Old 04-13-2015, 11:32 AM   #15
Chanpion
Drives: 13 FRS Satin
Originally Posted by mav1178 View Post
The two cars are identical when it comes to sound insulation from the factory.
-alex
Doesn't the BRZ come with a trunk lid interior liner?
Chanpion is offline   Reply With Quote
Old 04-13-2015, 11:36 AM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Have you actually taken it apart? It's a piece of plastic with fur covering it. Looks pretty but doesn't do jack for sound.
Sound insulation that I speak of is actual deadening material that is glued to panels.
-alex
Tcoat (04-13-2015)
Old 04-13-2015, 11:37 AM   #17
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton
The Following 3 Users Say Thank You to tahdizzle For This Useful Post:
brianhj (04-13-2015), Sideways&Smiling (04-13-2015), Tcoat (04-13-2015)
Old 04-13-2015, 11:38 AM   #18
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you cant handle that noise, dont buy it. you'll regret it
Old 04-13-2015, 11:50 AM   #19
Originally Posted by carma143 View Post
Not to derail the thread, but I still can't relate to others having issues with the spealer volume. If I simply want to hear a song in the background (street driving) I'll keep the volume anywhere from 7-21. If I want to really, as the cool kids say "ROCK OUT!" I'll bump it up to around 32-43; flipping my hair in the wind... Queen, ELO, and Foreigner come to mind.
This^^^^
The only issue I have is that with some music the bass will start to resonate with my exhaust and the whole song become nothing more then a booming form of white noise (Sabbath and GNR are both really bad for it at any volume). In those cases a quick switch from "Feel" to "Voice on the head unit usually fixes it.
(oh and "Rock out" to ELO? Teehee)
Old 04-13-2015, 12:01 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Plug up that sound tube on passenger side. It's pretty quiet.
The Following User Says Thank You to chaoskaze For This Useful Post:
Tcoat (04-13-2015)
Old 04-13-2015, 12:04 PM   #21
I have some photos of it on my Builder's thread here. @mav1178 is right, I doubt it does much for sound deadening. It's literally thinner than your car key.
mav1178 (04-13-2015)
Old 04-13-2015, 12:09 PM   #22
tahdizzle
So elite I'm 1338
What's a "key"?
-Jack Burton
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
AznBRZer (04-13-2015), gramicci101 (04-13-2015)
Old 04-13-2015, 12:13 PM   #23
gramicci101
Off Topic
Originally Posted by tahdizzle View Post
What's a "key"?
I got a courtesy loaner from the dealership a month or so back, and I sat there and stared at the key for about five seconds before I remembered what to do with it. I was seriously thinking "But where's the start button..."
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
leoh007 (04-13-2015), sftateofmind (04-13-2015), tahdizzle (04-13-2015)
Old 04-13-2015, 12:13 PM   #24
What's a "key"?
key1
[kee] /ki/
Spell Syllables
noun, plural keys. 1. a small metal instrument specially cut to fit into a lock and move its bolt.
2. any of various devices resembling or functioning as a key: the key of a clock.
3. key card.
4. something that affords a means of access: the key to happiness.
5. something that secures or controls entrance to a place: Gibraltar is the key to the Mediterranean.
6. something that affords a means of clarifying a problem.
7. a book, pamphlet, or other text containing the solutions or translations of material given elsewhere, as testing exercises.
8. a systematic explanation of abbreviations, symbols, etc., used in a dictionary, map, etc.: pronunciation key.
Compare legend (def 4).
9. the system, method, pattern, etc., used to decode or decipher a cryptogram, as a code book, machine setting, or keyword.
10. one of a set of marked parts, designated areas, or levers pressed in operating a typewriter, computer terminal, calculator, etc.
11. a manually operated lever for opening and closing an electric circuit, used to produce signals in telegraphy.
12. Music.
  1. (in a keyboard instrument) one of the levers that when depressed by the performer sets in motion the playing mechanism.
  2. (on a woodwind instrument) a metal lever that opens and closes a vent.
  3. the relationship perceived between all tones in a given unit of music and a single tone or a keynote; tonality.
  4. the principal tonality of a composition: a symphony in the key of C minor.
  5. the keynote or tonic of a scale.
13. tone or pitch, as of voice: to speak in a high key.
14. mood or characteristic style, as of expression or thought: He writes in a melancholy key.
15. degree of intensity, as of feeling or action.
16. a pin, bolt, wedge, or other piece inserted in a hole or space to lock or hold parts of a mechanism or structure together; a cotter.
17. a small piece of steel fitting into matching slots of a hub of a wheel or the like and the shaft on which the wheel is mounted so that torque is transmitted from one to the other.
18. a contrivance for grasping and turning a bolt, nut, etc.
19. Computers. a field or group of characters within a record that identifies the record, establishing its position among sorted records, and/or provides information about its contents.
20. (in a series of advertisements or announcements soliciting replies) a unique code inserted for each medium used, to determine the relative effectiveness of the media.
21. Electricity.
  1. a device for opening and closing electrical contacts.
  2. a hand-operated switching device ordinarily formed of concealed spring contacts with an exposed handle or push button, capable of switching one or more parts of a circuit.
22. Biology. a systematic tabular classification of the significant characteristics of the members of a group of organisms to facilitate identification and comparison.
23. Masonry. a keystone.
24. Architecture. (in a ribbed vault) a stone, as a boss, at the intersection of two or more ribs.
25. Masonry, Carpentry. a wedge, as for tightening a joint or splitting a stone or timber.
26. Carpentry. a small piece of wood set into a timber across the grain to prevent warping.
27. Building Trades. any grooving or roughness applied to a surface to improve its bond with another surface.
28. Basketball. keyhole (def 2).
29. Photography. the dominant tonal value of a picture, a high-key picture having light tonal values and minimal contrast and a low-key picture being generally dark with minimal contrast.
30. Painting. the tonal value and intensity of a color or range of colors: Rembrandt's colors are characterized by their low key.
31. Botany. a samara.
32. (initial capital letter) a member of the House of Keys.
33. keys, spiritual authority.
Expand
adjective 34. chief; major; important; essential; fundamental; pivotal: a key person in the company; key industries.
verb (used with object), keyed, keying. 35. to regulate or adjust (actions, thoughts, speech, etc.) to a particular state or activity; bring into conformity: to key one's speech to the intellectual level of the audience.
36. Music. to regulate the key or pitch of.
37. Painting.
  1. to paint (a picture) in a given key.
  2. to adjust the colors in (a painting) to a particular hue: He keyed the painting to brown.
38. to fasten, secure, or adjust with a key, wedge, or the like, as parts of a mechanism.
39. to provide with a key.
40. (in the layout of newspapers, magazines, etc.) to identify, through signs or symbols, the positions of illustrations or pieces of copy in a dummy.
41. to lock with or as if with a key.
42. Masonry. to provide (an arch or vault) with a keystone.
43. Computers. keyboard (def 4).
Expand
verb (used without object), keyed, keying. 44. to use a key.
45. Computers. keyboard (def 4).
Verb phrases 46. key in, Computers. keyboard (def 4).
47. key on,
  1. Football. to watch the position and movements of an opponent in order to anticipate a play: The defensive backs keyed on the star receiver.
  2. Also, key in on. to single out as of prime importance or interest; be intent on or obsessed with: a company that is keyed in on growth.
48. key up,
  1. to bring to a particular degree of intensity of feeling, excitement, energy, nervousness, agitation, etc.: keyed up over the impending test.
  2. to raise (a piece of masonry) by the insertion of a wedge or wedges.
  3. to raise (the haunches of an arch) by the insertion of a voussoir.
Idioms 49. power of the keys, the authority of a pope in ecclesiastical matters, vested in him as successor of St. Peter.
Dadhawk (04-13-2015)
Old 04-13-2015, 12:15 PM   #25
I had keyless for many years and now that I am back to one I just jump in and try to push a nonexistent button at least once a day!
Old 04-13-2015, 01:00 PM   #26
Chanpion
-alex
Haha! My bad, I thought it actually did something.
Old 04-13-2015, 01:08 PM   #27
What's a "key"?
It's that thing that prevents someone from hopping in your car when you are standing outside of it, pushing a button and driving off.
You know, that thing... (although, in all fairness a gun works for that too)
Old 04-13-2015, 01:10 PM   #28
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Road noise is a big problem for me in this car and the main reason I'll be getting rid of it when the lease is up. Adding performance-oriented tires makes it worse too.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
Dampening Road Noise from Wheel Wells aznatama Electronics | Audio | NAV | Infotainment 6 08-18-2014 07:59 PM
hankook v12 road noise DarkestBuddha Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-04-2014 09:46 PM
Road/Exhaust noise mitigation? l0aded Scion FR-S / Toyota 86 GT86 General Forum 10 03-05-2013 06:55 PM
road noise chris's fr-s Scion FR-S / Toyota 86 GT86 General Forum 40 12-01-2012 11:19 PM
