| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: 2013 Firestorm Scion FR-S
If I had to guess, I would say it is way too wide.
#16 |
I don't know, but motofan if you do attempt this, let me know. I might consider doing the same and would like to know if it was an issue.
#17 |
Drives: 2013 Raven FR-S 6MT
Nitro,
Thanks for the right up w pictures. I plan on adding a similar Pioneer unit in the next week or so. What about the mic for Bluetooth. Where you able to use the stock mic in the headboard? Thanks again. |
#18 |
I forgot to add this to the DIY, but I ran the included Pioneer mic to my sun visor. I noticed that the stock mic had 4 wires coming out of it and I didn't feel like trying to figure out what the extra 2 wires were.
#19 |
Drives: 10 VW GTI
#20 |
Drives: Scion FRS
I just did this install and routed the aftermarket mic to where the stock mic is located. Running wires took about 5min.
Pop off the stock mic piece from roof and run your aftermarket mic wire from deck under driver side dash up the a-pillar then under the roof liner. (where the roof meets the windshield) and into the stock mic area. Done!
#21 |
Radio wiring harness guru
Drives: 1996 SVX L AWD
Sounds like the OEM mic has a built-in amplifier circuit, like recent Subarus have. See this post.
Different aftermarket HU brands require different techniques to bypass the parking brake requirement. Most Kenwoods and JVCs just need their parking brake lead tied to chassis ground. With many others, you can use a simple 12 volt relay, or an equivalent (and much smaller) solid-state device. There are also tiny alternatives to that PAC TR7 module. Google your HU model plus 'parking brake bypass' to see what yours needs. If other people might be driving your car (friends, family, valets, mechanics), consider adding a hidden bypass disable switch so they can't blame your HU as the reason they drove into a telephone pole.
#22 |
Drives: 10 VW GTI
I finally gave up the idea of installing the scion radio to the Civic. Instead I placed a Kenwood DDIN in the Civic. I would say the front panel of the Scion radio is too wide. You can't put it in the Civic without cutting off a large chunk of Civic's radio bazel.
#23 | |
#24 |
Drives: 2013 FR-S Matte Orange
I just installed a Kenwood DDX719 and I will say the dash kit is butt a55 ugly. Gonna have to do something to make it blend better. Bondo may be the answer.
#25 |
Drives: 1995 Ford Probe
can we install the brz navigation unit in the fr-s?
#26 |
Drives: Raven 6speed mt
I'm a noob that needs help have no fm or am radio
I have a pioneer z140bh everything works but I ran into a problem with putting the antenna into the traffic tuner.my vehicles antenna does not match! Wtf I'm so lost on how to fix the problem.
#27 |
Drives: Argento 6spd FR-S
#28 |
First86 / boat thief
Drives: MKIV Supra
| BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
| Subaru iPod Connector Cable? | Kimsey47 | Audio/Visual, Electronics, Infotainment, NAV | 25 | 07-05-2012 02:49 PM |
| BRZ Nav Unit owner's manuals | eikond | Electronics | Audio | NAV | Infotainment | 0 | 04-11-2012 04:07 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
