Old 07-09-2015, 11:40 PM   #15
SteveIsBored
Drives: 2013 subaru brz
Originally Posted by KoolBRZ View Post
Just get an entire steering wheel and column from a wrecking yard, a cheap ebay cable with a (cracked) copy of techstream, and install, connect up with the techstream cable, find where it's at and check the box for shift paddles "yes".
It's probably not that easy since there's a significant price difference between the two
SteveIsBored is offline   Reply With Quote
Old 07-10-2015, 12:11 AM   #16
scarfo
Drives: gts 86
That price difference is roughly the same for manual transmission gt and gts, so I doubt it would be super expensive
scarfo is offline   Reply With Quote
Old 07-10-2015, 12:48 AM   #17
SteveIsBored
I'm guessing that the trans module would need to be re-configured for paddle shifters which would probably require downloading a vin specific configuration file, that's the tough part
Old 07-10-2015, 01:54 AM   #18
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The TCU would be exactly the same as it takes the EXACT same inputs whether it's GT/GTS or whether it's shifter/paddles. All the paddles do is perform the exact same function as the shifter in M. I think you'd just need the wheel and maybe a loom from a GTS. If you're lucky the loom might already be in the GT column. Contact Kalen Gray and see if he has any AT wrecks.
Best case is you remove the wheel and find 2 more pins on the column side of the cruise control plug that aren't on the wheel side.
Worst case you need to get a whole column and run wires to piggyback on to the 2 switches in the floor shifter.
The Following User Says Thank You to Wayno For This Useful Post:
KoolBRZ (07-10-2015)
Old 07-13-2015, 04:14 PM   #19
sirro
Drives: stock, planning upgrades.
Real reply here.
I purchased a set of paddles for my manual gts for my planned air shifter. The wiring is there it plugs straight in. It is just the back plastic piece for the steering wheel not a complete replacement. Standard computer i dont know about. I have the motec installed.
Sent from my SM-N915G using Tapatalk
sirro is offline   Reply With Quote
Old 07-18-2015, 06:59 AM   #20
SunnyDay
Drives: 86
So I removed the airbag to have a look and it seems as sirro said that the holes to mount the paddles are already there (red circles) and the 4 pins connector to the paddle is there too (blue circles).
Here is a photo of the paddles connector that match the connector I have on my wheel:
Are those paddles simple on/off switches? If so I could try to short the connector to simulate the paddle and see if the electronic is working before buying the paddles.
SunnyDay is offline   Reply With Quote
The Following User Says Thank You to SunnyDay For This Useful Post:
Wayno (07-30-2015)
Old 07-18-2015, 07:07 AM   #21
sirro
If i was in the country i would check for you. But i am willing to bet they are just momentary switches.
I think the only problem you may run into is software. But if i was toyota id make one software for both and just have the paddles trigger the same circuit for shift up / down.
I picked my paddles up off ebay. 115$ buyout within a few hours of listing....took a long time for them to show up.
Old 07-18-2015, 07:09 AM   #22
Wayno
Wayno's Avatar
I picked my paddles up off ebay. 115$ buyout within a few hours of listing....took a long time for them to show up though.
Software wtf? The floor shifter does the EXACT same function.
Old 07-18-2015, 07:12 AM   #23
sirro
Thats what i am hoping. If they just have it on the same circuit it is as good as done.
Old 07-18-2015, 08:23 AM   #24
SunnyDay
Drives: 86
sirro, I tried to find the paddles on eBay but could find any. Could you please tell me the seller name or the search you used to find them?
Cheers!
Old 07-18-2015, 08:31 AM   #25
SunnyDay
Drives: 86
From the repair manual, it seems that the paddles are simple switches:
Bellow 1 Ohm when the switch in pulled means a simple short is required to trigger the speed change
MrDinkleman (11-05-2015)
Old 07-18-2015, 08:52 AM   #26
sirro
Ebay seller was andrew86car
private seller.
Probably a part out car he was doing.
Just listed as toyota 86 / brz auto shift paddles.
I search all the time for items like that. Only works if you aren't in a hurry.
Old 07-23-2015, 08:27 AM   #27
SunnyDay
Drives: 86
Just bought a full wheel with the shift pedals for only $99!
Decided to give it a go! Will let you know how it goes in a few weeks!
Wayno (07-23-2015)
Old 07-23-2015, 08:28 AM   #28
Wayno
Wayno's Avatar
Where from? I need to do this to my friends gt.
paddle-shifters
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
CF Shift Paddles? FRS_Ken Cosmetic Modification (Interior/Exterior/Lighting) 2 01-23-2013 11:05 PM
I know the automatic has paddles, but..... Jedi1 Engine, Exhaust, Transmission 34 10-02-2012 01:50 PM
