| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
#16 |
Drives: 2015 Dodge Challenger SXT
Damn, how did you manage that, a giant shoe horn? My bestfriend is only 5'-8" and around that same weight and she had to have the seat all the way back just to fit in, and even with it all the way back she wasn't exactly perfectly comfortable in the car. I guess my definition of a useful seat is just different as to me really it has to be a practical useful seat, you get in, you sit down, you have room, to me if it involves squishing people in and some kind of human oragami it's not a useful seat, maybe when I was in my late teens/early 20's I would have thought that was acceptable to call a seat useable, but not now.
#17 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
This guy claims to have gotten 4 "dudes" in the FR-S during his test drive.
So many modders have more cents than sense!
#18 | |
Drives: 05 Sti 20g'd
Stolen from:http://www.ferrari-talk.com/forums/f...position-2274/ Proper driving position, according to Ralf Schumacher 1. Seat height: as high as possible. 2. Distance from steering wheel: your outstretched arms meet the sides of the wheel at the wrists. 3. Distance to the pedals: with the clutch fully depressed, the knee is still bent. "A Formula One driver wouldn't be able to drve more than a few hundred yards in the seating position used by most drivers... ...The best seating position for ordinary drivers is not quite as extreme as in motorsport, but the principles are similar... ...A high seating position automatically provides a better all-around view and a better view of the instruments. Of course, there are limits to height adjustment: there should be at least enough room between the ceiling of the car and the top of the driver's head for a clenched fist... ...The angle between the backrest and the seat should be 90-100 degrees, i.e., nearly upright. Most drivers prefer a more shallow position for the backrest, and initially find this most comfortable. That's not ideal, however, because the backrest supports the entire back only when the spinal column keeps its natural shape... ...The headrests are not just there for comfort; they also protect against severe injuries to the neck vertebrae. In a head-on crash, the driver is first preopelled forward, then diagonally backwards and up. Therefore, the top edge of the headrests should be at least level with the top of the head or higher. Whiplash injuries and dangerous injuries to the cervical vertebrae frequently come about because the headrests are set too low..." |
#19 |
Well she is a big girl, as in heavy, so it was tight for her.
That's actually almost exactly how I have my seat adjusted, no clue if my knees are bent with the clutch depressed since it's an automatic, but they are always when pressing the gas/brakes, the steering wheel is exactly that distance away and the seat is almost all the way up height wise. |
#20 | |
Ninja Cat Mod
Education is Important, but Race Cars are more Importanter |
#21 |
Drives: Silver AT Limited
Post pics when you get this project dun! I want to see
#22 | |
Yup, I certainly will once I get everything in
#23 |
Today I finally got a chance to poke around back there and pull the rear seat out which was easy (putting it back in was a bit of a pain though) and it looks like if I go with a fiberglass enclosure I should be able to fit the 12" subs I have in the back there without interfering with folding the rear of the seat to get access into the trunk.
#24 |
Drives: Raven Scion FRS
the rear seats can be removed in minutes with simple tools. It took us about 5 minutes or less to remove them the first time.
#25 |
Yeah, it took me more time to find the right size socket to unbolt it than it did to actually take it out, was just a pain getting that back loop to latch back in place when putting it back in.
#26 |
Drives: Hot Lava 2013 Scion Frs
It looks pretty simple..any need to disconnect the battery? I'm not in the mood to get thumped in the back of the head by an airbag while doing it.
#27 |
I didn't disconnect the battery when I took one of the seats off, really there should be no reason to have to do so.
#28 |
Drives: 13 DGM BRZ Ltd
There is no need to disconnect the battery to remove the rear seat bottoms. There are no electrical connectors there for the airbag system - only the fuel pump stuff.
To those who still haven't figured out how to remove the rear seat bottoms, 1x 10mm bolt holds it in place at the forward edge nearest the front seats, and a hook (on the seat cushion) and loop (bracket bolted to the car) system at the trailing edge nearest the trunk for each cushion. Unbolt at the front, push down and pull out at the rear, and presto your seat bottom is out. |
| Sit in the rear seat for me ;) (with photos of people in back seat) | D4ng3r | Scion FR-S / Toyota 86 GT86 General Forum | 125 | 11-14-2013 06:59 AM |
| Rear seat question, version 2.0 | 8987846 | BRZ First-Gen (2012+) — General Topics | 29 | 06-05-2012 06:13 PM |
| would rear-facing baby seat fit? | ranisron | BRZ First-Gen (2012+) — General Topics | 17 | 02-27-2012 11:49 PM |
| Crazy idea... the Rear Seat info ? | MRZ415 | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 01-27-2012 12:19 PM |
| Pics of people sitting in rear seat | glorydays | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 12-08-2011 04:54 AM |
