Old 09-11-2015, 02:25 AM   #1
mario17623
Drives: FRS 2014
P0301 code -turbo frs
I don't know what is going on with my car. At first I thought it was my gas tank not sealed up right so I re tighten it. It fixed it self for a bit but now it's worse. No its sputtering like won't accelerate correctly. I am not sure if it's bc there is water in the tank now? Or I just don't know[IMG]I don't know what is going on with my car. At first I thought it was my gas tank not sealed up right so I re tighten it. It fixed it self for a bit but now it's worse. No its sputtering like won't accelerate correctly. I am not sure if it's bc there is water in the tank now? Or I just don't know
Sent from my SM-N910T using Tapatalk
mario17623 is offline   Reply With Quote
Old 09-11-2015, 03:16 AM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Replace/clean 02 yet?
Check spark plugs, coil on cyl 1 and compression.
The Following User Says Thank You to Packofcrows For This Useful Post:
Dream20b (09-14-2015)
Old 09-11-2015, 03:32 AM   #3
mario17623
Drives: FRS 2014
Check spark plugs
No I haven't cleaned my o2. How would you know if its good, but I did check cylinder one side and my spark plug and it looked fine.
Old 09-11-2015, 03:42 AM   #4
Packofcrows
Sputtering, misfire, lazy acceleration, shakyness, CEL are all symptoms of bad O2. I just replaced my 02 on pickup. $35. It also had mpg drop symptom at hwy driving.
For sparkplug have you tried swapping wires to make sure they havent gone bad?
Code on obd says cylinder one. Swap wire 1 with 2 etc...
Try this.
http://www.ft86club.com/forums/showthread.php?t=43169
And fml changing air filter and i forgot, tried turning it on, and it sucked the towl i was using to detail front.
Tcoat (09-11-2015)
Old 09-11-2015, 03:48 AM   #5
mario17623
Drives: FRS 2014
Sputtering, misfire, lazy acceleration, shakyness, CEL are all symptoms of bad O2. I just replaced my 02 on pickup. $35. It also had mpg drod symptom at hwy driving.
Try this.
Yes I tried doing that and same problem still. So Ill try that out and see what happens
Old 09-11-2015, 04:00 AM   #6
Still stock other than turbo? No other changes at all?
DIs or seals by the looks of the code.
http://www.google.ca/url?sa=t&rct=j&...Fa5LOoUnv-cpHA
Or possibly your tune if tuned
http://www.google.ca/url?sa=t&rct=j&...ax2sxxSBOyGxwg
Old 09-11-2015, 04:06 AM   #7
steve99
Drives: FT86
When you google engine codes always include subaru in search (ecu is subaru) codes can be different between manufacturers
http://engine-codes.com/p0301_subaru.html
P0301 is cylinder 1 misfire
these cars have history of coil pack failure
but either log ecu parameters or take it to a shop to confirm
Tcoat (09-11-2015)
Old 09-11-2015, 09:49 AM   #8
mario17623
Drives: FRS 2014
No not really alot just fuel pump and injectors
Old 09-11-2015, 10:14 AM   #9
mario17623
Drives: FRS 2014
I forgot to mention I could drive my car sometimes with no problem. Then at times my check engine light and traction turns on. Not sure if that would narrow some stuff down.
Old 09-11-2015, 11:25 AM   #10
fika84
fika84's Avatar
Sounds electrical if it's off and on like that. I would take @steve99 advice and check coil packs.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Tcoat (09-11-2015)
Old 09-11-2015, 12:33 PM   #11
I concur. A seal or injector is likely going to be intermittent. They either work or they don't.
Old 09-12-2015, 07:44 AM   #12
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Coil Packs usually throw a 35x code but its easy to swap just the coils on 1&3 and see if the issue follows. Typically they start acting up at high rpm first.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 09-12-2015, 08:35 AM   #13
mario17623
Drives: FRS 2014
There is a code c1201 and c1241
Old 09-12-2015, 11:59 AM   #14
mario17623
Drives: FRS 2014
I re-tuned my car with old map it had and now it shooting a diffrent code
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
CEL P0301, P0351, and P0172 Darryljr11 Issues | Warranty | Recalls / TSB 16 06-07-2015 06:37 PM
CEL P0301 came up today Sportsguy83 Issues | Warranty | Recalls / TSB 22 01-09-2014 12:49 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 04:04 PM
CEL P0301 C1201 and U0100 peachch Issues | Warranty | Recalls / TSB 32 12-21-2013 04:37 PM
