#267 | |
Drives: '13 SWP GT86
IG @squareddesign
http://www.squareddesign.se |
#268 |
Painted and done.
IG @squareddesign
#269 |
Drives: 13 Scion FR-S
Extremely nice setup. Would you mind sharing your setup on the wheels?
Sent from my SM-G930W8 using Tapatalk
Check out my build: Instagram @kawallito
#270 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Managed to get a set of CCW LM5T's from a local guy. They ended up being 18x11.5 +38 on the rear. Anyone have an idea on what kind of spacer I'd need to run to get a flush fitment? I know the best answer would probably be to get new barrels, but if I need just a quick bandaid, what would you recommend? +25mm spacers in the rear?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#271 | |
F: 18x9.5 -3, 255/35 Toyo R888 R: 18x10.5 -26, 285/35 Toyo R888 ![]()
IG @squareddesign
#272 |
Drives: 2014 Subaru BRZ
Hey RB guys,
I'm extremely tempted by some wheels, and before i get to excited and bite off more then i can chew. Wanted to try an make sure the'll fit. I'm rocket bunny V2 18x11-10 18x12-15 Is anyone running close to this size in the front? I'm pretty sure the rears will fit, but im worried about rubbing like crazy in the front. |
#273 | |
Drives: 2013 Ultramarine FR-S
#274 |
Yeah, 11" up front wont really work. Unless you redo your entire wheel wells
IG @squareddesign
http://www.squareddesign.se Last edited by sqd; 07-28-2017 at 02:22 PM. |
#275 |
Drives: Impretzal
Hey guys, I'm planning on buying a kit but the offet of my wheels are pretty high..
I've got s13ps 18x9.5 29mm fronts and 18x10 30mm rears. Would I be able to make it with spacers or am I SOL? |
#276 |
Drives: Brz
Came across a set of Work vskf 18x11 -38
What’s the possibility of making this fit? 3 piece wheels so the front lips could always be changed. |
#277 |
Drives: frs
i run a 10.5 -28 in the front and it fits with the correct tire and camber adjustments, I also beat the hell out of the unibody extensions on the firewall.
#278 |
Drives: '13 frs
#279 |
I modified the sideskirt, not the flares. They're not modified in any significant way. I only trimmed down the lips inside the fender flares, and a bit on the inside of the front piece, to acomodate the large tires. This year they'll even be a little "fatter" though, so we'll see what magic I have to perform..
IG @squareddesign
#280 | |
Drives: 10 Series #974 6m/t
| Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
| Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
| Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
| Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
| GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
