Old 01-13-2016, 04:10 PM   #15
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
damn if you can't deal with a dead battery then why the heck are you into cars firstly, secondly did you say that you disconnected the battery and then pushed the button and nothing happened? that because if you don't have a battery connected there is no electricity going to the car nothing is going to happen. its so simple. its common sense. if you don't have battery in you tv remote and you push the button will the channel change?
sweetfrs is offline   Reply With Quote
Old 01-13-2016, 04:14 PM   #16
carczar87
Perpetually Sideways
carczar87's Avatar
Drives: '14 DGM BRZ, '94 Volvo 940 Turbo
Originally Posted by mdm View Post
Wait, did you disconnect your car's (supposedly dead) battery from the car? You should not do that.
This. I'm assuming we must have misunderstood you, because... well... the alternative is too painful.
carczar87 is offline   Reply With Quote
Old 01-13-2016, 04:35 PM   #17
Kkobe2
Drives: 2015 Series.Blue
Disconnected and reconnected terminals to stock battery nothing new happened so took battery out to get tested and it was no good. Installed new battery and started right up, I was questioning my battery being bad because the car only has 20k miles.
Kkobe2 is offline   Reply With Quote
The Following User Says Thank You to Kkobe2 For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 04:38 PM   #18
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The battery's life is not dependent on miles driven. Quote this.
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 04:42 PM   #19
Kkobe2
Originally Posted by Packofcrows View Post
Is your battery clean (the terminals)?
Have a voltage meter/battery tester tool?
like this
Did you re-tighten battery terminals?
Try starting car with a different battery?
Can you take battery to local autoshop/O'rilleys/NAPA etc for testing?
Did you try reading the manual?
Did you recently do any car mods?
Are your fuses ok? Do you have a tool to check them?
Do any of your electric dependent items work like ac input? Lights? Car beeps?
I dont own a push start model (just not a big fan of all electric), but these are things I would check.
Later on, id check starter, alternator, etc...
Keep us posted!~
Yes, so ecu re-programs itself. Just unplug one cable while you work installing it. I know some people dont do this, they just plug and play.
I do have a multimeter and a tool to check the fuse. The battery died once in a camping trip and never was the same again taking a few more cranks to start up. Thank you for your professional response!
Old 01-13-2016, 05:13 PM   #20
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
I know they are not easy to get to,but if your battery is good,then it's more than likely fouled spark plugs and I would look into that.
Th3rdSun is offline   Reply With Quote
Old 01-13-2016, 05:36 PM   #21
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
OK... you mentioned jumper cables in the beginning, and then you said
"I did try to hold the key to the button nothing. Reconnect the battery connection wires. I did not try that yet "
That made me think that you used another battery to jump-start the vehicle but for some reason disconnected your battery first, and tried holding the key to the button without reconnecting your battery... None of that seemed to make sense, but I guess I misunderstood you.
Glad you have it solved. Batteries die sooner or later. It does not depend on mileage, more on time and external temperatures, I think. Gets pretty cold in Indiana, doesn't it?
I get mine tested whenever my oil is changed, and I replace as soon as they say it's going bad. Maybe they are making extra money on me, but on the other hand I have never had a dead battery (except when I left my headlights on ;-) )
mdm is offline   Reply With Quote
Old 01-13-2016, 08:01 PM   #22
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Alternator starting to malfunction? Or, wire not grounded appropriately would be my next plan of attack.
Packofcrows is offline   Reply With Quote
Old 01-13-2016, 10:45 PM   #23
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'm making it my mission in all the dead battery threads to remind people these are NOT maintenance free batteries.
The fluid level in the cells must be checked regularly and filled with distilled water as required.
See pages 304-305 (32-33) of the Owner's Manual.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
brandonblt2 (01-15-2016), Hoahao (01-14-2016), humfrz (01-14-2016), wireman957 (01-14-2016), Zed (01-14-2016)
Old 01-14-2016, 01:52 AM   #24
humfrz
Keep us posted!~
DANG @Packofcrows .... you out did yourself on that post ......
humfrz
Old 01-14-2016, 02:04 AM   #25
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Oh, this is an interesting thread. Why, when I read it, do I get a mental image of the 3 Stooges? And I hear in my brain "Pop Goes The Weasel".
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
Old 01-14-2016, 02:08 AM   #26
Packofcrows
humfrz
Thanks pal.
...seems like for every pound i lose i gain one helpful point
The Following User Says Thank You to Packofcrows For This Useful Post:
humfrz (01-14-2016)
Old 01-14-2016, 03:52 PM   #27
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
@Kkobe2
Hey op, with the push start. You wanna make sure the push start is actually in off position.
Once the battery is connected "for a little while" make sure you unlock the car with fob, then push the start up botton with the clutch in like 2 or 3 times with like 5 second interval in between.
Old 01-14-2016, 04:23 PM   #28
Have you noticed though that almost all of these dead battery issues have been BRZs with only a couple of FRSs? I strongly suspect that there is something about the BRZ options that is causing a problem. What it is I do not know but there is something up. The difference in numbers is more that I would call a coincidence especially when you consider the smaller number of BRZs that exist.
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 07:55 PM
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
EMERGENCY I NEED HELP PLEASE kiname Southern California 25 07-09-2014 11:41 PM
ECUTEK ECU Emergency gdrider77 Software Tuning 6 12-18-2013 02:28 PM
Emergency help!! Howardwei Engine, Exhaust, Transmission 3 08-16-2013 04:42 PM
