Old 09-12-2015, 12:03 PM   #15
mario17623
Drives: FRS 2014
P2127 and p2122.. which is the throttle position sensor in circuit "e" and "d" I really don't know if that's it now
Sent from my SM-N910T using Tapatalk
mario17623 is offline   Reply With Quote
Old 09-12-2015, 12:48 PM   #16
Originally Posted by mario17623 View Post
There is a code c1201 and c1241
When you google engine codes always include subaru in search (ecu is subaru) codes can be different between manufacturers
http://engine-codes.com/p0301_subaru.html
P0301 is cylinder 1 misfire
these cars have history of coil pack failure
but either log ecu parameters or take it to a shop to confirm
Originally Posted by fika84 View Post
Sounds electrical if it's off and on like that. I would take @steve99 advice and check coil packs.
Those would indicate electrical. Did you check as Steve said or just reflash?
Old 09-12-2015, 01:59 PM   #17
mario17623
Drives: FRS 2014
Just reflash but I am going to check coils right now
Old 09-12-2015, 05:50 PM   #18
steve99
You can sometimes get weird codes come up after a reflash, clear them and see if they come back its unusual that you would get al those ectra codes in two unrelated systems.
the original code the ecu flagged P0301cylinder 1 misfire can be due to many things
coil pack
failed spark plug
even problem with cam position sensor
di seal failed
bad fuel
see here
crap tune and bad fuel results in spark plug fail and possible di seal fail
but check spark plugs and coil packs first
if you not getting poping sounds out on intake hopefully its not di seal.
http://www.ft86club.com/forums/showthread.php?p=838159
Old 09-12-2015, 06:21 PM   #19
mario17623
Drives: FRS 2014
I checked spark plugs and there in good condition, what are di seals? Sorry I am a bit confused on that part
Old 09-12-2015, 06:26 PM   #20
mario17623
Drives: FRS 2014
coil pack
failed spark plug
di seal failed
bad fuel
see here
I sort of get a pop like sound, sucking in air. I have to clear that code that says throttle position sensor everytime I leave my car parked for a while because if not it stays up in 3k rpm and won't let me steep on gas. Once I clear it I could drive it a bit like normal only that I get like a lag at first and then kicks in
Old 09-12-2015, 07:22 PM   #21
steve99
poping from intake can be an indicator of di injector seal problems
if your getting weird random codes also check battery\alternator volts dying batteries or other electrical issues that cause volts to be unstable will upset ecu and sensor readings.
very difficult to diagnose this stuff on a forum :-)
Old 09-12-2015, 07:38 PM   #22
mario17623
Drives: FRS 2014
Yeah it's been the hardest problem I have ever had. Well to find the main cause
Old 09-12-2015, 07:49 PM   #23
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
If you pulled the coils to check the plugs did you swap them when reinstalling? If you did and the code still indicates the same cylinder then you know its not the coil pack.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 09-13-2015, 03:09 AM   #24
Dude, we have said DI seals since the very beginning of the thread and yet you have chased everything but them. It may be time to take it to a shop if you don't know what DI seals are. Not being a smart ass but the answer may be staring you in the face and not a hard problem at all.
Old 09-14-2015, 12:53 AM   #25
mario17623
Drives: FRS 2014
My bad I confused the Direct injector with the port injectors.
The Following User Says Thank You to mario17623 For This Useful Post:
Tcoat (09-14-2015)
Old 09-14-2015, 06:38 PM   #26
mario17623
Drives: FRS 2014
I found the issue it was my tune at first and now it looks like the code it's throwing now is the right one. It says my ignition coil d and I remembered switching them. Does anyone know where to buy coil?
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
CEL P0301, P0351, and P0172 Darryljr11 Issues | Warranty | Recalls / TSB 16 06-07-2015 06:37 PM
CEL P0301 came up today Sportsguy83 Issues | Warranty | Recalls / TSB 22 01-09-2014 12:49 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 04:04 PM
CEL P0301 C1201 and U0100 peachch Issues | Warranty | Recalls / TSB 32 12-21-2013 04:37 PM
