Old 03-07-2014, 03:43 AM   #267
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
... well, that was short lived.
I'll be selling my kit, tried installing today but ran into a problem, faulty hex tool managed to strip the water plug on the block.
-alex
Old 03-07-2014, 05:50 AM   #268
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Pm sent
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 03-07-2014, 01:43 PM   #269
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
-alex
Try finding a torx bit that is slightly larger and hammer it in.
Has worked for me plenty of times on stripped hex bolts.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
mav1178 (03-07-2014)
Old 03-07-2014, 01:49 PM   #270
mav1178
mav1178's Avatar
I know, but I'm okay with using the Cusco kit.
I was thinking about the coolant pressure differential and cooling capacity, and for my purposes having coolant from the hot/cold radiator hoses will be more effective instead of coolant routed from the block.
Blessing in disguise, I suppose. Plus I already sold the kit :P
-alex
Old 03-11-2014, 09:53 PM   #271
pixel67
pixel67's Avatar
-alex
and i already received it!
Old 03-19-2014, 04:37 AM   #272
indy
indy's Avatar
Drives: blue GT86, AT
pics from AT GT86. No place for T-connector at AT cooling line, approximately 1in between the socket and steel tube hose. And I don't recommend anything to do with these lines, imho cooling an automatic transmission not less important than the cooling of the motor oil. I will make T-connector at heater hose, as discussed earlier.
indy is offline   Reply With Quote
The Following User Says Thank You to indy For This Useful Post:
CARNZ (03-19-2014)
Old 03-19-2014, 03:56 PM   #273
indy
indy's Avatar
Originally Posted by Ralph Spoilsport View Post
I want to (if possible) use the auto trans cooling nipple shown in the top figure, see 11060, Fig 154 <AT>. My car is MT, so I am hoping that I can swap this out for the blank off plate shown for <MT>. What is the part @ 21210?
11060: SU003-00114 or 11060AA290 HOUSING, WATER INLET
21210: SU003-00408 or 21210AA190 THERMOSTAT 50-63C
Ralph Spoilsport (03-20-2014)
Old 03-20-2014, 07:11 AM   #274
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
I like the heater hose connection idea.
I've studied the water circuit a little and come to a few conclusions.
1) the water flow pictures posted earlier by another contributor aren't correct. Water leaving the pump goes through the block first, exits at the water manifold at the top of the engine (under the intake manifold) and returns to the pump via either the radiator, the heater core, the AT or the throttle body. This is to say that the barbed fittings at the water pump are inlets to the pump. Evidence for this is a) water flow direction through the radiator (always top to bottom), b) arrows on heater hoses at the heater core, c) this is the way circulation goes in any engine.
2) the water circuit popularized in this thread provides a very low pressure drop across the oil cooler. The cooler is in parallel with a nice, wide open water pipe and both return water from the throttle body (minor) and the heater core (major).
Two alternatives come to mind that would improve water flow through the cooler. The first is the simplest: Tee into both heater hoses and run the OC in parallel with the heater. The other would be to source water as close to the water manifold as possible (e.g. supply side heater hose) and drain at the water pump with an added barb fitting as shown many times in these threads. Both approaches will, I think, increase the pressure drop across the OC and get a little closer to the spirit of the FXT implementation.
Ralph Spoilsport is offline   Reply With Quote
The Following 2 Users Say Thank You to Ralph Spoilsport For This Useful Post:
CxG (04-25-2016), M1K3 (03-27-2014)
Old 03-20-2014, 08:36 AM   #275
indy
indy's Avatar
I was also confused by the "IN" and "OUT" directions on the heater hoses.
By the way, i have a tee from the Mitsubishi Montero V75W rear heater circuit, he has outputs 17-14-17mm. Our heater hoses have the same internal diameter, ~16mm.
CxG (04-25-2016)
Old 03-23-2014, 05:18 PM   #276
Kirby64
Drives: Galaxy Blue BRZ
Just finished this install a few weeks ago following the instructions on the first page. A few notes:
1) Guide fails to mention you need to remove the aluminum skidplate and the first fiberglass one.
2) "Some coolant" coming out of the hex bolt = all the coolant. I definitely had to refill the entire 1.75L.
3) Dear god why is it so tight between the engine block and firewall for the tubing? My hands hurt for like 3 days afterwards from how much I had to force the tubing into place.
Otherwise, pretty clean and OEM. Seems to bring things up to temperature faster than before. And you certainly can't beat the price!
Kirby64 is offline   Reply With Quote
The Following 4 Users Say Thank You to Kirby64 For This Useful Post:
CARNZ (03-23-2014), CxG (04-25-2016), jcw99 (01-17-2015), weederr33 (03-03-2018)
Old 03-23-2014, 05:40 PM   #277
CARNZ
CHECK ENGINE
Drives: 2004 STi
Figured it'd be pretty obvious by showing photos of underside of engine/etc that you would have to remove the covers! :P
Thanks for the feedback
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 03-24-2014, 12:21 AM   #278
Kirby64
The aluminum skidplate I was expecting, it just took me awhile to figure out I need to pull the fiberglass one too. First excursion under the car, so I didn't have my bearings quite yet.
Old 03-26-2014, 09:43 AM   #279
olorin
olorin's Avatar
Drives: GBS Premium
Awesome DIY, thanks OP for putting this together. I was really worried about the bend in the pipe causing the hose to get pinched. My solution was to shorted the OE heater hose by 3 inches:
and reroute it under all the other hoses. There is already a slight bend in the OE hose and shortening it brings the bend almost to where the hose bends.
As others have noted, its more a flood of coolant that will pour out.
olorin is offline   Reply With Quote
The Following 3 Users Say Thank You to olorin For This Useful Post:
CxG (04-25-2016), DM7 (03-28-2014), jcw99 (04-21-2016)
Old 03-26-2014, 10:24 AM   #280
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks for sharing. Just to be clear, what you call the OE heater hose (which you cut) is the Forester hose, right?
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
