Sam Strano
Old 06-01-2015, 05:10 PM   #3151
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I think if the new miata goes to c street then you guys will all have issues. That car is surprisingly quick based on initial magazine tests. 0-60 in the 5s, 1/4 in mid 14s.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 06-01-2015, 08:12 PM   #3152
Wheeljack
Wheeljack's Avatar
Drives: 2013 WRB BRZ Limited
The other question is, can the new Miata run heads up with an S2000 or non Z06 C5 vette. They can't really make C-Street like F-Street where the bar gets raised every time they make a faster mustang or camero. Otherwise, C Street will start catching B Street on the next redesign of the 86 and Miata. What would open up B-Street to a lot more cars is if they would move the non Z06 vette back to A street. I think GM made less manual transmission Z51s then the number of Lotus Elise exported to the states.
Wheeljack is offline   Reply With Quote
Old 06-01-2015, 08:38 PM   #3153
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
UI don't think they will class it in B street because the c5 and s2000 are going to be faster. They won't bury that car imo. Cstreet is in trouble lol
Old 06-01-2015, 09:48 PM   #3154
Wheeljack
Wheeljack's Avatar
I read this right after I just bought your sway bar.
If the ND is getting mid to high 5 second 0-60 times, and it's lighter than an S2000, it should be able to run heads up with it in B-Street. It would also add another new car to the B-Street mix besides the 370 Z. On the other hand, as popular as the twins are, the ND will outsell be a mile, and the SCCA won't want to risk burying the car against a 7 year old Honda.
Old 06-01-2015, 10:38 PM   #3155
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I no longer have a dog int he fight, sold my BRZ in April.
However, I saw gearing graphs on the ND and it's 2nd gear is woefully short. The epic drivers may be fine with many 2-3s then 3-2s in each run but it's going to hamper it's solo effort in stock trim. If they aren't lying, it looks like ~54mph for second gear.
http://www.msn.com/en-us/autos/resea...p4B?srcref=rss
CRAZY short transmission with a really long rear end.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-02-2015, 10:10 AM   #3156
OkieSnuffBox
Drives: '23 BRZ Limited
So it will be up to the autoX guys to see how high it will spin before zoom zoom boom!
Old 06-02-2015, 10:14 AM   #3157
Kido1986
Dodging cones
Kido1986's Avatar
This is stock ECUs though, no spinning higher. Taller tires (OEM is 205/45/17) will increase a bit at the cost of the sharpness but it does has the same size wheel as the twins so a 235/40/17 will fit well on some times but they you're almost as short as OEM again.
Old 06-02-2015, 10:53 AM   #3158
renfield90
The Stig's German cousin
If the gearing is that short, then they must shift to 3rd to hit 60mph. If they are shifting to third and still nailing 0-60 in 5.8s we are in trouble.
I have STX class letters, but TTD looks appealing as well. Do they allow port-installed options for no points?
The Following User Says Thank You to renfield90 For This Useful Post:
MTeator (06-02-2015)
Old 06-02-2015, 11:03 AM   #3159
solort
Drives: Series 10 FRS
I believe they moved the MX5 MSR to BS, so I would guess that this Miata would go there also...
solort is offline   Reply With Quote
Old 06-02-2015, 11:32 AM   #3160
MTeator
First 86
So the potential to spend 5 figures is OK for STX, but if you didn't have the magnets it would be off the table? That's so autocross
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-02-2015, 12:09 PM   #3161
OkieSnuffBox
That's right, was thinking ST even though this is the Street discussion.
Old 06-02-2015, 12:39 PM   #3162
renfield90
That's only because it was a slight overdog combined with extremely limited availability (had to be one specific model year with $3k of extra parts installed).
Chris Harvey autocrossed the ND back to back against his well prepped NC, both on Rival S tires. I think the results will be in GRM soon. Won't be apples to apples but it'll give a good indication of the car's potential. If bone stock it's faster than the NC, we have a small chance it goes to BS. If they're anywhere close to being on parity, forget it.
Old 06-02-2015, 12:44 PM   #3163
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Same tires but the ND will be stock? If the ND is faster than his developed NC then we are really screwed.
DylanFRS is offline   Reply With Quote
Old 06-02-2015, 12:50 PM   #3164
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Keep in mind that Harvey's NC has baller double adjustable Koni's with added compression. Anyone running OEM or single adjustable shocks in the NC has had essentially zero success in CS.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
