Old 06-18-2012, 09:46 PM   #1
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
I know the automatic has paddles, but.....
Every once in awhile I like to play with the sequential style shifter. There doesn't seem to be an issue here until you realize that for some unexplained reason the shift pattern is backwards? Why would a manufacturer such as Toyota or Subaru do this? Both companies have Motorsport ties that reach back decades. I am fairly confident that someone on the development team knows pulling the shifter towards the driver should be an upshift and pushing it towards the dash should be a downshift. This makes sense because under braking it is easier to push the shifter forward to downshift and exactly the opposite is true under acceleration.
I say that to ask this. Does anyone out there know if we can just pull whatever plug the sequential stick engages and reverse it, or would that cause the ECU to throw a raging tantrum?
Just curious. Thanks to anyone that might have some input on reversing the shift direction.
Sean
Jedi1 is offline   Reply With Quote
The Following User Says Thank You to Jedi1 For This Useful Post:
Sonolin (03-07-2013)
Old 06-18-2012, 10:08 PM   #2
Mild2Wild
Drives: Firestorm FR-S
There is no "right" way to design it. It varies from manufacturer to manufacturer. If I remember correctly the Porsche PDK system is also forward to upshift.
Mild2Wild is offline   Reply With Quote
Old 06-18-2012, 10:10 PM   #3
arghx7
Drives: car
It could be done if you reprogrammed one or more of the control modules. Or maybe if you repinned an electrical connector.
Why is it like that in the first place? It's probably because that's what their customer clinics told them the expected buyer wanted. Or maybe they didn't bother doing any evaluations. Nobody actually uses manual shifting functions on a regular basis. They try it out a couple times and then forget about it.
arghx7 is offline   Reply With Quote
Old 06-18-2012, 10:34 PM   #4
Jedi1
Jedi1's Avatar
Yep, PDK is backwards when it comes to this as well.
I know it comes down to the manufacturers choice. But what I don't understand is why manufacturers with massive racing backgrounds choose to do this backwards. It's odd to me.
Old 06-18-2012, 10:54 PM   #5
ahausheer
Re-member
Drives: Toyota camry
That would be a cool mod. Pull to shift up, the way it should be.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-18-2012, 11:02 PM   #6
Jedi1
Jedi1's Avatar
I will be looking into the possibilities.
Old 06-18-2012, 11:11 PM   #7
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I guess whether its an easy change depends if the gear selector is switch activated or mechanical (inside the tranny?).
If switches, I would presume you could swap the switches or wiring from front to back which would reverse the shift direction to the correct way.
Slick is offline   Reply With Quote
Old 06-18-2012, 11:30 PM   #8
Jedi1
Jedi1's Avatar
Hoping for the switch option.
Old 06-18-2012, 11:44 PM   #9
catharsis
Drives: honda civic si 08
Personal preference.
catharsis is offline   Reply With Quote
Old 06-19-2012, 12:11 AM   #10
Jedi1
Jedi1's Avatar
Sorry, its not personal preference when every sequential box put into any modern era race car is upshift towards the driver and downshift towards the dash. If you personaly like it the other way around, that's cool. But, it is backwards when compared to track specific sequential boxes.
gonzo (10-02-2012)
Old 06-19-2012, 12:29 AM   #11
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
it would be easiest to change the wiring at the ECU (or junction block), rather than make physical changes to the switches.
Cleanest way would be to have two mini jumper harnesses.
One that swaps the wires, and one that reverts it back to stock.
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Jedi1 (06-19-2012)
Old 06-19-2012, 02:33 AM   #12
old greg
Rocket Surgeon
Drives: PSM GGA OMG
The manual-mode autos aren't set up for people who have spent time using a proper sequential manual, they are made for people who drive automatics (no offense intended). And from a certain viewpoint it does kind of make sense; push forward to go faster, pull back to go slower is kind of intuitive. That said, I completely agree with you.
old greg is offline   Reply With Quote
Old 06-19-2012, 08:57 AM   #13
arghx7
Drives: car
Wake up. This isn't a race car. They are trying to maximize sales through good impressions from "regular" people taking test drives, not please internet car forums. Either they don't give a crap or they have data from customers saying that's the preference.
Old 06-19-2012, 09:49 AM   #14
atledreier
Drives: GT86 DGM
The de'facto standard is 'backwards', sadly. I haven't seen any semi-auto box that had the stick the 'right' way. It's a pain in the butt. Looked into swapping them on my VW DSG, but the wiring down there is just overengineered to the nth degree. I skipped it and just live with it for now.
atledreier is offline   Reply With Quote
The Following User Says Thank You to atledreier For This Useful Post:
Jedi1 (06-19-2012)
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Do you think FT-86 will have automatic? TRD Engine, Exhaust, Transmission 217 08-03-2013 09:36 AM
Red Automatic FRS available BRZ88 NY / NJ / CT / PA 0 06-01-2012 12:04 PM
automatic pdf :D enjoy carbonBLUE Engine, Exhaust, Transmission 4 04-26-2012 11:17 PM
Anyone Else Considering an Automatic FR-S? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 410 02-16-2012 12:41 PM
