Old 06-14-2012, 11:28 AM   #15
Originally Posted by Shizuma View Post
It seems virtually imposible to me, as i'm 5'-8" which while tall for a woman really isn't that tall in general, I would bet almost all the guys driving the car are my height or taller than me, with the seat adjusted for me there is only 1" between the front seat and back seat, too small for anyones legs to fit back there, now I could possibly see if you squish the person in the passanger's seat you could squeeze someone in the back on that side, but the drivers side? I don't see it as possible unless the driver is a really short woman around 5'-0"
I'm 5'7" and have driven the FR-S with MomHawk (5'3") and Son3Hawk(5'10") in the back behind me. My son's head heads the glass, but otherwise was OK for a short trip. He was much more comfortable turned sideways though or sitting behind MomHawk on the passenger side.
Old 06-14-2012, 11:32 AM   #16
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
Originally Posted by Laika View Post
I got a friend that was about 220 pounds and 6 foot with another 6 foot guy around 130 pounds behind him.
Damn, how did you manage that, a giant shoe horn? My bestfriend is only 5'-8" and around that same weight and she had to have the seat all the way back just to fit in, and even with it all the way back she wasn't exactly perfectly comfortable in the car. I guess my definition of a useful seat is just different as to me really it has to be a practical useful seat, you get in, you sit down, you have room, to me if it involves squishing people in and some kind of human oragami it's not a useful seat, maybe when I was in my late teens/early 20's I would have thought that was acceptable to call a seat useable, but not now.
Shizuma is offline   Reply With Quote
Old 06-14-2012, 11:53 AM   #17
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
This guy claims to have gotten 4 "dudes" in the FR-S during his test drive.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 06-14-2012, 12:42 PM   #18
aethelwulf
Drives: 05 Sti 20g'd
If she is 5'8" and had the seat back that far then I would guess she is either 70% leg or had the seat much further back than is really necessary. Most people sit a lot farther back than is needed or even ideal for driving. Sitting closer may feel uncomfortable at first, but it's something that you will quickly adjust to.
Stolen from:http://www.ferrari-talk.com/forums/f...position-2274/
Proper driving position, according to Ralf Schumacher
1. Seat height: as high as possible.
2. Distance from steering wheel: your outstretched arms meet the sides of the wheel at the wrists.
3. Distance to the pedals: with the clutch fully depressed, the knee is still bent.
"A Formula One driver wouldn't be able to drve more than a few hundred yards in the seating position used by most drivers...
...The best seating position for ordinary drivers is not quite as extreme as in motorsport, but the principles are similar...
...A high seating position automatically provides a better all-around view and a better view of the instruments. Of course, there are limits to height adjustment: there should be at least enough room between the ceiling of the car and the top of the driver's head for a clenched fist...
...The angle between the backrest and the seat should be 90-100 degrees, i.e., nearly upright. Most drivers prefer a more shallow position for the backrest, and initially find this most comfortable. That's not ideal, however, because the backrest supports the entire back only when the spinal column keeps its natural shape...
...The headrests are not just there for comfort; they also protect against severe injuries to the neck vertebrae. In a head-on crash, the driver is first preopelled forward, then diagonally backwards and up. Therefore, the top edge of the headrests should be at least level with the top of the head or higher. Whiplash injuries and dangerous injuries to the cervical vertebrae frequently come about because the headrests are set too low..."
aethelwulf is offline   Reply With Quote
The Following 2 Users Say Thank You to aethelwulf For This Useful Post:
Dadhawk (06-14-2012), WRB-DZA-BRZ (06-14-2012)
Old 06-14-2012, 01:46 PM   #19
Shizuma
Shizuma's Avatar
Well she is a big girl, as in heavy, so it was tight for her.
That's actually almost exactly how I have my seat adjusted, no clue if my knees are bent with the clutch depressed since it's an automatic, but they are always when pressing the gas/brakes, the steering wheel is exactly that distance away and the seat is almost all the way up height wise.
Old 06-14-2012, 05:04 PM   #20
M-17
Ninja Cat Mod
M-17's Avatar
This is a real rough image of what i'm thinking of doing, so the top of the box would have a layer for acoustically transparent fabric so the subs wouldn't be visible and the top of the box would be flush with the center hump so the back seat could still fold flat when needed, also I would put speaker grills over the speakers but under the fabric so I can put stuff back there without worrying about damaging the subs.
This sounds like something I would want to do, just to get the car shaking. Although that's if I choose to have a car to be casual vs. track oriented.
Old 06-14-2012, 05:22 PM   #21
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Post pics when you get this project dun! I want to see
mechaghost is offline   Reply With Quote
Old 06-14-2012, 06:27 PM   #22
Shizuma
Shizuma's Avatar
Yeah, my car will likely never see a track ever, it's just my daily drive so making sure I shave every pound of weight off the car I can isn't a concern, and no way I could live with the lack of bass in the factory stereo for too long, going from a car with 2 12" subs and 4 6.5" woofers for bass to a car with simply 2 6.5" woofers for bass is painful, the music sounds so lacking and hollow to me, my $40 Skullcandy headphones have more bass sadly :/
Yup, I certainly will once I get everything in
Old 06-22-2012, 01:28 PM   #23
Shizuma
Shizuma's Avatar
Today I finally got a chance to poke around back there and pull the rear seat out which was easy (putting it back in was a bit of a pain though) and it looks like if I go with a fiberglass enclosure I should be able to fit the 12" subs I have in the back there without interfering with folding the rear of the seat to get access into the trunk.
Old 06-22-2012, 01:32 PM   #24
Juan@aePerformance
Juan@aePerformance's Avatar
Drives: Raven Scion FRS
the rear seats can be removed in minutes with simple tools. It took us about 5 minutes or less to remove them the first time.
Juan@aePerformance is offline   Reply With Quote
Old 06-22-2012, 01:40 PM   #25
Shizuma
Shizuma's Avatar
Yeah, it took me more time to find the right size socket to unbolt it than it did to actually take it out, was just a pain getting that back loop to latch back in place when putting it back in.
Old 03-28-2013, 10:15 AM   #26
scottynoshotty
scottynoshotty's Avatar
Drives: Hot Lava 2013 Scion Frs
It looks pretty simple..any need to disconnect the battery? I'm not in the mood to get thumped in the back of the head by an airbag while doing it.
scottynoshotty is offline   Reply With Quote
Old 03-28-2013, 11:18 AM   #27
Shizuma
Shizuma's Avatar
I didn't disconnect the battery when I took one of the seats off, really there should be no reason to have to do so.
Old 03-28-2013, 11:26 AM   #28
infinite012
Drives: 13 DGM BRZ Ltd
There is no need to disconnect the battery to remove the rear seat bottoms. There are no electrical connectors there for the airbag system - only the fuel pump stuff.
To those who still haven't figured out how to remove the rear seat bottoms, 1x 10mm bolt holds it in place at the forward edge nearest the front seats, and a hook (on the seat cushion) and loop (bracket bolted to the car) system at the trailing edge nearest the trunk for each cushion. Unbolt at the front, push down and pull out at the rear, and presto your seat bottom is out.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
bignrichlll (03-29-2013)
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 07:59 AM
Rear seat question, version 2.0 8987846 BRZ First-Gen (2012+) — General Topics 29 06-05-2012 07:13 PM
would rear-facing baby seat fit? ranisron BRZ First-Gen (2012+) — General Topics 17 02-28-2012 12:49 AM
Crazy idea... the Rear Seat info ? MRZ415 Scion FR-S / Toyota 86 GT86 General Forum 78 01-27-2012 01:19 PM
Pics of people sitting in rear seat glorydays FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-08-2011 05:54 AM
