Old 10-11-2015, 09:04 PM   #15
ir1064
Drives: 6MT, C7P
Originally Posted by BlackJesus View Post
By the looks of things... no. It's a brand new headunit meaning new wiring configuration but I might be wrong. Check with someone who has a 2016 and ask them to take a picture of the back of their hu and compare it with your headunit. Plus buying an audio hu from Toyota is going to cost alot. I was quoted $1300 for a 2013 brz hu without the SD card and wiring. SD was another $600. So expect $1500+ since the rear view camera doesn't come with your purchase of the hu
eBay has one for $850
http://www.ebay.com/itm/2016-Scion-I...3848f3&vxp=mtr
ir1064 is offline   Reply With Quote
Old 10-11-2015, 10:07 PM   #16
Ramjet
Drives: 2015 Scion FR-S Asphalt
I have a 2015 and bought the one from camera source on ebay. It has the guidelines but can be disabled by cutting a jumper on the cable close to the camera. Pretty much plug and play. Had a little trouble getting the 12 volt trip wire into the plug at the head unit but other than that it was a breeze. When you pop the molding up beside the seat there is a nice little trough to run the cable through. Camera is obviously not HD but does have a good enough picture. We have Toyota Tacoma work trucks at the work 20 with the multimedia cameras on them and this one is every bit as good. It took me about 6 hours to install due to the problem with the trip wire. If I did it again I could probably get it down to 4 or 5. You won't be disappointed. Price was $161.00 with shipping and all.
Ramjet is offline   Reply With Quote
Old 10-11-2015, 10:53 PM   #17
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by N1rve View Post
I bought this one...
https://camera-source.com/scion-disp...amera-kit.html
There are guidelines but I left them on because why not? They will be accurate if you mount dead center. I mounted off center. Good quality, only spliced one wire (reverse trigger)
Could you make a video / picture to show =p?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 10-11-2015, 10:57 PM   #18
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
I just went out and played with my jumpers. My camera has 4 wires. Two green and two white. When the green wires are connected the parking guidelines are removed from the screen. Connecting the two white wires inverts the image making it upside down on the display.
The trip wire gave me some trouble as well. Rather than try to force the pin into the plastic connecter which was difficult to get in deep enough to make continuity I just didn't use it and just pushed the bare wire in from the backside and secured it with a dot of hot glue. Im sure if I had the patience I could have made the connector work but the only thing that matters is continuity.
OP:
Go back and reread the other thread I linked to. There are two youtube videos that go over the installation and specifically the installation of the reverse wire.
I'm sure there are variations of cameras out there that will use different combinaitons of the jumper wires based on how the camera was manufactured. The photo below shows what works for mine to disable the guidelines and have the proper orientation.
RustySocket is offline   Reply With Quote
Old 10-11-2015, 11:29 PM   #19
RustySocket
Slow Learner
Drives: 15 Halo FRS
This post shows all the jumpers disconnected and the grid lines being displayed.
Old 10-11-2015, 11:32 PM   #20
RustySocket
Slow Learner
Drives: 15 Halo FRS
This is a picture of my Dog because now that we have been in and out of the car ten times she would like to go for a ride... or just lick my phone:
The Following User Says Thank You to RustySocket For This Useful Post:
86kahl (10-21-2015)
Old 10-12-2015, 01:50 AM   #21
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I followed this video...
[ame="https://www.youtube.com/watch?v=6_F4ww1YHRY"]https://www.youtube.com/watch?v=6_F4ww1YHRY[/ame]
Only ONE wire splicing required (I prefer to splice as little as possible). And there is a harness to wire most of the items.
N1rve
Old 10-12-2015, 03:40 AM   #22
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
Originally Posted by ir1064 View Post
Yea, ebay will always be alot cheaper than the actual dealership. I'm not sure if the new subaru star link is alot better or not than scion but I do know that it's a ton of money
BlackJesus is offline   Reply With Quote
Old 10-12-2015, 10:48 PM   #23
Ramjet
This is the video I followed as well.
I'll try to get a pic of it when I can get a chance.
Actually I didn't splice, just tinned the wire with solder and stuck it in the plug by the hood latch. I think it was the 5th one down. Went in really easy and secured with small cable tie so it's not coming out.
The Following User Says Thank You to Ramjet For This Useful Post:
RustySocket (10-30-2015)
Old 10-30-2015, 04:26 AM   #24
RustySocket
Slow Learner
Drives: 15 Halo FRS
I did the same thing rather than splice into the harness. Clean, easy to remove without a trace. No risk of cutting the harness wire.
Old 02-27-2016, 01:49 AM   #25
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Had a little trouble getting the 12 volt trip wire [reverse gear signal] into the plug at the head unit ...
It sounds like the vendors didn't send you a reverse gear lead with the proper Japanese terminal to fit the car's 28-pin harness plug. Not good.
When I supply that wire with a camera harness to FR-S owners (and anyone else whose car lacks the reverse gear lead), it has the correct terminal.
Before you can insert (or extract) a terminal, you do also need to open a retaining latch on the bottom of the 28-pin plug.
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
RustySocket (03-02-2016)
Old 03-02-2016, 11:23 AM   #26
RustySocket
Slow Learner
Drives: 15 Halo FRS
It is very likely this is what I was doing wrong.
Reverse Camera on stock 2015 head unit iLaw Electronics | Audio | NAV | Infotainment 18 04-29-2017 01:35 AM
2016 Scion FR-S Backup Camera Guidelines iJeff Electronics | Audio | NAV | Infotainment 25 02-24-2017 04:36 PM
Backup camera for AXCP-Q14U T10015 pioneer touchscreen head unit infamous_s Electronics | Audio | NAV | Infotainment 8 02-21-2017 12:44 PM
2016 Head Unit Question / Discussion Devante Electronics | Audio | NAV | Infotainment 31 04-18-2016 07:59 PM
OEM Reverse Camera and aftermarket head unit map26 Electronics | Audio | NAV | Infotainment 0 07-27-2015 10:47 AM
