Old 10-10-2015, 01:24 PM   #15
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Someone needs to get another one going... Not it. But I will definitely be able to get in on it.
Sent from my LG-D850 using Tapatalk
Respect BRZ is offline   Reply With Quote
Old 10-10-2015, 01:44 PM   #16
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Added YouTube video.
Rifle is offline   Reply With Quote
Old 10-10-2015, 01:51 PM   #17
Rifle
Rifle's Avatar
Originally Posted by vien View Post
Does the cell cause any issues with performance at all or just a annoyance?
Annoyance, makes cruise control not work. I have an ECUTek so I can just clear the code though.
Old 10-10-2015, 02:02 PM   #18
vien
Drives: subaru brz
I see well that sucks, but besides the cruise anything else?
vien is offline   Reply With Quote
Old 10-10-2015, 02:39 PM   #19
Rifle
Rifle's Avatar
Nope.
Old 10-13-2015, 03:24 PM   #20
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Does the header come with the overpipe -> header bolts & nuts or do I have to source that? If so, what bolt sizes did you use?
Thanks!
Rabbit of Caerbonnog is offline   Reply With Quote
Old 10-21-2015, 11:55 PM   #21
Rifle
Rifle's Avatar
Thanks!
Header comes with NOTHING - not even a cheap pair of gaskets. Normally, if you're using an aftermarket OP, they will have the nuts+bolts, as stock OP has studded bolts + nuts.
I used the PLM overpipe with no issues.
Also, we were able to pinpoint the source of my leak:
We used larger gaskets + torqued to spec, and this still happened. I'm assuming non-level, but I don't have a decking tool to say so. My vendor swapped it out for me no problem.
New header installed, and no issue!
The Following User Says Thank You to Rifle For This Useful Post:
Rabbit of Caerbonnog (10-22-2015)
Old 10-22-2015, 07:41 AM   #22
Run Away!
Yeah I received my header about a week ago. Unfortunately the Nameless op/fp I also ordered came without the op to header bolts. So far, how are you liking the header?
Sent from my ONE A2005 using Tapatalk
Old 10-22-2015, 03:09 PM   #23
Rifle
Rifle's Avatar
I love it. It has the snake sound to it, but only on the inside. Paired with the N1, you're not hearing shit anyway. It's aggressive af.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Old 10-25-2015, 09:37 PM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Awesome setup, this review made it next on the mod list
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Rifle (10-25-2015), Teseo (12-23-2015)
Old 12-23-2015, 05:42 PM   #25
Teseo
Drives: frs
When done make a video pls
Old 12-23-2015, 05:53 PM   #26
Teseo
Drives: frs
Lol. So far, I love it. I'm about to leave for work shortly, let's see if I can take a cold-start video without waking up the neighborhood... unlikely..
Video doesnt work
Old 01-06-2016, 08:57 PM   #27
Teseo
Drives: frs
Anyone can confirm if the header and overpipe cant fit well? And need buy the overpipe of them to fit the header?
Old 06-27-2016, 06:15 AM   #28
calvinwilson1
Drives: 350z
So you no longer have the whistle/rattle?
I just installed my manifold and found it to have the whistle noise
Your original link for the video with the rattle no longer works
calvinwilson1 is offline   Reply With Quote
Best EL catless header? shu5892001 Engine, Exhaust, Transmission 38 01-22-2018 10:36 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Open flash header and catless front pipe and unresonated exhaust review FrostedFlakes Engine, Exhaust, Transmission 14 07-07-2015 12:57 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
