Old 03-20-2015, 08:16 PM   #15
lx93
Drives: 2013 BRz Premium
Originally Posted by sw20kosh View Post
You can easily swap out the perrin 13 row series 6 setrab core for a 15, 20, 25 row series 9 setrab.
You may even be able to mount this core behind your intercooler depending on how flexible the intercooler mounting is (or depending on your ability to create new mounts for the intercooler). In my case, my intercooler had just enough space between it and the condenser to fit in my 25 row setrab core. Also, the radiator can be moved forwards or backwards as desired with a little bit of DIY work on the top radiator brackets.
I have looked into the selection of setrab cores, and looking behind the grille, it seems my current series 6 13 row is just about the tallest that can fit under there. it is mounted in front of the FMIC so above it there is a rail in the way. where do you fit the 25 row core?
lx93 is offline   Reply With Quote
Old 03-20-2015, 08:17 PM   #16
lx93
Originally Posted by [Ron] View Post
You will not need a retune. it is the same blower with a different unit to handle lubrication (self lubricated versus fed from the oil pan. Please see the following thread for more information:
http://www.ft86club.com/forums/showthread.php?p=1754125
It is possible to send in your current V3 blower for an oil-fed "upgrade". More information is available in the thread I linked.
nice. I have called vortech and it is 1000 to upgrade to v2, for future reference
Old 03-21-2015, 09:05 AM   #17
sw20kosh
Drives: 2013 Black FR-S
Behind IC where the rail does not get in the way.
Old 03-22-2015, 11:11 AM   #18
lx93
I have Koyo radiator so I am not sure if there is enough clearance between that and the fmic. I will take off my bumper to check I guess
Old 03-23-2015, 01:37 AM   #19
sw20kosh
Radiators can move easily on this car. The top brackets are easy to modify/move if need be. Just drill new holes.
Old 06-13-2016, 12:01 AM   #20
Tenino
Drives: 13' BRZ
Any updates on the clearance with aftermarket koyo radiator? I'm currently in same position of upgrading to koyo radiator and swapping my 13 row setrab core that came with the Perrin oil cooler for a 25 row setrab.
*JRSC*
Tenino is offline   Reply With Quote
Old 06-13-2016, 05:04 PM   #21
AJPG
Drives: 22RE, FA20, 4G63
*JRSC*
Hi,
Different approach here.
I use 2 oil coolers of 10 rows each connected serial. Temps well controlled as oil pressure, SC with vortech 3.125" pulley, koyo rad, out side temp 90f. DD on backroads.
AJPG is offline   Reply With Quote
Brake cooling Model Citizen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 115 08-28-2018 11:28 PM
Oil and water cooling Boba_kz Engine, Exhaust, Transmission 13 08-08-2017 03:58 AM
brakes and cooling DRACHENV6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 10:34 AM
APR Performance FRS/BRZ Brake Cooling Kit vividracing Brakes, Suspension, Chassis 0 08-08-2013 04:03 PM
vortech supercharger & clutch & cooling? ft86me Forced Induction 42 07-08-2013 01:09 PM
