Old 10-10-2015, 06:00 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Can I buy rear camera and head unit 2016
Hey, I have a 2015 FRS (BASE)
I need a rear camera and I was wondering if I could buy the rear camera and the HU of the 2016 model?
I know there were few guide of how to install the rear camera an after market one. I don't like the quality and I wanted something from Toyota...
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 10-10-2015, 07:08 PM   #2
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
By the looks of things... no. It's a brand new headunit meaning new wiring configuration but I might be wrong. Check with someone who has a 2016 and ask them to take a picture of the back of their hu and compare it with your headunit. Plus buying an audio hu from Toyota is going to cost alot. I was quoted $1300 for a 2013 brz hu without the SD card and wiring. SD was another $600. So expect $1500+ since the rear view camera doesn't come with your purchase of the hu
BlackJesus is offline   Reply With Quote
Old 10-10-2015, 07:32 PM   #3
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
The 2015 base headunit will support a camera. I installed one on mine.
RustySocket is offline   Reply With Quote
Old 10-10-2015, 08:17 PM   #4
Mikeez
Engineering Student
How's the quality.
Okay thanks :3 I will look after market then
Old 10-10-2015, 08:43 PM   #5
RustySocket
Slow Learner
Drives: 15 Halo FRS
It's a Toyota camera. It looks identical to the camera installed on the 2016 car.
I got it off ebay searched for Toyota Fit camera. Paid about 100$ for it. Comes with the hole saw to drill the hole to mount the camera. In hindsight I could have gotten a 15$ knock off and accomplished the exact same thing but like yourself I wanted a factory part.
It comes with a harness that plugs into the back of the radio. You have to tap into your reverse lamp signal and run a wire for the reverse trigger. There's a thread on here how to do it. Now that ive done it once it's a half hour job at most.
No way would I spend 1500$ upgrading to a 2016 headunit to do the exact same thing. That would be ridiculous.
Here is an install thread:
http://www.ft86club.com/forums/showthread.php?t=65777
Old 10-10-2015, 08:49 PM   #6
Mikeez
Engineering Student
http://www.ft86club.com/forums/<br /...ad.php?t=65777
is there guidelines? Since I hate them.. they look bad since its not calibrated
Old 10-10-2015, 08:52 PM   #7
RustySocket
Slow Learner
Drives: 15 Halo FRS
Mine has guidelines, Not sure what you mean by not calibrated?
Actually I believe there is a jumper on the camera wire to disable them, and another set to invert the signal 180. Mine are spot on however so I didn't worry about it.
Old 10-10-2015, 08:53 PM   #8
Mikeez
Engineering Student
like the guidelines sucks =p, its not at the right angle
Old 10-10-2015, 09:14 PM   #9
RustySocket
Slow Learner
Drives: 15 Halo FRS
When I set mine up. I placed markers on the ground. The markers were square to the back of the car and centered on the guidelines. Not sure how much better/worse it could be. I use it for backing into parking spaces as to not hit a concrete barrier with my exhaust and to back into the garage. I'm not filming video with it.
As to whether or not it meets your standards or not is speculative. I was simply trying to be helpful. I've been in a 2016 I don't recall it being any different. By all means if you have the money to spare to install a 16 headunit that is probably what you should do.
Old 10-10-2015, 09:19 PM   #10
Mikeez
Engineering Student
My sincere apologies in how I talked to you buddy. I was wondering which one did you buy and where =p?
Also, does it work with the base model of the 2015 FRS??
Old 10-10-2015, 09:27 PM   #11
Mikeez
Engineering Student
http://www.ebay.com/itm/Toyota-Scion...item460e37a094
Old 10-10-2015, 09:29 PM   #12
RustySocket
Slow Learner
Drives: 15 Halo FRS
I purchased this exact camera from this seller:
Old 10-10-2015, 09:33 PM   #13
Mikeez
Engineering Student
okay thanks =p
Old 10-11-2015, 02:16 AM   #14
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I bought this one...
https://camera-source.com/scion-disp...amera-kit.html
There are guidelines but I left them on because why not? They will be accurate if you mount dead center. I mounted off center. Good quality, only spliced one wire (reverse trigger)
N1rve
Reverse Camera on stock 2015 head unit iLaw Electronics | Audio | NAV | Infotainment 18 04-29-2017 12:35 AM
2016 Scion FR-S Backup Camera Guidelines iJeff Electronics | Audio | NAV | Infotainment 25 02-24-2017 03:36 PM
Backup camera for AXCP-Q14U T10015 pioneer touchscreen head unit infamous_s Electronics | Audio | NAV | Infotainment 8 02-21-2017 11:44 AM
2016 Head Unit Question / Discussion Devante Electronics | Audio | NAV | Infotainment 31 04-18-2016 06:59 PM
OEM Reverse Camera and aftermarket head unit map26 Electronics | Audio | NAV | Infotainment 0 07-27-2015 09:47 AM
