#15 | |
All that said, why not just wire up a different switch you can manually press instead of pushing in the clutch? Then you don't have to worry about what the ECU's will do thinking the clutch is constantly depressed.
#16 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#17 |
If you're already spending enough for the swap, why not go with a twin disc clutch and avoid the issue altogether? Better drivability too.
#18 |
My FR-S has 5 gears
Define "enough" for the swap. Because I have less into this swap than most stock block fa20 turbo builds. Also, only twin disc for my future par setup is 14 weeks lead time
Omar GC
#19 |
What worries me is what will you do to trigger your launch control?
#20 |
My FR-S has 5 gears
No concern for LC, I don't drag race ^_^
Omar GC
#21 |
Drives: 2JZ FRS
Works fine for me still. Nothing is different that I've noticed. It's been a few months
| BRZ Nav Bypass | lxsedan | CANADA | 43 | 03-30-2015 07:44 AM |
| Pressing/releasing clutch pedal - audible click sound (not the clutchs switch | tanner | BRZ First-Gen (2012+) — General Topics | 26 | 06-03-2014 08:24 PM |
| Push-button start clutch switch | mike the snake | Engine, Exhaust, Transmission | 8 | 04-14-2014 11:31 PM |
| BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
