Old 01-04-2016, 10:26 PM   #15
humfrz
It's 2 better.
But seriously, are they incompatible? That's the real question.
I doubt they are incompatible (chemically) ........ but, they were formulated to be more compatible with different elements of different cooling systems.
humfrz
Old 01-05-2016, 01:12 AM   #16
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by i-engineer View Post
Wow ... Toyota dealership near me is charging 40 for 1 gallon. What a rip off.
Sent from my SM-N910V using Tapatalk
Get it off Amazon. Like $23 last I ordered mine.
Packofcrows is offline   Reply With Quote
Old 01-05-2016, 01:52 AM   #17
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
humfrz
I'm pretty sure they have different %'s of rust inhibitors / acids / and stuff, and if they are mixed, the commonly held belief is that the service interval is drastically shortened/sped up because of negative interactions.
aegisdrgn is offline   Reply With Quote
Old 01-05-2016, 03:19 AM   #18
humfrz
I think we are saying about the same thing.
All the different "colored" coolants have different ingredients and/or percentages of ingredients.
In most of the coolants, ethylene glycol is the base ingredient.
The second largest ingredient is water.
The rest of the stuff in the jug can be generally classified as corrosion inhibitors and buffers.
Then we confuse the mix with a dash of phosphates and organic acids and some mixes exclude amines, silicates and borates.
Now, what I mean by “compatibility” is the old “jar test” ….. put a little of each in and shake it up and see what happens.
However, although the two may get along fine in the jar, doesn’t mean they will get along well with the different parts of different engines.
That is where and why the different manufactures have different formulas (colors) specifically designed to protect the parts of their specific engines, that come in contact with the coolant.
So, what to do ….. simply read and follow the owner’s manual …..
Now, back in the day (ya’ll knew this was coming), life was simpler …… in the fall, before first frost, one would drain out all the old rusty water and re-fill the cooling system with well water and alcohol (half & half).
humfrz
Subaru OEM Coolant System Additive JDKane527 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-27-2014 01:24 PM
Losing Coolent nabil_frs Issues | Warranty | Recalls / TSB 10 09-06-2013 12:25 AM
How Many Times has your FRS/BRZ/GT86/Toyota 86 saved your life? BlueLeader Scion FR-S / Toyota 86 GT86 General Forum 21 01-01-2013 12:35 PM
Official Subaru BRZ 34.3 MPG Highway (real life results) dariendrollinger BRZ First-Gen (2012+) — General Topics 25 06-05-2012 12:39 AM
Subaru BRZ real life spottings WingsofWar BRZ Photos, Videos, Wallpapers, Gallery Forum 1694 03-05-2012 04:13 AM
