Old 06-30-2015, 03:44 PM   #2787
churchx
churchx's Avatar
Drives: 2014 GT86
It might not change dynamics of acceleration, but it will certainly change car's character handling wise. It won't be as tailhappy anymore if staying in NA with that much rubber (i guesstimate of course that you will fit wider tires fitting for these wheels too), i guess more probable is case of 'going like on rails'. With that much grip slipping will happen at much higher and dangerous speeds and very probably at more sudden rate.
Old 06-30-2015, 08:53 PM   #2788
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
275/35/18 with 18x9.5+38 stock suspension and stock body, anyone have pics of ftment, how mch poke and any rubbing?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 07-04-2015, 02:30 AM   #2789
FR-Shred
FR-Shred's Avatar
I will try to give as much info as I can..
I want:
17x9
245 or 255 / 40 (unless another size is recommended)
I have/am:
1" drop (might go about .5" more later)
-1.5 F, -1 R Camber
SPC Bolts up front
SPC LCA in the rear
what would be the ideal offset?
My alignment shop said -1.5 was the most they could get out of the front (I trust them). I can get more in the rear but don't really want to with only -1.5 front.
Ive done the calculators but you see it says something will fit and someone on here says it rubs and what not... so yeah, what offset would be best for this drop and camber on 17x9.. thanks!
FR-Shred is offline   Reply With Quote
Old 07-04-2015, 07:11 AM   #2790
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
So I'm going to get some work wheels for next season, and I was thinking O-disk, so would these fit, without any rubbing?
I'm lowered with 15mm that is about 0.6" with the JDM TRD adjustable spring kit.
18x8 ET 30 front and 18x8 ET 18 rear wrapped in 225/40/R18 tires
They could also deliver 18x8 ET 35 front and 18x8 ET 22 rear but that is A-disk.
same type of tires ofc.
I'm on stock brakes.
O-disk got more lip (deep dish), and A-disk is standard.
And I tried the calc, and i looks ok with the deep dish, but just want to ask, so I don't en up rubbing and destroying my tires :p
Cheers
Teclis is offline   Reply With Quote
Old 07-04-2015, 07:27 AM   #2791
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'm surprised your camber isn't more with a 1" drop, especially in the rear.
Ideal offset is +35 for a 17x9. This will be flush and clear, plus will give you clearance if you ever want to go with a BBK.
Suggest a 245/40R17 unless you need more tire (power), then try a 255.
I want:
17x9
I have/am:
-1.5 F, -1 R Camber
SPC Bolts up front
SPC LCA in the rear
Slick is offline   Reply With Quote
Old 07-04-2015, 07:30 AM   #2792
Slick
Slick's Avatar
Way too low offset. For an 18x8, you want something closer to +40.
You might be okay in the front with +30, but +18 rears will likely rub the fenders.
Cheers
Old 07-04-2015, 07:38 AM   #2793
swarb
Check the meaty tire thread. It will rub. First post in the thread mentions 265/35-18's and how to fit them. Unless you have 300+ hp, 275's are overkill.
I want:
17x9
I have/am:
-1.5 F, -1 R Camber
SPC Bolts up front
SPC LCA in the rear
+35 or +40, some people also have +45 but some run a 3-5mm spacer. You can also run another camber bolt to add another degree or so of negative camber.
Cheers
You don't need brake clearance, so those sizes should fit fine. People also like square setups (same tire/wheel all around) so you can rotate tires. You could also run a spacer in the rear. +18 would be my choice. Maybe a couple mm of poke if at all, depending on camber.
Old 07-04-2015, 08:18 AM   #2794
Brody602
Drift King
Brody602's Avatar
I have 600hp thanks for the info
Old 07-04-2015, 10:02 AM   #2795
Teclis
Marine Electrician
Teclis's Avatar
Yeah, I want diff offset in front and back, after I don't want to use spacers.. after that would kinda defeat the purpose of getting 3p wheels
But +18 in the rear wont rub as Slick mentions?
Old 07-04-2015, 01:17 PM   #2796
swarb
18x8 +18 is roughly equal in outside track width as 18x9.5 +37 which is right around the popular 18x9.5 +34 or +40. Inside widths you will have about 19mm more clearance than a 18x9.5+37. You won't rub unless you have zero camber.
You should be good to go. I would get something at least x9 widths in the front if I was ordering a custom 3piece setup. Bigger sizes hold their value better and hold meaty 255+ tires and big power better too.
Old 07-04-2015, 02:04 PM   #2797
Teclis
Marine Electrician
Teclis's Avatar
I like my 225 tires (Michelin Pilot Sport 3), that I have wrapped around my TRD SF2 (18x7.5) wheels, they are great at the track and off the track
But yeah you got a point about 18x9 resale value, big power wont be an issue, after I live in Norway (it's a lot more strict than Germany too here), so a turbo or supercharger aint gonna happen, as it is near impossible to get legally, if you're not an millionaire that is
But wouldn't the 18x9 hit my mpg in a bad way, and also my power?
Old 07-04-2015, 02:13 PM   #2798
swarb
@Teclis the setup you have planned will be more nimble than a wider setup. But will also have less overall grip. Depends on your driving style/preference. Yes a bigger wheel will add weight and you will take a small hit in the power/mpg, it ends up being very little, maybe 1hp and 1mpg.
Old 07-08-2015, 07:54 PM   #2799
FR-Shred
FR-Shred's Avatar
How are 17x9 +42?
My camber was -2.6 with lowering the car before I did LCA.. I didn't want to run that much camber in the rear without that or more camber in the front. But since I don't have camber plates in the front so I can only get -1.5 in the front. I had the shop put the rear camber at -1 to keep handling good.
Any experience with +42 offset?
I was unaware of using two camber bolts.. hmm.. with that I would probably bump the front up to -2 and -1.5 in the rear.
Old 07-08-2015, 08:02 PM   #2800
swarb
How are 17x9 +42?
Rear camber is not adjustable without lower control arms or some other type of bushing/etc.
Mach V wheels are +42 and many people seem to run them with no problem. With 255 tires they may be close to the strut.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
