Old 10-19-2015, 06:01 PM   #15
steve99
Originally Posted by Chad11491 View Post
I had a noticeable pop this morning when starting with E85 right at 40*. This will be the last tank I run until it warms up again. The loud pop really worries me as it sounds like detonation (note it only did once when starting up). This is the coldest day of the week for us, as the rest will be in the 60-70 range, so I'll run it out and put 93 in for the winter.
use waynos tables they are much better and from memory less fuel added aroud 40f, i have never had the poping, but like kodename47 said its nothing to be worried about unless its does it on throttle application.
some guys on petrol have also reported the occasional pop on startup in cold weather
Old 10-19-2015, 09:09 PM   #16
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Took at least 2 cranks to start it when 60-70 degrees.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 10-19-2015, 09:48 PM   #17
steve99
standard e85 oft cranking tables ?
or different tune ?
Old 10-19-2015, 10:26 PM   #18
Tt3Sheppard
or different tune ?
Just the standard tables at the moment.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 10-20-2015, 01:03 AM   #19
steve99
use the ones wayno posted up in his thread it will start first crank down to 40f even on e90
Old 10-20-2015, 03:26 AM   #20
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If it doesn't start after taking some ign and maf adjustment out and increasing cranking, then hit the start button once with the throttle pedal on the floor, then once normally.
Old 10-20-2015, 11:04 AM   #21
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Starting your car on ethanol is cold temps is going to be tough no matter how much fuel you add. It is not the amount of fuel that is added, it is making sure the ethanol vaporizes before combustion/spark.
The problem with ethanol (e85) is it will not vaporize below about 50 degrees. Because of this it will not ignite, causing you to try and start the car multiple times. This will continue to happen in order to get the cylinders temps high enough so when the cold ethanol enters the chamber it then vaporizes easily.
Basically you need to warm the fuel to have a fighting chance of starting the car.
Cheers,
William Knose
Old 10-20-2015, 01:44 PM   #22
Tt3Sheppard
Wow that is a huge upgrade with cold cranking
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 10-20-2015, 01:57 PM   #23
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Have been using @Waynos cranking tables here in the WI mornings and has been firing right up so far. This weekend will be a nice test as it is going to get into the low 20's for a few days.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 10-20-2015, 03:00 PM   #24
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Cold starts have been uneventful for me as well after appying Wayno's cranking tables.
Intent > Content
Old 11-02-2015, 02:03 AM   #25
SoCalArgento
Drives: 2014 Argento FRS
In regards to cold starts and first time using Ethanol, would intentionally leaving an extra gallon or so from gas light be a bad idea since the ecu is getting used to e% in general? I ask because it's been in the low 50's where I live and don't want to have cold start problems until I can add some petrol to taper e%. Idk exactly what percentage of E the pump has this is a pic of it helps determine anything Name:  ImageUploadedByTapatalk1446447577.127944.jpg
Any advice helps.
SoCalArgento is offline   Reply With Quote
Old 11-02-2015, 02:49 AM   #26
steve99
Originally Posted by SoCalArgento View Post
In regards to cold starts and first time using Ethanol, would intentionally leaving an extra gallon or so from gas light be a bad idea since the ecu is getting used to e% in general? I ask because it's been in the low 50's where I live and don't want to have cold start problems until I can add some petrol to taper e%. Idk exactly what percentage of E the pump has this is a pic of it helps determine anything Attachment 124152
Any advice helps.
Shiv said the tune is good for between about 60% and 90% ethanol. if your fuel is guaranteed e85% then no problems adding a gallon or so of petrol to a full tank for easier start. Also you cam modify the cranking IP W tables in tune for better starting in cold weather as well ,do both of those and you should be good down to near freezing temps
Old 11-02-2015, 04:16 AM   #27
SoCalArgento
Awesome! Any other tips/advice for someone first trying E85? Aside from the tips already mentioned in the "How to Run E85" thread?
Car has intake that's scaled to 91, full UEL header back exhaust, Power Blocks and other misc. mods.
Old 11-02-2015, 04:31 AM   #28
steve99
if its a stock intake then probably copy wayno s e85 maf scaling from one of his e85 tunes
if its an aftermarket intake then copy across your current scaling then check the fuel trims and afr, it might need a re-touch up.
copy waynos e85 cranking table values as well they are the best available especially for high e content e85
A/C not cold enough Champster BRZ First-Gen (2012+) — General Topics 41 06-15-2015 11:04 PM
How cold did you run your Vortech kit? kaybee123 Forced Induction 8 03-26-2014 09:13 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 11:20 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
it to cold Pekingduck Southern California 9 01-05-2013 08:08 AM
