Old 03-25-2015, 09:44 PM   #15
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Originally Posted by Silver Ignition View Post
Which pin is the parking brake input? Is it on the Beatsonic harness or on the factory harness?
The parking brake input is pin #6 on the HU's 16-pin socket. You'll find that your FR-S did not have a factory harness for that socket -- as shipped, your car does not connect the parking brake signal to the HU.
See this page on my site: Subaru/Toyota 16-pin camera socket information
The Beat-Sonic harness has both a 16-pin plug and socket. Their harness passes through most of the pins from the car's factory plug to the HU.
Since your car didn't have a factory plug, the Beat-Sonic's socket remains unused. You can touch the #6 pin there.
Looking forward to seeing "before" and "after" pictures of your HU's Diagnostic and Camera Setting screens.
BTW, it turned out that the only parking guide lines you were seeing were from the Rydeen camera, not the HU, correct?
SVXdc is offline   Reply With Quote
Old 03-31-2015, 08:04 PM   #16
bruizerrob
Drives: 2013 Scion 10 series frs
Where do you run the reverse trigger wire?
Sent from my SAMSUNG-SM-N910A using Tapatalk
bruizerrob is offline   Reply With Quote
Old 03-31-2015, 10:35 PM   #17
bruizerrob
I figured it out. Also found a connector that wasn't plugged in. I've never had that kickpanel off so it must have been a weak push from the factory.
Rydeen Duo on BRZ Limited sure74 Electronics | Audio | NAV | Infotainment 343 01-22-2019 07:28 PM
rydeen mini backup cam jknakes Electronics | Audio | NAV | Infotainment 21 05-08-2015 11:04 PM
How to wire up with Rydeen Duo Hyperian Electronics | Audio | NAV | Infotainment 6 05-16-2014 04:20 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 06:20 PM
Rydeen Duo installed on a Preimum sparks Electronics | Audio | NAV | Infotainment 9 10-16-2012 06:39 PM
