06-10-2017, 07:23 AM | #267 |
Drives: '13 SWP GT86
It did on harsher bumps, but the inner lip on the rear fenders get sanded down when they get painted, any day now. So that combined with slightly more camber will probably help a lot. Gonna be some trial and error
IG @squareddesign
http://www.squareddesign.se |
06-18-2017, 07:04 PM | #268 |
Painted and done.
IG @squareddesign
The Following 6 Users Say Thank You to sqd For This Useful Post: | Chronology (07-21-2017), DustinS (06-28-2017), FutureFT86 (07-21-2017), JD001 (07-28-2017), Metabrz (07-17-2018), VIP BRZ (06-19-2017) |
07-21-2017, 12:42 PM | #269 |
Drives: 13 Scion FR-S
Extremely nice setup. Would you mind sharing your setup on the wheels?
Sent from my SM-G930W8 using Tapatalk
Check out my build: Instagram @kawallito
The Following User Says Thank You to FutureFT86 For This Useful Post: | sqd (07-22-2017) |
07-21-2017, 03:52 PM | #270 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Managed to get a set of CCW LM5T's from a local guy. They ended up being 18x11.5 +38 on the rear. Anyone have an idea on what kind of spacer I'd need to run to get a flush fitment? I know the best answer would probably be to get new barrels, but if I need just a quick bandaid, what would you recommend? +25mm spacers in the rear?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
07-22-2017, 08:22 AM | #271 | |
F: 18x9.5 -3, 255/35 Toyo R888 R: 18x10.5 -26, 285/35 Toyo R888
IG @squareddesign
The Following 2 Users Say Thank You to sqd For This Useful Post: | FutureFT86 (07-22-2017), VIP BRZ (07-24-2017) |
07-28-2017, 11:52 AM | #272 |
Drives: 2014 Subaru BRZ
Hey RB guys,
I'm extremely tempted by some wheels, and before i get to excited and bite off more then i can chew. Wanted to try an make sure the'll fit. I'm rocket bunny V2 18x11-10 18x12-15 Is anyone running close to this size in the front? I'm pretty sure the rears will fit, but im worried about rubbing like crazy in the front. |
07-28-2017, 01:46 PM | #273 | |
Drives: 2013 Ultramarine FR-S
The Following User Says Thank You to DustinS For This Useful Post: | VIP BRZ (07-28-2017) |
07-28-2017, 02:09 PM | #274 |
Yeah, 11" up front wont really work. Unless you redo your entire wheel wells
IG @squareddesign
http://www.squareddesign.se Last edited by sqd; 07-28-2017 at 02:22 PM. |
The Following User Says Thank You to sqd For This Useful Post: | VIP BRZ (07-28-2017) |
09-25-2017, 06:36 AM | #275 |
Drives: Impretzal
Hey guys, I'm planning on buying a kit but the offet of my wheels are pretty high..
I've got s13ps 18x9.5 29mm fronts and 18x10 30mm rears. Would I be able to make it with spacers or am I SOL? |
12-07-2017, 05:01 AM | #276 |
Drives: Brz
Came across a set of Work vskf 18x11 -38
What’s the possibility of making this fit? 3 piece wheels so the front lips could always be changed. |
12-08-2017, 08:47 AM | #277 |
Drives: frs
i run a 10.5 -28 in the front and it fits with the correct tire and camber adjustments, I also beat the hell out of the unibody extensions on the firewall.
01-29-2018, 12:03 AM | #278 |
Drives: '13 frs
01-31-2018, 06:30 AM | #279 |
I modified the sideskirt, not the flares. They're not modified in any significant way. I only trimmed down the lips inside the fender flares, and a bit on the inside of the front piece, to acomodate the large tires. This year they'll even be a little "fatter" though, so we'll see what magic I have to perform..
IG @squareddesign
02-01-2018, 10:22 AM | #280 | |
Drives: 10 Series #974 6m/t
Similar Threads | ||||
Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
