Old 07-19-2015, 01:48 PM   #15
plynnjr92
plynnjr92's Avatar
Drives: 2015 Halo FR-S 6-Speed
But it doesn't work. Even if the fog light button is 'on', the only instance in which they will turn on, is when the headlights are on too. I'm bad at explaining things, but I'll illustrate with some pics when I get to my car.
Sent from my Samsung Galaxy S5 using Tapatalk
plynnjr92 is offline   Reply With Quote
Old 07-19-2015, 01:52 PM   #16
plynnjr92
plynnjr92's Avatar
Originally Posted by Ammunition View Post
FWIW I plan on simply re-wiring my Diode Dynamics kit to tap into the side marker, and not the headlights - that way if I (like you) just want a little extra light (but don't want to have my headlights enabled) I can just flip the light stock one turn and have the fog lights come on with the side markers, license plate, and dash lighting. I emailed Diode Dynamcis asking if this would be safe, and they confirmed that it should be perfectly fine to do so.
THIS!! If I can't have them on all the time I at least want them wired to the marker lights
Old 07-19-2015, 02:26 PM   #17
plynnjr92
plynnjr92's Avatar
We've established I want my fog lights on with Marker Lights on. But they only turn on with the headlights on.
This is my fog light switch in "on" position.Name:  uploadfromtaptalk1437330330070.jpg
Here's Marker Lights on, Fogs "on"Name:  uploadfromtaptalk1437330343202.jpg
Here's Headlights on, Fogs "on"Name:  uploadfromtaptalk1437330366544.jpg
To put it this way, the fogs and headlights are married. I want the fogs to divorce the headlights and marry the marker lights haha
Old 07-20-2015, 11:31 PM   #18
mush
mush's Avatar
Originally Posted by Chen View Post
The way I have mine set up. It's just a switch independent from the headlights.
http://www.nigel-jdmparts.com/fog-li...h-onoff-switch This switch specificity.
are u able to turn ur fogs on anytime?
Old 07-20-2015, 11:42 PM   #19
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Yeah. It's just an on and off switch.
Chen is offline   Reply With Quote
Old 07-20-2015, 11:48 PM   #20
mush
mush's Avatar
thats what plynnjr92 is trying to do
i kinda want to use my fogs as drl too
Old 07-21-2015, 01:01 AM   #21
PNW FRS
PNW FRS's Avatar
Fogs off when Hi-beam On
I have the OEM fogs with control on left-stalk. When Fogs are on... and Hi-beam is turned on.. the Fogs turn off (by design).... must be something "legal-wise" b/c on my other rig (w/factory Fogs), the same thing... Hi's on - Fog's off.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 07-21-2015, 08:13 AM   #22
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
I don't get where the confusion in this thread is coming from...
I have the exact setup you're looking to accomplish and it's not difficult
1. Buy Diode Dynamics fog light kit
2. Buy FR-S Monogram switch kit (found at fteightysix.com)
3. Install fog light kit --> Power wire goes to your battery
--> Trigger wire goes to the switch
My fog lights work independently of the headlights.
The only complication I see is that your fogs were installed by factory but that shouldn't be a show stopper. Just go take a look how they were wired up and re-route that power wire + trigger wire
Hope that helps...See my posting here for more clarification:
http://www.ft86club.com/forums/showp...43&postcount=6
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
The Following User Says Thank You to tiz22 For This Useful Post:
Bergen23 (07-21-2015)
Old 07-21-2015, 08:21 AM   #23
plynnjr92
plynnjr92's Avatar
I don't wanna have to buy a whole new fog kit if I have oem. But basically what I should have the fogs powered directly from the battery?
Old 07-21-2015, 08:46 AM   #24
tiz22
tiz22's Avatar
Correct.
In order to separate the marriage between your headlights and fog lights - you need to provide your fogs with an "always on" power source. The battery is the easiest way to get that.
So just find the power wire to your OEM fogs and connect it to the positive terminal of the battery.
Then hook up the switch as I show in that previous post link giving it ground and power - and then splicing the fogs trigger wire into it
plynnjr92 (07-21-2015)
Old 07-21-2015, 08:50 AM   #25
plynnjr92
plynnjr92's Avatar
Thanks man! I think my friend and I can figure this out sometime this weekend
Old 07-21-2015, 08:51 AM   #26
tiz22
tiz22's Avatar
No worries. Send me a PM if you're having any issues
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
Subaru BRZ independent fog light??? itsmybrz13 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-19-2016 01:23 AM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
running fully independent suspension BadCompany235 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-20-2013 08:23 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
