Old 02-17-2015, 04:46 PM   #15
BRZFanatix
Drives: Soon to be BRZ
Andy? I wouldn't rub right?
BRZFanatix is offline   Reply With Quote
Old 02-17-2015, 05:18 PM   #16
Racecomp Engineering
I think you'd be okay.
- Andy
Old 02-17-2015, 05:38 PM   #17
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
You should be ok.
ApolloSki is offline   Reply With Quote
Old 02-18-2015, 06:08 AM   #18
Sploozel
Drives: 2015 BRZ CWP
inb4 he buys wheels without coils and the wheels don't fit.
Sploozel is offline   Reply With Quote
The Following User Says Thank You to Sploozel For This Useful Post:
wparsons (02-18-2015)
Old 02-18-2015, 08:58 AM   #19
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
I dunno.
A buddy of mine had bought some work wheels 18x9.5 with 38 offset, and couldn't install them because the stock coilovers are too wide. He bought tein streetflex and he's ok now.
BTW, he fitted 255 tires. 265's were too wide as well.
OnionTou is offline   Reply With Quote
Old 02-18-2015, 09:33 AM   #20
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
First things first, go to the wheels section of the forum and look for similar setups, there are millions. Second 225 is way to damn to be comfortable imo for a 9.5 but doable. Third it'll fit but you'll need camber and plenty.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-18-2015, 10:47 AM   #21
BRZFanatix
Originally Posted by OnionTou View Post
I dunno.
I dont plan on using stock, as I said I'm buying these for coils:
KW Suspension V3
Old 02-18-2015, 10:54 AM   #22
BRZFanatix
Are these cambers good with the KW coils im getting?
Whiteline Rear Camber kit I would get cambers for both rear and front
Old 02-18-2015, 10:59 AM   #23
You will be able to adjust camber up front without buying extra parts with KW V3.
The WL rear camber kit will work but it is a difficult install and some shops don't like adjusting it.
Since you're a self-admitted suspension newbie, I'd highly recommend buying your suspension parts from an BRZ/FRS shop that knows things about suspension. There are a couple good ones on this board. That way when you have a question after you receive your stuff, you can get professionals to help you.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
BRZFanatix (02-18-2015)
Old 02-18-2015, 11:16 AM   #24
BRZFanatix
- Andy
Thanks good to know! And I will talk so them!!! So at least I don't have to buy a camber kit for the front, which kit in the back would be better than WL since you said some shops don't like adjusting it? Is there a better choice than WL?
Thanks for your patients with me andy! I really appreciate you taking the time to respond to my newbie questions.
Edit:
Andy I found these Adjustable rear arms? These good ones? Cusco Lateral Arm Rear Adjustable
Old 02-18-2015, 11:25 AM   #25
ApolloSki
Stealth
ApolloSki's Avatar
Edit:
I'd recommend SPC for your application. It's a much cheaper option and it does the job pretty nicely. If you want to spend the extra cash for a good part, get SPL.
The Following User Says Thank You to ApolloSki For This Useful Post:
Old 02-18-2015, 11:34 AM   #26
BRZFanatix
Those would these be good for the rear?
SPC Performance
And here is the SPL you were talking about:
SPL Pro Suspension
Are the ones I chose the right ones? I might as well get the SPL then
Old 02-18-2015, 12:34 PM   #27
ApolloSki
Stealth
ApolloSki's Avatar
SPC Performance
SPL Pro Suspension
Yes, those are the ones.
If you're mostly going to DD/Canyon your car(with a couple track days a year), the SPC is good enough. I only recommended SPL because I know the quality is good and I heard its easier to adjust (for alignment person) than Cusco - plus its in the same price range. Either way, can't go wrong with either of those. Just be sure and get the newest version of the SPC.
Old 02-18-2015, 12:52 PM   #28
BRZFanatix
Are the ones I posted the newest ones?
newbie OFT question 2much Software Tuning 5 11-13-2014 08:59 PM
newbie NA Tune Question eguzman6 BRZ First-Gen (2012+) — General Topics 2 11-12-2014 03:55 PM
Newbie Question! ButtonMasher Tracking / Autocross / HPDE / Drifting 5 04-10-2014 04:20 PM
Newbie question: what is an ecu tune Dispect Engine, Exhaust, Transmission 1 11-30-2012 01:35 PM
question about frs for a newbie enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 18 08-04-2012 05:42 PM
