#15 |
I Love custom Turbo kits
Drives: Limited BRZ
No inspections in FL at all, ever... Yes, move here
#16 |
Member of the year - 2016
Drives: Scion FRS
Before everyone starts jerking themselves off that they don't need an inspection in their own state.
I'm confused as if you flashed back to stock tune or not. Or is your headless catless, thus causing an immediate CEL?
#17 | |
There certainly is something to be said for a decent inspection system.
| The Following User Says Thank You to Tcoat For This Useful Post: | Quentin (06-11-2015) |
#18 | |
Drives: '13 10 Series FRS #1203
I did not flash back to stock. I simply went to another station after someone in this thread mentioned being in NYS and having just passed an inspection. Comparing the tunes of his and mine (aside from fueling as his was a FI tune) all the diagnostic stuff was the same. I figured I'd try another shop. I'm guessing the OBDII scanner they use is a little worn down for how much it gets used and just makes a crappy connection with my port. All my OBDII devices work just fine. It failed 2 attempts and the 3rd one finally went thru. Multiple forums for various other platforms were commenting the same "Connection Failure" issue with a tune on their car which is what prompted me to make this thread. Even though the OBDII device says its connected per the diagnostic light, apparently some tunes will cause a "Connection Failure" message with NYS machines if any readiness monitors are turned off. However it does not appear Shiv disables any of those things in his tunes. The disabled DTC codes have no effect on this. |
| The Following User Says Thank You to Shady195 For This Useful Post: | Tcoat (06-10-2015) |
#19 | |
Drives: Scion FRS
Did they put the sniffer on your exhaust?
#20 |
| Failed Tom's Tail lights | RevoG | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 12-21-2016 07:45 PM |
| Failed login notification | griffinnn | Site Announcements / Questions / Issues | 6 | 02-18-2015 09:21 PM |
| OFT and inspection | NyC Zn6 | NY / NJ / CT / PA | 10 | 08-18-2014 09:12 AM |
| OFT and inspection in NYC | NyC Zn6 | Software Tuning | 6 | 08-15-2014 04:27 PM |
| AT - Failed to downshift in manual mode | abutterman | Issues | Warranty | Recalls / TSB | 26 | 03-14-2013 10:11 AM |
