Old 01-31-2012, 04:00 PM   #281
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by 7thgear View Post
Formula 1 cars derive their handling from downforce.
Said downforce combined with sticky tires creates enormous amounts of drag. Consider that the drag coefficient of an F1 car is 3-4 times larger than a typical production vehicle.
To overcome this drag and generate the necessary downforce in order to turn the vehicle quickly you must have gobs of power.
furthermore, RAW horsepower is the main ingredient in breaking through wind resistance on straights.
With the exception of a few places on this planet, road speeds are controlled. So going past 100km (when horsepower actually starts to count) is, well, illegal
In that sense, since handling is an attribute which is felt 100% of the time, it is worth more than having gobs of power that you'll never use without attracting the wrong kind of attention.
as for the race track, as was said before, budgets and whole different level of competition start to play a factor.
Handling comes into play in corners so I don't get what you mean by this. And 100% of the roads in the world is not curves.
On my daily commute I run into 75% straights and 25% curves/corners.(I think every American does..lol)
Care to explain what you meant?
SUB-FT86 is offline   Reply With Quote
Old 01-31-2012, 04:05 PM   #282
OrbitalEllipses
Drives: Attitude
200hp in a 2600 chassis is enough to have fun on any track, and more than enough to have fun at an Autocross (which has class designations anyway, means there is zero need to up your power)
Perhaps a stripped out race car will weigh that much, but the road-going car is closer 2800lbs. 2762 is closer to 2800 than it is to 2700, if anyone wants to argue that point you're welcome to.
I'm not saying this car won't be fun, but there's plenty to be said for being pegged into the seat when getting on the throttle. Should I actually have time to autocross this car, it will be more fun than my WRX. As it stands, it's slower than my nearly stock WRX and will not have the satisfaction of BOOST a half-second after flooring it through a turn. I can understand why people have grips about the power, but that's a problem that won't be going away anytime soon. We've all been brainwashed to believe MOAR POWUHH is MOAR BETTERER!
Do I still want it? Yeah. Am I still gonna buy one? Yeah. Am I gonna miss my WRX? Yeah.
Old 01-31-2012, 04:05 PM   #283
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so you're of the opinion that handling goes out the window on straights?
Old 01-31-2012, 04:08 PM   #284
OrbitalEllipses
Drives: Attitude
Guess he's never thought about how stable a car is as being related to handling.
Old 01-31-2012, 04:11 PM   #285
catharsis
Drives: honda civic si 08
Balance, under powered cars are not balanced. The frs/brz is not balanced. Basically I fear that this car would lose to nearly all its competition in a track enviroment just because of its low power output. Straights matter on a track guys. And in autocross a lot depends on its classing it could be a non contender.
catharsis is offline   Reply With Quote
Old 01-31-2012, 04:15 PM   #286
Dimman
Kuruma Otaku
Dimman's Avatar
I believe DSPORT weighed the Greddy FR-S and got 2730 lbs with a half-tank of gas and 19" rims.
Because titanium.
Old 01-31-2012, 04:16 PM   #287
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Anytime there is weight transfer in any direction; acceleration, deceleration, left/right turns "handling" as it were is in effect. It is not simply steering input required to change the yaw and/or direction of the vehicle. 7thgear's statement is accurate.
mines13 is offline   Reply With Quote
Old 01-31-2012, 04:19 PM   #288
SUB-FT86
86 Member
I understand straight line stability through handling yes, but the fun part of handling is in the curves.
Old 01-31-2012, 04:26 PM   #289
OrbitalEllipses
Drives: Attitude
To be clearer, I was not disagreeing with 7thgear.
Old 01-31-2012, 06:46 PM   #290
serialk11r
Drives: '06 AM V8V Coupe
Regarding the power debate, do people really ever floor it on the street? If you buy a bigger engine just so you can feel more acceleration at part throttle, that's wasting all the extra capacity. Makes more sense to keep the smaller engine, and actually use it if you want to feel the forces of acceleration.
Old 01-31-2012, 07:23 PM   #291
mines13
mines13's Avatar
So much truth in there, this is something I enjoyed in my S2000. You could go WOT all over and you were never really going all that fast. compare this to my 300ZXTT where you were pretty much going to do jail time playing the same game.
Old 01-31-2012, 08:14 PM   #292
SUB-FT86
86 Member
I know what you mean. My Thai friend used to own a 2002 AP1 and it felt kinda slow until he went above 6500 rpms. It became a rush at high rpms only. It felt amazing.
Old 01-31-2012, 10:27 PM   #293
OrbitalEllipses
Drives: Attitude
Everyday in my WRX. Why bother having a car like that if I'm not gonna experience the engine?
Old 01-31-2012, 10:58 PM   #294
catharsis
I floor it all the time, only 1st and 2nd gear pulls of course. I try to stay safe on the streets and only do it when the roads empty. I get off from work late like 11pm, the roads are the empty, and it's a great feeling after work just to gas it through 2 gear pulls as I enter the highway.
86 dyno, brz dyno, fr-s dyno, frs dyno, hks 86, hks fr-s, hks frs, hks toyota 86, scion fr-s dyno, scion fr-s hks, scion frs dyno, scion frs hks, subaru brz dyno, toyota 86 dyno, toyota 86 hks, toyota gt86 dyno
Any publication strap this car on a dyno yet? mspeed6 Engine, Exhaust, Transmission 67 02-02-2012 05:48 PM
Autoguide gushes on Scion FR-S (w/ track drift video). Says destined to become icon. ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 111 12-16-2011 03:47 AM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 09:55 AM
Best drift ever Matador Off-Topic Lounge [WARNING: NO POLITICS] 1 05-11-2010 02:48 PM
ft-86 drift trueno Scion FR-S / Toyota 86 GT86 General Forum 46 01-21-2010 05:39 AM
