Old 05-24-2015, 12:17 AM   #15
whataboutbob
AutoX-10/10ths every run
BTW, I've been running these CASCAMs on my car for over a year, and have not had ANY issues like the ones you are experiencing. I'd be looking to other suspension components first before the CASCAMs.
Build thread:Here
Old 05-24-2015, 03:12 AM   #16
Deraj
Drives: '14 Asphalt Monogram
I also had a clunking noise - on stock suspension plus Raceseng cascams dialed for max camber. I contacted Raceseng and they said they had a production run of bolts (the 3 top mounting bolts) that were too long. As a result, the spring perch was hitting up against the bottom part of the bolt and causing the clunk. I should mention that Raceseng was very responsive and sent out replacement bolts and spring perches the same day. I would measure one of those bolts and shoot it over to Raceseng to see if that's your problem.
Deraj is offline   Reply With Quote
Old 05-24-2015, 05:03 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by whataboutbob View Post
This. If the bolt holding the endlink to the swaybar or the bolt holding the endlink to the strut/coilover is loose, you'll get clunking when there is an uneven load on the swaybar. A case where this can happen is when you are entering a driveway and one side of the front suspension becomes loaded while the other is not. In this case there is the most extreme load on the front swaybar and if the endlinks aren't REALLY tight, you can get clunking. I've encountered this problem more than once on my car. It is a good idea to check the nuts on the endlinks from time to time as they may come loose even if you tightened them properly during the initial install. I've also found that depending on which endlinks you are running, it may be necessary to put a 3/8" fender washer on both sides of the mounting point for the endlink to get them to snugly tighten up.
It cant be this. I tightened with hex key and wrench. The next time i used an impact wrench.
i had a problem getting 2.6 camber in my alignment and it was because of that issue. I too got replacement bolts. I dont know if maybe something else could have got damage during the alignment as they were trying to set it. I doubt it but i am not sure what to look at.
I check every bolt. Next day off i guess i will swap on oem top mount and see for sure...
Old 05-26-2015, 09:07 AM   #18
Raceseng
Raceseng's Avatar
This damage is from the bolts that were too long. We will gladly replace the spring perch, please send me an email and we will get it shipped out.
It sounds like we eliminated the spherical bearing from the equation.
Please do the same check on the radial bearing in the spring perch. Make sure it moves smoothly and does not have any play.
If we eliminate both of components, the next thing to address is installation.
I disassembled the passenger side today. Took the whole thing out.
Bearing moves smoothly. No play. No noise. Reassembled everything, new blue loctite on fasteners.
Sound is still there. Occurs much more when single wheel is driving over bumps, not much if any when both wheels go over something, like an expansion joint.
I noticed this damage to the spring perch. It may be from an incorrect bolt on initial install which has since been replaced but I can't be sure.
Raceseng is offline   Reply With Quote
Old 05-26-2015, 09:08 AM   #19
Raceseng
Raceseng's Avatar
We already cleared this up with him but thank you for the feedback.
Old 05-26-2015, 09:52 AM   #20
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
I had some weird noises after my install, and luckily it was just the strut bar was torqued too high....
Good luck with your fix OP
drewbot is offline   Reply With Quote
Old 06-01-2015, 11:38 AM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Ugh sry no update. Today my day off and absolutely pissing rain. Ill try get up early tomorrow and hope it stopped and do some more investigation.
Old 06-01-2015, 02:07 PM   #22
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
As Jarrett, said earlier, its probably that the bearing has play. Mine started making a noise and Raceseng replaced it all for me. New part is installed and no more clunking.
Ranatsu is offline   Reply With Quote
Old 06-06-2015, 03:16 PM   #23
ZionsWrath
Thanks
ZionsWrath's Avatar
Might be fixed? Going to test drive tonight and tomorrow ~50 miles to NYC and back.
When I removed everything there didn't seem to be play. If I have to tomorrow I will reinstall OEM top hat and see. I don't want to just throw new parts at it as I'll still be frustrated if they don't work.
Crossing my fingers for the test dive tonight.
Old 07-21-2015, 02:19 AM   #24
ZionsWrath
Thanks
ZionsWrath's Avatar
Sorry no update for while, been busy with some other stuff haven't even drive the car until a few days ago.
I guess it has to be the bearing as there is really nothing else it could be. I just did a track day Friday and car drives fine. I don't know but I'm not going to waste any more time trying to hunt it down lol
Anyway I would like to hit up @Raceseng for those replacement top mounts if its not too late. Maybe I should just buy a replacement bearing and see what happens.
Old 07-22-2015, 10:16 PM   #25
Raceseng
Raceseng's Avatar
Send me an email with your shipping address and what side bearing housing you need, we will get it shipped out same day.
Thanks!
Old 08-02-2015, 05:04 PM   #26
ZionsWrath
Thanks
ZionsWrath's Avatar
Got the replacement bearing Friday. Did not receive the spring perches. But I was excited because I knew immediately the bearing would fix it.
I guess I couldn't tell because I had no comparison but when I removed the parts last time the bearing moved freely. This new one I couldn't even move.
Anyway, I installed it seems to fix problem. But I only drove a couple miles and my car is going into shop for some unrelated issues. Will do extensive test drive and track time when I get it back.
Thanks @Raceseng for superb customer service
SPC Camber Bolt Issue breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-20-2021 09:22 AM
Jrz rs1 no camber plate? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-09-2014 10:16 PM
ST coilover + Camber plate BRZPDX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-26-2014 02:11 PM
Raceseng Camber adj top mounts issue kcco-whiteout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-16-2014 02:15 AM
HVT BRZ/FRS Non-raising Camber Plate Turn in Concepts Brakes, Suspension, Chassis 25 08-18-2013 03:57 PM
