#15 |
Old Mechanic
Drives: 2013 Limited BRZ
Someone needs to get another one going... Not it. But I will definitely be able to get in on it.
Sent from my LG-D850 using Tapatalk |
#16 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Added YouTube video.
#17 |
#18 |
Drives: subaru brz
#19 |
#20 |
Run Away!
Drives: 2015 Subaru BRZ Limited
Does the header come with the overpipe -> header bolts & nuts or do I have to source that? If so, what bolt sizes did you use?
Thanks! |
#21 | |
I used the PLM overpipe with no issues. Also, we were able to pinpoint the source of my leak: ![]() We used larger gaskets + torqued to spec, and this still happened. I'm assuming non-level, but I don't have a decking tool to say so. My vendor swapped it out for me no problem. New header installed, and no issue! |
#22 | |
Run Away!
Sent from my ONE A2005 using Tapatalk
#23 |
I love it. It has the snake sound to it, but only on the inside. Paired with the N1, you're not hearing shit anyway. It's aggressive af.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#24 |
Awesome setup, this review made it next on the mod list
#25 |
Drives: frs
#26 |
Drives: frs
#27 |
Drives: frs
Anyone can confirm if the header and overpipe cant fit well? And need buy the overpipe of them to fit the header?
#28 | |
Drives: 350z
I just installed my manifold and found it to have the whistle noise ![]() Your original link for the video with the rattle no longer works |
| Best EL catless header? | shu5892001 | Engine, Exhaust, Transmission | 38 | 01-22-2018 10:36 PM |
| catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
| Open flash header and catless front pipe and unresonated exhaust review | FrostedFlakes | Engine, Exhaust, Transmission | 14 | 07-07-2015 12:57 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
