR-S
#353 |
Drives: FT86
I don't think anyone has looked into the ROM logic AFAIK and shiv did not mention any changes to defined tables. But if you want the latest ROM D00 revision flash away. The toyota/subaru guys are probably just updating ROM for idle stability with A/con or something but that just a guess |
#354 |
Drives: '13 BRZ Ltd
Really dumb question - my ECU was A01C. I'm assuming I should load the corresponding A01c file to my OFT... correct? There's no benefit to loading a more recent cal (if this is even possible)?
EDIT nevermind the answer was right at the top of the page Last edited by Wepeel; 08-07-2014 at 10:27 PM. |
#355 | |
Drives: 2003 Camry Blue | 2013 FR-S White
8/05/14 v2.03b -Revised ZA1D00C XML that fixes minor definition errors. -Revised Stage 2 E85 UEL D00C and Stage 2 E85 EL D00C files with corrected cranking enrichment values and the earlier: 7/24/14 v2.0b -Tune map support for only USDM ROMs -All ROMs are based on latest factory software (B01C and B01D) -91oct, 93oct and E85 maps are available. -New XML files for all USDM ROMs. If you want to edit the OTS map, you MUST use the supplied beta XMLs. Delete the old XML file from your ROM Raider folder as they are not longer applicable. All I see is that 7/24/14 says that the new roms from 2.0b is based on factor B01C and B01D The newest update 2.03 only revises ZA1D00C XML, which shows true since all the other roms are the same and contains the same date as 7/24/14 |
#356 | |
Drives: FT86
The revision to the D00 xml files was because of a definition errors for some of the tables. I think 2.02 was the initial D00 based ROM release superseded when the XML file was corrected.and release 2.03 You need to be careful which definitions you use to edit ROM if you have copy's of the 2.00 or 2.01 use the defs that come with the ROM zip file else nasty things will happen = car no starty ECU = no respondy = you not happy from your post 7/24/14 v2.0b -Tune map support for only USDM ROMs -All ROMs are based on latest factory software (B01C and B01D) v2.03b -Revised ZA1D00C XML that fixes minor definition errors. -Revised Stage 2 E85 UEL D00C and Stage 2 E85 EL D00C files with corrected cranking enrichment values The 2.03 versions are D00C/D based D00 defs will not work with B01C/D ROM,s and vice versa. |
#357 | |
For people who just flash, this won't apply then, happy editing. |
#358 |
Drives: '13 FR-S (Asphalt)
So I don't have a header yet. Do you guys think its still worth getting the oft? Anyone come from a unichip to this? That's what I'd be switching from
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
#359 |
Drives: Scion FR-S A/T, Whiteout
I did exactly that, and yes, it's worth it even for stage 1. The off-the-shelf tunes are better, you can modify tunes to your liking, and you can data log to keep tabs on what your engine is doing. Plus you get a discount on their header if you decide to go that route eventually.
#360 | |
#361 | ||
aeiou
Drives: WRB BRZ
Is the high rev cold start dialed back some with these latest maps? Or do we still need to modify those values with Romraider? It's slightly complicated looking, but I'm more lazy than anything.
Can we just get UEL/EL maps with the cold start ignition retard disabled? If I had to guess, I'd think there are fewer catted setups out there than catless. Quote:
#362 |
Drives: 86
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Dow...
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#363 |
Drives: 2012 Toyota 86
#364 |
Any benefit coming from 2.01 stage 2?uel
Sent from my SM-N900T using Tapatalk |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
