go_a_way1
Old 03-01-2017, 01:47 AM   #3347
nima314
Drives: Subaru BRZ 2017 (almost)
Originally Posted by choi0706 View Post
what about using coilovers set at OE ride height, what is the widest one could go without rubbing? 949 wheels 17x9 40
Width of rim doesn't matter as much. 245 tyre is biggest to fit on stock suspension. Even with a 9" rim at +38
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 03-01-2017, 02:17 AM   #3348
choi0706
Drives: t
coilovers installed but I don't want to lower the car. only using coilovers for more tire clearance.
choi0706 is offline   Reply With Quote
Old 03-01-2017, 07:33 AM   #3349
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by CatalystPLUR View Post
18x8.5 +38 225/40/18 On Tien Coils will this fit without fender rolling?
This will fit fine, unless you're lowering the car 5858444949" or something ;-)
The issue is less about rubbing inside here, than about the wheel poking out of the Fender with this Setup
17x9 +40 will work, but if on stock hight and no camber it will poke quiet alot in the front, and aswell in the rear.
Here is a shot of 18x8.75 +35 on stock Suspension, with 245 tires http://www.ft86club.com/forums/showp...1&postcount=75
a 17x9 +40 will look about the same (well, another 2mm more inside, but thats hardly noticable)
Killerbee is offline   Reply With Quote
Old 03-01-2017, 07:34 AM   #3350
nima314
As soon as I have a pic of my 18x9.5+38 on stock fenders with less than -1.5 camber on 1" drop ill upload. I have phone ones but waiting for proper photos to be edited. Should be done within 48hrs
Old 03-01-2017, 02:11 PM   #3351
Ketchum88
Ketchum88's Avatar
Drives: 2013 FR-S Hot Lava
255/35/18 on a 18x9 +33 square setup lowered on ST Coilovers with front camber bolts and rear LCAs will I be clear?
Ketchum88 is offline   Reply With Quote
Old 03-01-2017, 08:04 PM   #3352
PhoenixGT86
PhoenixGT86's Avatar
Drives: Firestorm red
Hi guys would It be possible to have these wheels in the rear with rear fender roll work:
Stock body, I have coilovers and LCA.
Wheels size is 18x8 -12 . if so which tires would you recommend me. Thank you for your time.
PhoenixGT86 is offline   Reply With Quote
Old 03-01-2017, 10:25 PM   #3353
Killerbee
Killerbee's Avatar
wow... why would you want those wheels on the twins? What are you planning to run in front?
a 8" -12 Wheel will poke out about 2-3cm in the rear. The math is as follows:
A 9.5" +35 is about flush lowered on the twin (it depends a bit on camber, but for the sake of simplicity, lets go for the "norm"). So 1.5" wheel difference, 50% of it, gives about 20mm. So an 8" +15 (which is +35 from the 9.5" - the 20mm we loose being a 8" wheel) will be about flush. Now you want to make this a -12, so its 15+12 ) 27mm -> This results in the wheel sitting outside your fender 2.7cm (or about a good inch)
Hope this helps
Cheers
The Following User Says Thank You to Killerbee For This Useful Post:
Ketchum88 (03-04-2017)
Old 03-01-2017, 10:30 PM   #3354
Killerbee
Killerbee's Avatar
Originally Posted by Ketchum88 View Post
255/35/18 on a 18x9 +33 square setup lowered on ST Coils with front camber bolts and rear LCAs will I be clear?
ST Coils as in coilovers? If so, this should work. You'll probably need a good amount of camber to keep the tires inside the fenders in the front, but if you have coilovers at least you dont have to mind the stock inner struits
Old 03-02-2017, 11:38 PM   #3355
Dragon780
Drives: Scion FRS
Will this fit
Hi guys,
I just wanted to get some opinions before I do so.
For a stock fsr
Front rim 18x7.5 +38 offset
Tire 225/40r18
Rear rim 18x8.75 + 33 offset
Tire 245/40r18
Would those tire options fit on stock? Not lowered and stock springs
Dragon780 is offline   Reply With Quote
Old 03-02-2017, 11:42 PM   #3356
nima314
Originally Posted by Dragon780 View Post
Hi guys,
For a stock fsr
Tire 225/40r18
Tire 245/40r18
You can fit an 18x9.5" +42 ish on a 245 tyre all round stock.
Old 03-02-2017, 11:51 PM   #3357
nima314
Sorry 18x9" +40 will fit. I wouldn't go any less in terms of width. I regret not going +37/36 on my 18x9.5+38, although I did go 37 in back with LCAs
Old 03-03-2017, 01:19 AM   #3358
Dragon780
Drives: Scion FRS
oh awesome! so if i got all 4 rims being 18x8.75 33 offset with 245/40r18 will be fine?
Old 03-03-2017, 04:05 AM   #3359
Killerbee
Killerbee's Avatar
Be carefull with this. While nima314 is not incorrect, he is missing some vital information.
While you can fit that wide wheels/tires, it will poke when you're on stock suspension. if you're not planning on lowering your car, I would not go for a 8.75 +33 in the front.
I'll link you some pictures of a 18x8.75 +35 Setup with 245 tires so you can see what I mean. Your setup, being a +33, will stick out 2mm more than this
http://www.ft86club.com/forums/showp...4&postcount=98
EDIT:
Also, tires are 245/35/18 not 245/40/18 (unless you want to offset your speedo and "lift" your car because the diameter is to big)
Old 03-03-2017, 04:11 AM   #3360
nima314
EDIT:
Correct, the car should definitely be lowered. At least consider replacing springs with a 1" drop if on a budget.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
