Old 04-02-2017, 11:12 AM   #309
ILLSMOQ
Drives: 2017 WR BLUE BRZ
What are you going to replace it with?
ILLSMOQ is offline   Reply With Quote
Old 04-02-2017, 07:10 PM   #310
Apex-Apex
Apex-Apex's Avatar
I got a dry carbon roof since it'll be easier to weld the cage in with the roof out.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
ILLSMOQ (04-02-2017)
Old 04-14-2017, 08:56 PM   #311
Apex-Apex
Apex-Apex's Avatar
Just got the Dry Carbon roof from MPH Fabrication. It weighs only 3lbs!
IG: @apexapexapex
The Following 3 Users Say Thank You to Apex-Apex For This Useful Post:
Guff (04-17-2017), ILLSMOQ (04-14-2017), jordonallison (04-14-2017)
Old 04-14-2017, 09:25 PM   #312
huh
Drives: Schwin
Any idea what the stock bonnet weighs?
That's probably the biggest weight to be saved on the front end. Will certainly help offset the additional weight for the 2j.
huh is offline   Reply With Quote
Old 04-14-2017, 09:36 PM   #313
Apex-Apex
Apex-Apex's Avatar
Unfortunately this is the roof. I've been trying to shave as much as weight without having the move the radiator to the rear. So far, the front bash bar as shaved some weight, relocating the battery and dropping the 2jz as low and far back by using dry sump. The stock aluminum hood is really light and my seibon hood was probably the same weight, if not heavier.
IG: @apexapexapex
Old 04-14-2017, 09:36 PM   #314
Apex-Apex
Apex-Apex's Avatar
However, compared to stock roof, you shave 10lbs from the highest point of the car.
IG: @apexapexapex
Old 04-14-2017, 09:59 PM   #315
ILLSMOQ
Pretty bad ass roof right there!
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Apex-Apex (04-15-2017)
Old 04-14-2017, 11:10 PM   #316
huh
Drives: Schwin
I read hood.
I might have a drinking problem...
The Following User Says Thank You to huh For This Useful Post:
Old 04-15-2017, 05:42 AM   #317
Apex-Apex
Apex-Apex's Avatar
Thanks! It's super light!
I read hood.
I feel like I'm about to with this build.
IG: @apexapexapex
Old 04-17-2017, 09:37 PM   #318
Apex-Apex
Apex-Apex's Avatar
Decided to get some SPL Solid Subframe Bushings to replace the factory one. Hopefully this and solid diff bushings from Salasko Racing will save my diff!
IG: @apexapexapex
Old 04-17-2017, 11:49 PM   #319
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Goddang, this thread is just amazing! Keep up the parts porn!
Random question: Any particular reason you're running the non-VVTi 12-tooth trigger wheel vs the standard VVTi 36-2 trigger wheel?
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
Apex-Apex (04-18-2017)
Old 04-18-2017, 12:51 AM   #320
Apex-Apex
Apex-Apex's Avatar
Ah, I must have forgotten to edit that. Originally I had intended to do a non VVTI engine so that's why I had the reinforced non VVTI timing wheel. That's also a reason why I can't use my Hypertune valve cover
IG: @apexapexapex
Guff (04-18-2017)
Old 04-20-2017, 12:21 AM   #321
Guff
Guff's Avatar
Drives: BRZ LZR
Gotcha. I'm planning on doing a similar swap "soon-ish" as well, so I'll just live vicariously through your thread for the time being!
by Zaku
Apex-Apex (04-20-2017)
Old 04-20-2017, 05:54 AM   #322
Apex-Apex
Apex-Apex's Avatar
Hope to see more from your build! It's always interesting seeing everyone's perspective when they build things.
IG: @apexapexapex
Guff (04-20-2017)
Toyota GRMN 86 Concept is a Race Inspired FR-S for the Street vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 12 05-07-2016 01:49 PM
Alucard's BRZ Build alucard7755 Member's Car Journals 8 03-08-2016 03:18 PM
MINOCIN's FR-S Build, not because racecar, not because street car... just, because. MINOCIN Member's Car Journals 27 11-09-2015 12:02 AM
Street/Rally Build z3ro Member's Car Journals 3 06-07-2014 07:21 AM
C-Street BRZ 192 Build Info Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-26-2014 11:12 AM
