Old 04-23-2015, 01:26 AM   #1
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Lightbulb Best EL catless header?
Hi guys,
I tried to search but was not able to find any concrete result. I am looking to get a catless EL header.
I already have hi flow cat and resonated front pipe and resonated exhaust, so I think noise would not be too much of a concern.
I am in a dilemma between Nameless, JDL, PTUNING and TOMEI.
I was initially set on the Nameless header before they released it because of all the hype and stuff, but after they released it, it seem like it did not outperform other header by a lot.
I also hear people say that PTUNING is the best one on the market, but I know JDL also has superb quality, so I am really lost.
I am looking for the absolute best quality, cleanest sounding and best performing header (with a tune, of course). Price is not such a big of a concern.
Can anyone give me any advice?
Thanks!
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 04-23-2015, 01:53 AM   #2
shu5892001
Ontario's FT86
Also I currently have drop in filter, nameless OP/DP with hi-flow cat and resonator and perrin resonated exhaust. I may or may not get an intake, my final goal is to have a clean sounding car that will touch 200 whp on the dyno (with ecutek)..
Old 04-23-2015, 01:57 AM   #3
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The Ptuning is very good quality.
Get a tune with it for sure though.
Old 04-23-2015, 01:59 AM   #4
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
There is no best header. There are compromises with each header. You need to look at what is most important to you: a broader power band, peak power, peak torque, price, looks, or sound. There is no one size fits all best header.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-23-2015, 02:14 AM   #5
shu5892001
Ontario's FT86
Yea, I totally understand this and that's why I am in this huge dilemma right now. The car will be a daily driver, I already have the catted and resonated nameless OP/DP and perrin resonated exhaust. I just want to finish the overall package with a quality header and tune and call it a day...
I would love to touch the 200whp after the tune, but I also want a quality header that will last as long or out last the car, and also sounds civilized enough for a DD...
Old 04-23-2015, 02:28 AM   #6
RJasonKlein
RJasonKlein's Avatar
When I had to make a similar decision, after a lot of research I purchased the PTUNING header because of its proven quality and output. The JDL header looks excellent, but I wasn't convinced that they spent as much time optimizing exhaust cam timing during its development, and the quality didn't seem to be the match of the PTUNING header (although it looks like a close second). The Tomei seems like well made piece at a very affordable price (although their unequal length header looks much cooler than their equal length header).
Good luck with your purchase and let us know what you decide on.
Last edited by RJasonKlein; 04-23-2015 at 02:30 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 04-23-2015, 02:33 AM   #7
Andrew025
Andrew025's Avatar
How you drive the car will play a big role in the header you choose.
If you aren't in the upper RPMs often, you may not like the Ptuning since there is still a small "dip". If you track or don't mind driving in the upper RPMs, the Ptuning is a great choice.
The only other header I can compare it to is an UEL header with OFT tune.
It got rid of the dip but the Ptuning wins in every other category IMO.
Old 04-23-2015, 02:50 AM   #8
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I'd say Tomei or JDL
Alltezza is offline   Reply With Quote
Old 04-23-2015, 03:06 AM   #9
Turdinator
Señor Member
Turdinator's Avatar
Tomei is nice but not really in the same legue as the other two options mentioned and from all reports doesn't pick up as much power from a tune. Between the JDL and the Ptuning the biggest difference seems to be the torque curve. the JDL usually has a bump where the dip normally is the lifts up again towards redline. The Ptuning has quite a flat curve from early on with a small dip in it.
Another header to look at is the Aceheader 4-2-1. it looks well made and has a nice torque curve.
1974 TA22 Celica
2013 86 GT
Old 04-23-2015, 06:00 PM   #10
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I'd like to see these reports, I'm making 193whp w/Tomei on 93.
When I was shopping for a new exhaust manifold, it came down to PTuning and Tomei. Most of the headers are more or less identical (exception for the few 4-1 headers). A friend of mine for example has JDL, I'm making essentially the exact same power (he is 1 hp less than me actually). Tuned by the same person, on the same dyno. Weather conditions nearly identical.
PTuning with a full exhaust will make the most power. Fantastic piece of work. I would have gone PTuning if budget wasn't a factor.
Get PTuning header, and check out their thread. Pretty consistent 199whp - 203whp dyno numbers on 93. Availability can be an issue on their headers, they arnt ordered too often and they sell pretty fast.
SpectreRT is offline   Reply With Quote
Old 04-23-2015, 06:44 PM   #11
wparsons
wparsons's Avatar
Making a couple whp more up top means nothing if you're giving up more down in the midrange across a wider rpm range.
Look at the shape of the powerband on the headers, not peak numbers. The nameless is going to make much better power in the midrange due to it being a 4-2-1 compared to the good 4-1 headers out there, but will give up a couple hp up top.
Unless you're drag racing, you're probably going to be happier with the meatier midrange than the extra couple hp at peak.
flickr
Old 04-23-2015, 07:02 PM   #12
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I got my catless EL header from Top Speed. Less than 400 bucks and very good quality.
I also have the carless Perrin resonated exhaust. Love the sound.
Here's the header
http://topspeedauto.com/scion-fr-s-f...ght-flex-pipe/
You can hear my car here with the top speed header. I'm #24
Lunatic is offline   Reply With Quote
Old 04-23-2015, 07:11 PM   #13
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Can I see the dyno graphs?
To OP: The Tomei kit will probably be the most complete kit even if the performance gains are no as great as the others. You get gaskets, antiseize and heat shielding barrier to stick on your oil pan. You'd be lucky to even get gaskets with any other brand.
Old 04-23-2015, 10:00 PM   #14
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Hi guys,
Thanks!
Sorry, gotta plug.
ACE 4-2-1 (even comes with gaskets and decals).
Sounds awesome and has pretty good welds
http://www.ft86club.com/forums/showthread.php?t=80609
Nameless and JDL are also very good options
AceHeader-MT is offline   Reply With Quote
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Pa inspection and Catless Header b1gb2olo Engine, Exhaust, Transmission 6 12-09-2015 02:15 PM
Top Speed Pro-1 Catless Header GA_Dave Engine, Exhaust, Transmission 6 07-27-2014 09:56 AM
no cel after catless header install vestal52 Engine, Exhaust, Transmission 14 05-22-2014 02:21 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
