Old 08-17-2015, 04:06 PM   #15
ryoma
ryoma's Avatar
if you truly want a BBK, I would say go with the RR kit: http://www.ft86club.com/forums/showthread.php?t=90379
it's pretty affordable with good results and it has been track tested.
however, I would personally upgrade pads, fluid, rotors (maybe), and lines (if you want) before going to the BBK. test it out on the track and see if it has enough stopping power. unless your "home" track is going to have multiple 90+ MPH straights into tight turns, I doubt you'll need a BBK even if you're boosted.
I have winmax W5 pads with RT700 fluid and SS lines when I went to SoW and it stopped me fine after I was going 90+ MPH at the end of the straight into the turn. no fade at all, even after multiple laps.
The Following User Says Thank You to ryoma For This Useful Post:
CSG Mike (08-17-2015)
Old 08-17-2015, 04:14 PM   #16
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
The only reason I'd get the TRD brakes is if you like the look of the big red calipers and want the TRD logo. Also meant my warranty was valid as my car came with them.
They are rebranded brembos as others have said. I did know the brembo model numbers but can't locate them at the moment.
There's much better value for money so logo/look/warranty would be the reasons.
Here's mine
With weds SA10R wheels
Being installed by Toyota
With original TRS SF2 wheels
nzer is offline   Reply With Quote
Old 08-17-2015, 04:47 PM   #17
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I wouldn't worry about the calipers and rotors if you are a Novice track driver.
However once you move up you will want a BBK.
The Stoptech ST40 has been tested over and over and is stock on most Porsche 911s so the range of pads available for it are enormous and relatively inexpensive.
We use the 328mm Kit on our Spec86 Cup race car and Project BRZ track and street car.
Pricing is very reasonable at about $1600 shipped and they are designed specifically for the BRZ/FRS including Pads, Lines, Calipers and Rotors. Hit us up if you want to talk brakes or suspension. sales@azpinstalls.com
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
nzer (08-17-2015)
Old 08-17-2015, 06:19 PM   #18
We can always get you a Brembo setup, that you can repaint to show TRD instead of Brembo
Old 08-17-2015, 07:33 PM   #19
mdfm1286
Drives: 2015 release series 1.0 #907
Again guys thanks for the great info yes looks play a big role on why I want the TRD but overall performance is scrificed ill just safe a bit more. I plan on going to the limit with Yuzu.
mdfm1286 is offline   Reply With Quote
Old 08-17-2015, 07:35 PM   #20
mdfm1286
Here's mine
beautiful my friend just beautiful!!!
The Following User Says Thank You to mdfm1286 For This Useful Post:
nzer (08-17-2015)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
