| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 13 FRS Satin
#16 |
Drives: 2005 Toyota Camry
Have you actually taken it apart? It's a piece of plastic with fur covering it. Looks pretty but doesn't do jack for sound.
Sound insulation that I speak of is actual deadening material that is glued to panels. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Tcoat (04-13-2015) |
#17 |
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton |
| The Following 3 Users Say Thank You to tahdizzle For This Useful Post: |
#19 | |
The only issue I have is that with some music the bass will start to resonate with my exhaust and the whole song become nothing more then a booming form of white noise (Sabbath and GNR are both really bad for it at any volume). In those cases a quick switch from "Feel" to "Voice on the head unit usually fixes it. (oh and "Rock out" to ELO? Teehee)
#20 |
The Fail Boat
Drives: CWP S.B.
Plug up that sound tube on passenger side. It's pretty quiet.
| The Following User Says Thank You to chaoskaze For This Useful Post: | Tcoat (04-13-2015) |
#21 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | mav1178 (04-13-2015) |
#22 |
So elite I'm 1338
What's a "key"?
-Jack Burton |
| The Following 2 Users Say Thank You to tahdizzle For This Useful Post: | AznBRZer (04-13-2015), gramicci101 (04-13-2015) |
#23 |
Off Topic
| The Following 3 Users Say Thank You to gramicci101 For This Useful Post: |
#24 |
key1
[kee] /ki/ Spell Syllables noun, plural keys. 1. a small metal instrument specially cut to fit into a lock and move its bolt. 2. any of various devices resembling or functioning as a key: the key of a clock. 3. key card. 4. something that affords a means of access: the key to happiness. 5. something that secures or controls entrance to a place: Gibraltar is the key to the Mediterranean. 6. something that affords a means of clarifying a problem. 7. a book, pamphlet, or other text containing the solutions or translations of material given elsewhere, as testing exercises. 8. a systematic explanation of abbreviations, symbols, etc., used in a dictionary, map, etc.: pronunciation key. Compare legend (def 4). 9. the system, method, pattern, etc., used to decode or decipher a cryptogram, as a code book, machine setting, or keyword. 10. one of a set of marked parts, designated areas, or levers pressed in operating a typewriter, computer terminal, calculator, etc. 11. a manually operated lever for opening and closing an electric circuit, used to produce signals in telegraphy. 12. Music.
14. mood or characteristic style, as of expression or thought: He writes in a melancholy key. 15. degree of intensity, as of feeling or action. 16. a pin, bolt, wedge, or other piece inserted in a hole or space to lock or hold parts of a mechanism or structure together; a cotter. 17. a small piece of steel fitting into matching slots of a hub of a wheel or the like and the shaft on which the wheel is mounted so that torque is transmitted from one to the other. 18. a contrivance for grasping and turning a bolt, nut, etc. 19. Computers. a field or group of characters within a record that identifies the record, establishing its position among sorted records, and/or provides information about its contents. 20. (in a series of advertisements or announcements soliciting replies) a unique code inserted for each medium used, to determine the relative effectiveness of the media. 21. Electricity.
23. Masonry. a keystone. 24. Architecture. (in a ribbed vault) a stone, as a boss, at the intersection of two or more ribs. 25. Masonry, Carpentry. a wedge, as for tightening a joint or splitting a stone or timber. 26. Carpentry. a small piece of wood set into a timber across the grain to prevent warping. 27. Building Trades. any grooving or roughness applied to a surface to improve its bond with another surface. 28. Basketball. keyhole (def 2). 29. Photography. the dominant tonal value of a picture, a high-key picture having light tonal values and minimal contrast and a low-key picture being generally dark with minimal contrast. 30. Painting. the tonal value and intensity of a color or range of colors: Rembrandt's colors are characterized by their low key. 31. Botany. a samara. 32. (initial capital letter) a member of the House of Keys. 33. keys, spiritual authority. Expand adjective 34. chief; major; important; essential; fundamental; pivotal: a key person in the company; key industries. verb (used with object), keyed, keying. 35. to regulate or adjust (actions, thoughts, speech, etc.) to a particular state or activity; bring into conformity: to key one's speech to the intellectual level of the audience. 36. Music. to regulate the key or pitch of. 37. Painting.
39. to provide with a key. 40. (in the layout of newspapers, magazines, etc.) to identify, through signs or symbols, the positions of illustrations or pieces of copy in a dummy. 41. to lock with or as if with a key. 42. Masonry. to provide (an arch or vault) with a keystone. 43. Computers. keyboard (def 4). Expand verb (used without object), keyed, keying. 44. to use a key. 45. Computers. keyboard (def 4). Verb phrases 46. key in, Computers. keyboard (def 4). 47. key on,
48. key up,
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (04-13-2015) |
#25 |
I had keyless for many years and now that I am back to one I just jump in and try to push a nonexistent button at least once a day!
| The Following User Says Thank You to Tcoat For This Useful Post: | gramicci101 (04-13-2015) |
#26 |
Haha! My bad, I thought it actually did something.
#27 |
It's that thing that prevents someone from hopping in your car when you are standing outside of it, pushing a button and driving off.
You know, that thing... (although, in all fairness a gun works for that too)
#28 |
head of infinite swagger
Drives: 2013 FR-S 6MT
Road noise is a big problem for me in this car and the main reason I'll be getting rid of it when the lease is up. Adding performance-oriented tires makes it worse too.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
| Road noise? Tread Noise? | zERoTu | Issues | Warranty | Recalls / TSB | 21 | 10-07-2020 11:21 PM |
| Dampening Road Noise from Wheel Wells | aznatama | Electronics | Audio | NAV | Infotainment | 6 | 08-18-2014 08:59 PM |
| hankook v12 road noise | DarkestBuddha | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 02-04-2014 10:46 PM |
| Road/Exhaust noise mitigation? | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 03-05-2013 07:55 PM |
| road noise | chris's fr-s | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 12-02-2012 12:19 AM |
