Old 06-19-2012, 09:05 PM   #15
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by motofan View Post
Hi Nitro,
I'm thinking about installing a HU for the FR-S. Do you think I can reuse the standard scion HU, for an 2002 civic, which support standard double DIN. Do you think the the scion HU will fit? It looks wide to me. Thanks.
If I had to guess, I would say it is way too wide.
Nitro is offline   Reply With Quote
Old 06-20-2012, 10:05 AM   #16
Hi Nitro,
I don't know, but motofan if you do attempt this, let me know. I might consider doing the same and would like to know if it was an issue.
Old 06-20-2012, 02:27 PM   #17
itsafrs
itsafrs's Avatar
Drives: 2013 Raven FR-S 6MT
Nitro,
Thanks for the right up w pictures. I plan on adding a similar Pioneer unit in the next week or so. What about the mic for Bluetooth. Where you able to use the stock mic in the headboard? Thanks again.
itsafrs is offline   Reply With Quote
Old 06-20-2012, 04:27 PM   #18
Nitro
Nitro's Avatar
Originally Posted by itsafrs View Post
Nitro,
I forgot to add this to the DIY, but I ran the included Pioneer mic to my sun visor. I noticed that the stock mic had 4 wires coming out of it and I didn't feel like trying to figure out what the extra 2 wires were.
Old 06-20-2012, 10:00 PM   #19
motofan
Drives: 10 VW GTI
Not stereo mic?
motofan is offline   Reply With Quote
Old 06-28-2012, 02:05 PM   #20
solution
solution's Avatar
Drives: Scion FRS
I just did this install and routed the aftermarket mic to where the stock mic is located. Running wires took about 5min.
Pop off the stock mic piece from roof and run your aftermarket mic wire from deck under driver side dash up the a-pillar then under the roof liner. (where the roof meets the windshield) and into the stock mic area. Done!
solution is offline   Reply With Quote
Old 07-01-2012, 10:00 PM   #21
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Sounds like the OEM mic has a built-in amplifier circuit, like recent Subarus have. See this post.
Different aftermarket HU brands require different techniques to bypass the parking brake requirement. Most Kenwoods and JVCs just need their parking brake lead tied to chassis ground. With many others, you can use a simple 12 volt relay, or an equivalent (and much smaller) solid-state device. There are also tiny alternatives to that PAC TR7 module. Google your HU model plus 'parking brake bypass' to see what yours needs.
If other people might be driving your car (friends, family, valets, mechanics), consider adding a hidden bypass disable switch so they can't blame your HU as the reason they drove into a telephone pole.
SVXdc is offline   Reply With Quote
Old 07-03-2012, 07:35 PM   #22
motofan
Drives: 10 VW GTI
I finally gave up the idea of installing the scion radio to the Civic. Instead I placed a Kenwood DDIN in the Civic. I would say the front panel of the Scion radio is too wide. You can't put it in the Civic without cutting off a large chunk of Civic's radio bazel.
Old 07-03-2012, 09:43 PM   #23
that would make sense as it seems Toyota makes their radios extra wide even though they are 2DIN height.
Old 07-07-2012, 09:43 PM   #24
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I just installed a Kenwood DDX719 and I will say the dash kit is butt a55 ugly. Gonna have to do something to make it blend better. Bondo may be the answer.
digital_assassin is offline   Reply With Quote
Old 07-15-2012, 03:54 PM   #25
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
can we install the brz navigation unit in the fr-s?
mikeg7827 is offline   Reply With Quote
Old 07-24-2012, 12:07 PM   #26
Raven86gt
Drives: Raven 6speed mt
I'm a noob that needs help have no fm or am radio
I have a pioneer z140bh everything works but I ran into a problem with putting the antenna into the traffic tuner.my vehicles antenna does not match! Wtf I'm so lost on how to fix the problem.
Raven86gt is offline   Reply With Quote
Old 08-09-2012, 01:23 AM   #27
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by Gir View Post
Okay, sweet. I was just curious because I'm looking to do the same thing, and with my old JVC one, I just grounded it out.
Looks like I'll need to find the unit somewhere in Aus
a simple 12v relay will work as well.
cruzinbill is offline   Reply With Quote
Old 09-23-2012, 08:46 PM   #28
SpeedR
First86 / boat thief
Drives: MKIV Supra
Originally Posted by |-Goku-| View Post
I wonder if anyone will make a trim piece that completely replaces the second piece that you remove in your DIY.
Would be nice, because it would look more complete, and OEM, IMO
working on it.
SpeedR is offline   Reply With Quote
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
Subaru iPod Connector Cable? Kimsey47 Audio/Visual, Electronics, Infotainment, NAV 25 07-05-2012 02:49 PM
BRZ Nav Unit owner's manuals eikond Electronics | Audio | NAV | Infotainment 0 04-11-2012 04:07 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
