Old 11-09-2015, 08:25 AM   #15
raven1231
Sorry to hear that man
Old 11-09-2015, 10:06 AM   #16
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by Sportsguy83 View Post
Your tune should have had over boost protection built into it, extremely easy for a tuner to set it up as long as you have an aftermarket MAP sensor....
Replied to +1. Hate to see a car being down because a tuner was too lazy to set up a boost cut.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
SoCal80six (11-09-2015), wparsons (11-10-2015)
Old 11-09-2015, 11:46 AM   #17
blueap2
Drives: '14 FR-S
What tune were you running?
blueap2 is offline   Reply With Quote
Old 11-09-2015, 12:42 PM   #18
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Were you still sporting stock internals? Guess it's time for a engine build
or to jump ship....
MS, CSCS, TSAC-F, CPT
Old 11-09-2015, 03:00 PM   #19
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
(Assuming you're tuned with Ecutek)
Yes I am tuned by delicious with ecutek .
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
The Following 2 Users Say Thank You to SoCal80six For This Useful Post:
Sportsguy83 (11-09-2015), texasbound972 (11-15-2015)
Old 11-09-2015, 03:02 PM   #20
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Was running delicious tune this map was supposed to be 7.5 psi on both 91 and e85 and I just put the e85 in not even an hour before this happened....
Old 11-09-2015, 03:04 PM   #21
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
or to jump ship....
Yes I was it was holding on strong with the right boost but it's not a surprise what happened on about 20psi. Just trying to see what caused it to over boost smh.
Old 11-09-2015, 03:05 PM   #22
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by GsxrMe View Post
I'm interested to know what vacuum line popped off. Evap?
Will be stripping it down in a few to see exactly what's going on with it.
Old 11-09-2015, 03:11 PM   #23
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Delicious Tung was your tune source? That is strange, considering they advertise as having boost cut in their tunes - http://www.ft86club.com/forums/showthread.php?t=52200
Delicious Tuning - Unique Custom Mapping Notes:
1. Use of stock direct injectors and port injectors on E85 up to ~350 whp or 11 pounds of boost.
2. Remove all signs of shift knock or throttle blip knock for boosted vehicles
3. Add switchable boost maps through the cruise control (including boost cut)
4. Added FlexFuel into all the above maps, including switchable boost maps
5. Boost/Fuel/Timing/Cams control up to 22 PSI
@DeliciousTuning - Any feedback regarding why a 7.5psi tune with boost cut would see 20psi?
blueap2 (11-09-2015), wparsons (11-10-2015)
Old 11-09-2015, 04:39 PM   #24
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Not trying to call them out or "start" anything. Just figured I'd throw the question out there since OP is unsure of a cause.
I'd guess a vac leak with the EBCS not seeing boost, preventing the wastegate from opening. The only issue with that is ecutek boost cut (fuel cut) is based on MAP reading. I can't see OP's situation happening unless boost really did spike from 7.5psi to 20psi faster than ecutek's fuel cut kicked in due to Delicious setting the fuel cut delay too high, or the boost cut simply was not configured. Both would be tune related problems, even though a vac line did disconnect. We use EcuTek for these safeguards and trust tuners to set them up properly.
The Following 3 Users Say Thank You to BRZoomTX For This Useful Post:
SoCal80six (11-09-2015), wparsons (11-10-2015), xkalelx (11-17-2015)
Old 11-09-2015, 04:48 PM   #25
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Hit 19 psi on a few pulls before it blew but did the math and I hit approximately 16.82 psi on the run where it actually went out.
Old 11-09-2015, 04:51 PM   #26
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Ouch. Well, next time you know to stop beating on it once you go over target boost. You're usually good for a couple psi over boost targets but definitely not double the target.
Still interesting how the boost cut did not trigger even after multiple pulls overboosting. It sounds like boost cut was not configured in your tune, which they advertise it being on all FI tunes.
Old 11-09-2015, 04:54 PM   #27
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yea wasn't trying to beat on it that's the worst part was doing logs and seen the problem. Pulled over to reflash the map to see if it would help then boom!! 1st pull it gave out.
Old 11-09-2015, 05:05 PM   #28
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Ah, damn... Sorry to hear that bud. Let us know once you've figured out what happened!
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
About to be boosted! willharp360 Forced Induction 18 06-04-2015 10:15 AM
Boosted! FRS-cotty Northwest 21 03-13-2015 10:02 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
