#3165 |
The Stig's German cousin
Meh. My point is I'm not sticking around if the car can't win, and that means I deploy my time and money somewhere else. It doesn't have to be autocross. I spent the better part of a decade driving a ridiculous underdog car and I'm done with that.
#3166 | |
In the track picture I saw of the ND it looked pretty floppy. |
#3167 |
Drives: 2013 Red 6MT Scion FR-S
They are Penskes.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street http://yawmomentracing.blogspot.com/ YouTube Channel |
#3168 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I'm trying to get setup with some lighter/nice 16"s running a wider track but haven't been able to find much of anything. I saw someone suggest RPF1's but I'm not sure that's within the legal 7mm from stock rules. So do you guys know of a good 16" to run and also do you think a slightly wider track has helped at all.
#3169 | |
Drives: Subaru
Will definitely be exciting to see what plays out and see your new car Laloosh at the next NNJR event! Doesn't SCCA has a tendency to put performance models in a higher class. S2k and CR, C5 and C5 Z06, 370z and Nismo 370z? Also, does anyone have the gear ratios for the new miata? I found the the ones for the japanese 1.5L. If they don't change them for the 2.0L, 2nd gear seems to top out at 56-59mph depending on redline. That sounds troublesome for autox. Maybe that's just me though. http://forum.miata.net/vb/showthread.php?t=571383 |
#3170 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
gear ratios Manual 1 5.087 2 2.991 3 2.035 4 1.594 5 1.286 6 1.000 Final 2.866 They do have to shift into 3rd to make it to 60mph but still do it in 5.8-5.9 according to C&D and MT.
So many modders have more cents than sense!
#3171 | |
Drives: 2014 BRZ
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
#3172 | |
Drives: 2014 FR-S
#3173 | |
Drives: Subaru
While shifting to third is fine for 0-60, I feel that on an autocross course it may be more of a hassle. |
#3174 | |
Senior Citizen
Drives: Scion FR-S
Typically for SD, the softer the suspension the better...think it has to due with the low grip and bumpy surface
#3175 | |
Drives: 2014 FR-S
#3176 | |
Senior Citizen
Drives: Scion FR-S
#3177 |
Are we still updating the initial post?
C-Street can now have 16", 17" or 18" wheels and an offset within 7mm of original spec, meaning 41-55mm. Spacers are allowed to bring offset back within spec. Wheel width must remain the same. Please update |
#3178 |
Senior Citizen
Drives: Scion FR-S
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
