Sam Strano
Old 06-02-2015, 12:54 PM   #3165
renfield90
The Stig's German cousin
Originally Posted by MTeator View Post
So the potential to spend 5 figures is OK for STX, but if you didn't have the magnets it would be off the table? That's so autocross
Meh. My point is I'm not sticking around if the car can't win, and that means I deploy my time and money somewhere else. It doesn't have to be autocross. I spent the better part of a decade driving a ridiculous underdog car and I'm done with that.
Old 06-02-2015, 04:50 PM   #3166
xwd
Originally Posted by SeanRTR View Post
Keep in mind that Harvey's NC has baller double adjustable Koni's with added compression. Anyone running OEM or single adjustable shocks in the NC has had essentially zero success in CS.
Are they Koni or Penske? I know Chris Fenter is a big Penske fan and had them on his MS-R. He knows how to set them up and re-valve them himself. That car is certainly an anomaly being very well setup and driven by very good drivers. Bump stop tuning is also important on those cars as they have almost no suspension travel...
In the track picture I saw of the ND it looked pretty floppy.
Old 06-02-2015, 05:41 PM   #3167
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
They are Penskes.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 06-02-2015, 05:54 PM   #3168
B T
I'm trying to get setup with some lighter/nice 16"s running a wider track but haven't been able to find much of anything. I saw someone suggest RPF1's but I'm not sure that's within the legal 7mm from stock rules. So do you guys know of a good 16" to run and also do you think a slightly wider track has helped at all.
B T is offline   Reply With Quote
Old 06-02-2015, 06:23 PM   #3169
engee
Drives: Subaru
Originally Posted by Laloosh View Post
I think if the new miata goes to c street then you guys will all have issues. That car is surprisingly quick based on initial magazine tests. 0-60 in the 5s, 1/4 in mid 14s.
We'll see. I don't think they will bury the car but most of the reviews coming out are the club version.
Will definitely be exciting to see what plays out and see your new car Laloosh at the next NNJR event!
Doesn't SCCA has a tendency to put performance models in a higher class. S2k and CR, C5 and C5 Z06, 370z and Nismo 370z?
Also, does anyone have the gear ratios for the new miata? I found the the ones for the japanese 1.5L. If they don't change them for the 2.0L, 2nd gear seems to top out at 56-59mph depending on redline. That sounds troublesome for autox. Maybe that's just me though.
http://forum.miata.net/vb/showthread.php?t=571383
engee is offline   Reply With Quote
Old 06-02-2015, 08:36 PM   #3170
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
2016 Mazda MX-5
gear ratios
Manual
1 5.087
2 2.991
3 2.035
4 1.594
5 1.286
6 1.000
Final 2.866
They do have to shift into 3rd to make it to 60mph but still do it in 5.8-5.9 according to C&D and MT.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 06-02-2015, 09:10 PM   #3171
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Temp tag autox this weekend
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 06-03-2015, 03:10 AM   #3172
markw
Drives: 2014 FR-S
2014 San Diego National Tour was won by an NC on single adjustable Konis, beating Jeff Stuart in his 370Z. So I wouldn't say they're required, but they do help.
markw is offline   Reply With Quote
Old 06-03-2015, 08:46 AM   #3173
engee
Drives: Subaru
Originally Posted by Rampage View Post
2016 Mazda MX-5
gear ratios
Manual
1 5.087
2 2.991
3 2.035
4 1.594
5 1.286
6 1.000
Final 2.866
I think those are the ratios for the 1.5L in Japan as it came out from the Japanese Brochure. Not sure if this will be what it gets in US, but I don't see why not.
While shifting to third is fine for 0-60, I feel that on an autocross course it may be more of a hassle.
Old 06-03-2015, 12:37 PM   #3174
simpleisbest
Senior Citizen
Drives: Scion FR-S
SD lot is just odd. What works for there will not work for anywhere else.
Typically for SD, the softer the suspension the better...think it has to due with the low grip and bumpy surface
simpleisbest is offline   Reply With Quote
Old 06-03-2015, 01:38 PM   #3175
markw
Drives: 2014 FR-S
It's progressing to the point of all courses are the same because of all the breakup. We've patched parts of the lot ourselves. This last weekend we pitted at the top of the lot and the course ran down to the bottom. The whole CS class is chasing Scott Lewis, the only time he's been beat locally was Lugod in your car by .004. My goal this year is to finish really close to him, I took 2nd by .027 at the last event, but he laid down a run 1.8 seconds quicker so the rest of us have work to do. RE71R's should be in this week, may have to hit El Toro on the 21st and try my luck there.
Old 06-03-2015, 01:47 PM   #3176
simpleisbest
Senior Citizen
Drives: Scion FR-S
Haha! Yeah, we were on Dunlops then, too!
Old 06-03-2015, 04:08 PM   #3177
B T
Are we still updating the initial post?
C-Street can now have 16", 17" or 18" wheels and an offset within 7mm of original spec, meaning 41-55mm. Spacers are allowed to bring offset back within spec.
Wheel width must remain the same.
Please update
Old 06-04-2015, 12:44 PM   #3178
simpleisbest
Senior Citizen
Drives: Scion FR-S
SCCA event is 13th/14th
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
