#15 |
I think the IS-F is a completely different setup. You're not comparing apples to apples and you have done zero research on the DI/PI hybrid system on the FA20.
You're opinion isn't worth much. Do the same research as the OP and come back and refute their findings, otherwise move along and stop vendor bashing. |
#16 | |
Drives: Gx 460, FRS, Prius
Factory piston from my ISF ![]() Factory piston from a Fa20 on the left. ![]() The piston designs are very similar. Problem we were having was that after the head work the piston was still getting extremely hot and failing In the same spot that Orido was I'll exit the thread here because I'm not looking to hurt anyone's business or attack anyone. I'm just interested in how the op got around the issues that come with DI removal. Sent from my phone so sorry for any typos
#17 | |
#18 |
Drives: 2013
I want to point out something I may have not made obvious. DO NOT run the stock DI system and just turn the injectors off. That is what Max did when he had failures with his drift car and it would be the same case in the FA20. If you leave the stock DI injectors in you MUST run at least some volume of fuel through them.
It's also worth noting that the stock piston is obviously designed to run a DI injector and of course I would recommend an aftermarket piston properly designed for the application. Pistons melt from prolonged knock or pre-detonation not because they aren't being sprayed with fuel. Granted the stock piston has a lot of hot spots that will make a potential knock scenario worse but they are present with or without the DI. |
#19 |
Drives: 2013 Black FR-S
Interesting!
So this was your test: Motec + DI = more knock prone Motec + DI deleted = less knock prone Or was it: Stock ECU + DI = more knock prone Motec + DI deleted = less knock prone
#20 |
Hot Lava 6MT
Drives: Hot Lava FR-S
I really like this thread. Please keep up the great work team, I look forwarding to seeing your products on the market.
#21 | |
Drives: DGM BRZ limited
And thanks to Carolina Dyno for sharing your findings. I love reading responses to challenges, such as the ones above. We all learn. Or at least I do. |
#22 |
Drives: FR-S 10 #103 AT
I don'r understand the fuss some are making. From what I've read, when going full out with a FI system (built motor level) it's pretty much standard procedure to lower the compression (piston replacement ), dramatically increase the injector capacity and delete the DI system. The OP's company just developed a kit to do that for the twins.
I thought replacing the pistons went without saying.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#23 | |
That Guy
Drives: 2013 asphalt FRS MT
Forgive me, but that looks like it could be fixed with a file and a few seconds if the heads were already out. Will your DI delete kit require the heads be removed? |
#24 |
Drives: toyota mr2/ Toyota GT86
Agreed
if the sharp edges in the chamber are such a problem did you try some heads with everything smoothed out? also does the standard head gasket leave any voids/ places for dead gas to sit? As it looks like the gasket impression is a way off the valves and edge of the chamber Last edited by 350matt; 03-19-2015 at 06:29 PM. |
#25 | ||||
Drives: 2013
You could file those spots down but at that point I personally would just weld it up, smooth it out, and put a non DI piston in it. Quote:
![]() Quote:
#26 |
the reason for asking was I note Cosworth sell these
http://www.karperformance.com/Produc...jc=&ProId=NTQ0 which come right up to the edge of the chamber, do you think there's any benefit to this? |
#27 |
Drives: CBS brz limited
In for updates! Which efr is that?
#28 | |
Drives: 2013
It's the EFR 7670 with the T4 divided externally gated housing. |
| I keep breaking lug studs!!! | Guff | Issues | Warranty | Recalls / TSB | 59 | 12-30-2015 12:34 AM |
| Axle breaking PSA | markmatley | Hawaii | 4 | 02-14-2014 03:44 AM |
| Down hill breaking... ABS? | shaofis | Issues | Warranty | Recalls / TSB | 11 | 10-22-2012 04:28 PM |
| Breaking Bad: Season 5 | |-Goku-| | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 07-22-2012 01:02 AM |
